* | bsps/m68k/mvf5235: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 6 | -18/+132 | |
| | | | | Updates #3053. | |||||
* | bsps/m68k/mcf5225x: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 4 | -12/+88 | |
* | bsps/m68k/mcf52235: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 3 | -9/+66 | |
* | bsps/m68k/mcf5206elite: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 1 | -3/+22 | |
* | bsps/m68k/include: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 4 | -12/+88 | |
* | bsps/m68k/genmcf548x: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 15 | -45/+330 | |
* | bsps/m68k/gen68360: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 1 | -3/+22 | |
* | bsps/m68k/gen68340: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 9 | -27/+198 | |
* | bsps/m68k/csv360: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 2 | -6/+44 | |
* | m68k/bsps/av5282: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 5 | -15/+110 | |
* | bsps/lm32/shared: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 8 | -24/+176 | |
* | bsps/lm32/lm32_evr: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 1 | -3/+22 | |
* | bsps/lm32/include: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 1 | -3/+22 | |
* | bsps/include: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 30 | -90/+660 | |
* | bsps/i386/shared/pci/pci_io.c:Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 1 | -3/+22 | |
* | bsps/i386/pc386: Change license to BSD-2 | Joel Sherrill | 2022-07-11 | 18 | -51/+376 | |
* | bsps/arm/realview-pbx-a9: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 11 | -33/+242 | |
* | bsps/arm/raspberrypi: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 2 | -6/+44 | |
* | bsps/arm/lpc32xx: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 29 | -87/+638 | |
* | bsps/arm/lpc24xx: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 34 | -102/+748 | |
* | bsps/arm/imxrt: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 1 | -3/+22 | |
* | bsps/arm/lpc176x: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 14 | -42/+308 | |
* | bsps/arm/include: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 17 | -51/+374 | |
* | bsps/arm/imx: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 16 | -48/+352 | |
* | bsps/arm/csb337: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 6 | -18/+132 | |
* | bsps/arm/beagle: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 2 | -6/+44 | |
* | bsps/arm/atsamv: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 30 | -90/+660 | |
* | bsps/arm/altera-cyclone-v: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 15 | -45/+330 | |
* | bsps/arm/shared: Change license to BSD-2 | Joel Sherrill | 2022-07-08 | 13 | -39/+286 | |
* | bsps/aarch64: Use MMU pages appropriately | Kinsey Moore | 2022-07-06 | 1 | -2/+2 | |
| | | | | | | | | | There were two bugs with MMU page use that were partially hiding each other. The linker script page table section was 4x the size it needed to be and the page table allocation routine was allocating pages PTRSIZE times larger than it needed to. On ILP32, this resulted in incorrect but functional allocation. On LP64, this resulted in allocation failures earlier than expected. | |||||
* | bsps/xilinx-zynq: Init debug console only once | Sebastian Huber | 2022-07-01 | 1 | -4/+1 | |
| | | | | Initialize the debug console only once during early system initialization. | |||||
* | bsp/lpc32xx: Optimize Ethernet transmit | Sebastian Huber | 2022-06-27 | 1 | -1/+1 | |
| | | | | | The updated Ethernet interface driver in libbsd profits from more transmit descriptors since it no longer uses transmit done interrupts. | |||||
* | aarch64/gicv3: Remove accesses to secure registers | Chris Johns | 2022-06-16 | 1 | -3/+15 | |
| | | | | | | RTEMS runs at EL1 and the removed register accesses are for EL3 or the TF-A. This change aligns our driver with the Linux and FreeBSD ones. | |||||
* | bsp/aarch64: Flush the cache before invalidating it | Chris Johns | 2022-06-16 | 1 | -1/+2 | |
| | | | | | - Any page tables need to be flushed if the cache is enabled. Disabling the cache may only be available in secure mode. | |||||
* | bsps/shared/*: Change license to BSD-2 | Joel Sherrill | 2022-06-15 | 74 | -222/+1628 | |
* | bsps/arm: MP core timer setting off by one | Chris Johns | 2022-06-15 | 1 | -1/+1 | |
* | bsp/aarch64: Fix array warning | Chris Johns | 2022-06-11 | 1 | -1/+1 | |
| | | | | Updates #4664 | |||||
* | bsps/stm32h7: remove external memory initialization from nucleo-h743zi BSP | Karel Gardas | 2022-06-10 | 2 | -479/+0 | |
| | | | | | | | Nucleo board does not provide any external memory so code does not have any function here anyway. Sponsored-By: Precidata | |||||
* | bsps/stm32h7: move BSP start hooks into boards subdirectories | Karel Gardas | 2022-06-10 | 7 | -44/+400 | |
| | | | | | | | The idea here is to prepare for better per-board specialization of the hooks function code. Sponsored-By: Precidata | |||||
* | bsps/imx: Enable clock of ETH2 | Christian Mauderer | 2022-06-09 | 2 | -0/+172 | |
* | arm/lpc32xx: Implement new interrupt directives | Sebastian Huber | 2022-06-08 | 1 | -6/+42 | |
* | bsp/lpc32xx: bsp_interrupt_vector_enable() | Sebastian Huber | 2022-06-08 | 1 | -2/+6 | |
| | | | | | | | | The interrupt enables are used to implement a priority scheme in bsp_interrupt_dispatch(). Enable interrupts through bsp_interrupt_vector_enable() only if they are not already enabled to not interfere with the priority scheme while bsp_interrupt_vector_enable() is called during interrupt dispatching. | |||||
* | bsp/lpc32xx: bsp_interrupt_is_valid_vector() | Sebastian Huber | 2022-06-08 | 2 | -0/+31 | |
| | | | | | Provide custom bsp_interrupt_is_valid_vector() implementation since several interrupt vectors are reserved. | |||||
* | bsp/lpc32xx: Use standard timer 2 for tm27.h | Sebastian Huber | 2022-06-08 | 1 | -19/+39 | |
| | | | | | This helps to run the validation tests of the Interrupt Manager directives. | |||||
* | arm/lpc32xx: Hide MLC details | Sebastian Huber | 2022-06-08 | 1 | -3/+1 | |
* | bsp/lpc32xx: Fix FIQ interrupt support | Sebastian Huber | 2022-06-08 | 1 | -10/+13 | |
| | | | | | Do not sporadically service interrupts configured as FIQ by the IRQ interrupt dispatch. | |||||
* | bsps/stm32h7: add board C files for stm32h747i-disco BSP | Karel Gardas | 2022-06-01 | 4 | -0/+736 | |
| | | | | | | | | | | | | Besides C files for the BSP variant the patch also provides license clarification on system_stm32h7xx.c file which is provided in boards/stm/stm32h747i-disco directory. The files comes from STM32CubeH7 project and references "root directory" in its license comment and it's not clear where this points out. Let's add clarification comment about it and also based on it and resulting license let's add SPDX license identifier. Sponsored-By: Precidata | |||||
* | bsps/stm32h7: include CMSIS Cortex-M4 header when required by configuration | Karel Gardas | 2022-06-01 | 1 | -0/+7 | |
* | bsps/stm32h7: enable cache and MPU only on Cortex-M7 | Karel Gardas | 2022-06-01 | 1 | -0/+4 | |
* | bsps/arm: add CMSIS Cortex-M4 Core Peripheral Access Layer Header File | Karel Gardas | 2022-05-30 | 1 | -0/+1937 | |
