Add default implementations for bsp_interrupt_get_affinity() and
bsp_interrupt_set_affinity() which are required to link all tests in SMP
configurations.
Update #3269.
Add rtems_interrupt_entry_remove(). Split up irq-generic.c into several files.
In particular, place all functions which use dynamic memory into their own
file.
Add optional macros to let the BSP customize the vector installation after
installing the first entry and the vector removal before removing the last
entry:
* bsp_interrupt_vector_install()
* bsp_interrupt_vector_remove()
Use these new customization options in the m68k/genmcf548x BSP so re-use the
generic interrupt controller support.
Update #3269.
This function is only used by one BSP.
Update #3269.
Return RTEMS_INCORRECT_STATE instead of RTEMS_INTERNAL_ERROR in case the
interrupt support is not initialized. This is similar to
rtems_timer_server_fire_after() for example.
Update #3269.
Update #3269.
Update #3269.
Update #3269.
Return a status code for bsp_interrupt_set_affinity().
Update #3269.
Return a status code for bsp_interrupt_get_affinity().
Update #3269.
Return a status code for bsp_interrupt_vector_disable().
Update #3269.
Return a status code for bsp_interrupt_vector_enable().
Update #3269.
Add a default implementation which just returns RTEMS_UNSATISFIED.
Update #3269.
Add a default implementation which clears the attributes to zero and
just returns RTEMS_SUCCESSFUL for valid parameters.
Update #3269.
Add rtems_interrupt_raise_on() and rtems_interrupt_clear().
Add a default implementation which just returns RTEMS_UNSATISFIED for
valid parameters.
Update #3269.
valid parameters.
Update #3269.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
Add rtems_interrupt_vector_disable().
Update #3269.
Update #3269.
Bring the error conditions and status in line with
rtems_task_get_affinity() and rtems_task_set_affinity().
Update #3269.
Update #3269.
The heap protection is conditional.
When compiling the lwIP port for the TMS570, there
were issues with the BSP. Headers are expected in a folder
named ti_herc which did not exist. This fixes the issue.
Furthermore, there were multiple warnings about define redefinitions.
This was fixed as well.
These patches were submitted a few months ago, but it was found out
that the default-by-family: [] were missing in the GPIO .yml lines.
This was fixed in this patch.
This patch accounts for different pins for the ETH peripheral
on STM32H7 devices. For example, the Nucleo H743ZI has slightly
different pins than other STM32H7 boards.
The <leon.h> header file contains a lot of implementation details. Hide them
from <bsp.h>.
Fully support the interrupt extension API to set/get the interrupt affinity.
Remove LEON3_irq_to_cpu which defined the interrupt to processor mapping in a
BSP-specific way.
Update #3269.
Flush imx_gic_dist_base so that secondary processors can use the right
address.
Skip the data cache initialization if we are a secondary processor.
The bug was introduced by e164df5e33608576443b4cd5923a9046358ee773 and
did not show up in tests using Qemu since the data cache behaviour is
not emulated.
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
Fixes a problem with bad epilog code in _fini and to keep sections
necessary with the -ffunction/data-sections.
This function is not performance critical. There is no need to
implement it inline.
The fix to address CID 1399742 (NO_EFFECT) in commit
f8b6359415404540864f809cbcffb8c2200261e1 introduced a bug since
LEON3_IrqCtrl_EIrq == -1 in case no extended interrupts are supported by
the interrupt controller. Fix this by checking for
LEON3_IrqCtrl_EIrq > 0.
In addition, interrupt number 0 is reserved and should not be used.
The GICv3 support is shared between AArch32 and AArch64. For AArch32,
the new AARCH64_IS_NONSECURE is never defined. Use ARM_MULTILIB_ARCH_V4
instead.
This issue was introduced by 76c6caad52244ab9a14151620a80ff0f71035b6c.
There is still a change in bsp_interrupt_vector_enable() for AArch32
compared to the version before 76c6caad52244ab9a14151620a80ff0f71035b6c.
Move the moduleid register to the correct offset according to Cadence IP
documentation.
The existing fix for the ZynqMP UART hardware bug only caught the vast
majority of instances where it could occur. To fully fix the data
corruption, this fix must be applied after every baud rate change. This
makes the logic reset and kick apply in any locations where the baud
rate could be changed.
Move _ISR_Handler() to a separate file since it is now only used if a handler
is installed by _CPU_ISR_install_raw_handler().
Statically initialize the traps for external interrupts to use the new
_SPARC_Interrupt_trap() which directly dispatches the interrupt handlers
installed by rtems_interrupt_handler_install() via the BSP-provided
_SPARC_Interrupt_dispatch().
Since the trap table is now fully statically initialized, there is no longer a
dependency on the Cache Manager in the default configuration.
Update #4458.
Add bsp_interrupt_handler_dispatch_unchecked() as an alternative to
bsp_interrupt_handler_dispatch(). It may be used if the caller can ensure that
the vector number is valid.
