Make the memory allocations in ambapp_scan() customizable via the new struct
ambapp_context parameter which generalizes the memory copy handler.
Directly initialize the memory in the start sequence defined by start.S
instead of using a system initialization handler. This avoids using the
global variable rdb_start which used a memory location which was shared
with _ERC32_MEC_Timer_Control_Mirror. This change makes it possible to
use _Memory_Allocate() even before the system initialization is started.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Initialize the stacks for all processors in one place. Do not rely on
Per_CPU_Control::interrupt_stack_high and directly use the statically
allocated interrupt stack area.
Initialize the stacks in start.S in one place and identical to
_CPU_Context_Initialize().
Remove the support to load the data section and rely on the boot loader. The
code is an artifact from the old erc32 days, when we would boot and execute
from ROM and the .data had to be copied over to RAM. With leon1/2/3, this is
not used anymore as a boot loader is made from the RAM image using a custom
tool (mkprom).
In SMP configurations, this support was also broken since LEON3_Boot_Cpu
(in the data section due to the -1 initialization value) was used quite
early in the start sequence.
If the data copy is really necessary, then an application can still add this
step as a very early system initialization step, since boot_card() and the
system initialization loop does not use initialized read-write data (only
read-only and BSS data). However, the SMP startup would still not work in this
case. A boot loader is a better place to load the sections.
The a72 BSPs are identical to the a53 BSPs just changing a53 to a72.
Update #4202.
Also updated licenses.
Closes #4400
Updates #3899
Currently, the AArch64 BSPs have a hard time running on real hardware
without building the toolchain and the bsps with -mstrict-align in
multiple places. Configuring the MMU on these chips allows for unaligned
memory accesses for non-device memory which avoids requiring strict
alignment in the toolchain and in the BSPs themselves.
In writing this driver, it was found that the synchronous exception
handling code needed to be rewritten since it relied on clearing SCTLR_EL1 to
avoid thread stack misalignments in RTEMS_DEBUG mode. This is now
avoided by exactly preserving thread mode stack and flags and the new
implementation is compatible with the draft information provided on the
mailing list covering the Exception Management API.
Ensure that cache functions are flagged as usable by the generic cache
implementation code.
This fixes a bug where addresses were not being aligned correctly.
Addresses used in cache functions are now aligned consistently using
RTEMS_ALIGN_DOWN.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
Closes #4r37.
Closes #4438.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _CPU_Context_switch() to avoid generation of
dead code in _Thread_Start_multitasking() if RTEMS was built with SMP
support enabled.
The EDMA is intialized so make sure the the clock is initialized too.
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Update #4180
Update #4406.
Add a parameter to _TOD_Validate() to disable the validation of the
ticks member.
There are two reasons for this change. Firstly, in
rtems_task_wake_when() was a double check for time_buffer == NULL (one
in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the
ticks member is ignored by rtems_task_wake_when(). This was done with a
write of zero to the ticks member and thus a modification of the
user-provided structure. Now the structure is no longer modified.
Using a mask parameter is quite efficient. You just have to load an
immediate value and there are no additional branches in _TOD_Validate().
Close #4406.
This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
This patch adds asserts to fix coverity defects
1) CID 1474437 (Out-of-bounds access)
2) CID 1474436 (Out-of-bounds access)
From manual inspection, out of bounds access cannot occur due to
bounds checking but coverity fails to detect the checks.
We are adding asserts as a secondary check.
Update #3866.
Change the ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX value to be in line
with the workspace entry in ARMV7_CP15_START_DEFAULT_SECTIONS.
Close #4395.
When the PowerPC shared console baud rate starts at anything other than
9600 the termios code will set it to 9600 at the first open.
The "powerpc/shared/console" code has the start-up console value fixed
at 9600 baud. This changes the hard-wired constant "9600" in the code
to the configuration setting "BSP_CONSOLE_BAUD" and adds configuration
support in both the "waf" and the legacy configuration systems.
Note that the VME BSPs beatnik, mvme3100, and mve5100 can be improved
by adding a "mvmexxxx" BSP family. This configuration change, as well
as future configuration changes, could then be made in a "grp.yml" file.
Uses configured millisecond per ticks
Refactored the i2c driver to parse register values from the device
tree rather than hardcoding them. But still the clocks have to
initialized manually.
Set the Main Stack Pointer (MSP) to the ISR stack area end just in case
we run using the Process Stack Pointer (PSP). This helps if
applications are started by a boot loader.
This now uses rtems_clock_get_uptime_nanoseconds
to calculate the uptime ticks in milliseconds.
Constantly reinitializing the Cadence UART on every character output
causes data corruption/loss on some ZynqMP hardware. Only initialize
the UART once for early output and give it a kick on startup.
enabled/disabled
CID 1399752: Unused value in disp_hcms29xx_update_task().
Closes #4342
Update #3850
Update #4372
Update #4372
Closes #4321
Updates #4321
- Fixes failure of test smpclock01
The following files have been ported
1) ti_pinmux.c
2) ti_pinmux.h
3) am335x_scm_padconf.c
4) am335x_scm_padconf.h
Update #3784
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
This patch imports the beagle pinmux driver from FreeBSD into
RTEMS. Previously this driver was placed in RTEMS-libBSD but
this caused double initialization of few pins once during RTEMS
initialization and second time during libBSD initialization.
The following patches port the driver from FreeBSD to RTEMS and
will remove the driver from RTEMS-libBSD.
RTEMS Ticket Update: #3784
FreeBSD head: ca12b7e9534b10af022fed60c043984dbaf4003d
The following files have been imported from FreeBSD:
1) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
2) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
3) freebsd/sys/arm/ti/ti_pinmux.h
4) freebsd/sys/arm/ti/ti_pinmux.c
This patch extends the RTEMS OFW API by adding
rtems_ofw_find_device_by_compat
This function checks if a node has the expected compatible
property.
