CID 1399752: Unused value in disp_hcms29xx_update_task().
Closes #4342
Update #3850
Update #4372
Update #4372
Closes #4321
Updates #4321
- Fixes failure of test smpclock01
The following files have been ported
1) ti_pinmux.c
2) ti_pinmux.h
3) am335x_scm_padconf.c
4) am335x_scm_padconf.h
Update #3784
Detects the SOC type using FDT and also replaces the ti_cpuid.h
header in FreeBSD with custom one.
This patch imports the beagle pinmux driver from FreeBSD into
RTEMS. Previously this driver was placed in RTEMS-libBSD but
this caused double initialization of few pins once during RTEMS
initialization and second time during libBSD initialization.
The following patches port the driver from FreeBSD to RTEMS and
will remove the driver from RTEMS-libBSD.
RTEMS Ticket Update: #3784
FreeBSD head: ca12b7e9534b10af022fed60c043984dbaf4003d
The following files have been imported from FreeBSD:
1) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.h
2) freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
3) freebsd/sys/arm/ti/ti_pinmux.h
4) freebsd/sys/arm/ti/ti_pinmux.c
This patch extends the RTEMS OFW API by adding
rtems_ofw_find_device_by_compat
This function checks if a node has the expected compatible
property.
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
Not used by the driver itself, but shuold be correct if used by
application.
Allows user to set SpaceWire run clock divisor for an individual port.
Without this smp05 and smpthreadlife01 tests may fail
depending on how the boot loader initialized the GPTIMER.
Before the time counter stopped counting when reaching
zero, but tests could work since it could take 2^32 us
before stopping.
The timer driver will potentially overwrite this, but it
happens later due to the initialization order having
RTEMS_SYSINIT_CPU_COUNTER very early.
Moves drvmgr_drivers[] from amba.c to a separate file in order
to avoid the dependecy on APBUART/GPTIMER drivers. This has
an effect when user configured not to use timer or uart
in their project.
The descriptor table size is equal to its alignment and set when
configuring the HW IP through VHDL generics. This SW patch simply
probes the HW how large the RX/TX descriptor tables are and adjusts
accordingly.
The number of descriptors actual used are controlled by other
settings (rxDescs and txDescs) controlled by the user.
Close #4324.
Update #4324.
The new GRCAN_FD IP supports CAN FD standard and is mostly backwards
compatible with GRCAN SW interface. The GRCAN driver have been extended
to support the GRCANFD IP using the same driver.
Additional functions have been added that uses a new CAN FD frame
format and read/write/baud-rate functions that supports both GRCANFD
and GRCAN. To keep the SW API fully backwards compatible with GRCAN,
the old functions remain.
Update #4324.
Update #4324.
Close #4323.
Update #4323.
Reimplemented the baud-rate algorithm from scratch to cope with
GRCAN, GRCANFD and OC_CAN devices.
Update #4323.
When the DMA table has been allocated dynamically, the IOCTL_SET_PACKETSIZE
will trigger an issue where pDev->rx and pDev->tx are not updated with
the new DMA tables base address. Instead the old pointers are used.
There is no point in reallocting the DMA tables because there is no
configuration option to it. Therefore the DMA tables allocation is
moved to a separate function never called from SET_PACKETSIZE.
This is enables the updated codec for GR740 and is backwards compatible
with all other versions of the IP.
Closes #4320
Updates #4320
CID 1437613: Unused value in grcan_set_filter().
This fix was recommended by Daniel Hellstrom (daniel@gaisler.com).
Closes #4301
CID 1399773: Unsigned compared against 0 in brm_write().
Closes #4295
CID 1399768: Unsigned compared against 0 in satcan_ioctl().
Closes #4294
CID 1437630: Unchecked return value from library in gr_cpci_gr740_init1().
Closes #4290
CID 1399785: Unchecked return value from library in gr_tmtc_1553_init1().
Closes #4289
CID 1399783: Unchecked return value from library in gr701_init1().
Closes #4288
CID 1399780: Unchecked return value from library in gr_rasta_adcdac_init1().
Closes #4287
CID 1399771: Unchecked return value from library in gr_rasta_tmtc_init1().
Closes #4286
CID 1399767: Unchecked return value error from library in gr_cpci_leon4_n2x_init1().
Closes #4285
CID 1399763: Unchecked return value from library in gr_rasta_io_init1().
Closes #4284
CID 1399760: Unchecked return value from library in gr_rasta_spw_router_init1().
Closes #4283
CID 1399761: Missing break in switch in process_dma().
CID 1399765: Missing break in switch in process_dma().
CID 1399766: Missing break in switch in process_dma().
CID 1399777: Missing break in switch in process_dma().
Closes #4277
CID 1399781: Unchecked return value in grspw_device_init().
Closes #4259
