path: root/bsps (follow)
* bsps/riscv: Fix multiple definitionSebastian Huber2020-04-101-2/+0
* bsp/raspberrypi: Fix build warnings.G S Niteesh Babu2020-04-102-1/+5
| | | | | | 1) _Memory_Initialize makes pointer from integer without a cast. 2) printf format error, expects %u but %lu provided.
* lpc23xx_tli800-testsuite.tcfg: Add psxaoi03 and psxsignal07Joel Sherrill2020-04-071-0/+2
| | | | Updates #3938.
* mcf52235-testsuite.tcfg: Add sp16Joel Sherrill2020-04-071-0/+1
| | | | Updates #3938.
* lpc1768_mbed-testsuite.tcfg: Add psxaoi03 and psxsignal07Joel Sherrill2020-04-071-0/+2
| | | | Updates #3938.
* lpc2362-testsuite.tcfg: Add psxaoi03 and psxsignal07Joel Sherrill2020-04-071-0/+2
| | | | Updates #3938.
* lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add psxsignal07Joel Sherrill2020-04-071-0/+1
| | | | Updates #3938.
* lm4f120-testsuite.tcfg: Add psxsignal07Joel Sherrill2020-04-071-0/+1
| | | | Updates #3938.
* tests: Exclude record02 for some BSPsSebastian Huber2020-04-0613-0/+13
| | | | Update #3938.
* sparc64: update linkcmds with missing sections for TLSGedare Bloom2020-04-061-52/+22
| | | | Closes #3936.
* bsp/raspberry: Add a bsp_fdt_map_intr().Christian Mauderer2020-04-042-0/+27
| | | | Fixes #3903
* bsp/shared/clock: Reset Clock_driver_isrs to correct valueJan Sommer2020-04-031-1/+1
| | | | | | | CLOCK_DRIVER_ISRS_PER_TICK is the configuration define, CLOCK_DRIVER_ISRS_PER_TICK_VALUE is the actual value of ISRS per clock tick, therefore use this one to reset the Clock_driver_isrs after each tick.
* arm: ARMv7-M statically initialized vector tableSebastian Huber2020-04-033-36/+63
| | | | | | | Statically initialize the ARMv7-M vector table to allow a placement in ROM with read-only MPU settings. Change licence to BSD-2-Clause in some files.
* bsp/qoriq: Fix off by one error in clock initSebastian Huber2020-04-021-1/+1
| | | | Close #3921.
* gdbarmsim: RemoveJoel Sherrill2020-03-1924-1451/+0
| | | | Closes #3611.
* bsps: Remove legacy interrupt API from defaultSebastian Huber2020-03-131-1/+0
| | | | | This fixes linker issues on the powerpc/virtex4 and powerpc/virtex5 BSPs.
* mrm332-testsuite.tcfg: Add dl01Joel Sherrill2020-03-121-0/+1
* rtl22xx-testsuite.tcfg: Add dl10 and ttest01Joel Sherrill2020-03-121-0/+2
* lpc23xx_tli800-testsuite.tcfg: Add ttest01Joel Sherrill2020-03-121-0/+1
* lpc2362-testsuite.tcfg: Add ttest01Joel Sherrill2020-03-121-0/+1
* lm3s3749-testsuite.tcfg: Add ttest01Joel Sherrill2020-03-121-0/+1
* imfs: Replace devfs with an IMFS specializationSebastian Huber2020-03-093-8/+0
| | | | | | | | | | | | | | | | Add a simplified path evaluation function IMFS_eval_path_devfs() for a device only IMFS configuration. The code size can be further reduced by the application if it disables the support for legacy IO drivers via: #define CONFIGURE_IMFS_DISABLE_MKNOD #define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE Obsolete CONFIGURE_MAXIMUM_DEVICES. Remove BSP_MAXIMUM_DEVICES. Update #3894. Update #3898.
* psim: Rework device tree so devices do not conflict with 256MB RAMJoel Sherrill2020-03-054-15/+12
| | | | updates #3849.
* bsp/pc386: Fix interrupt enable to make debug option work againJan Sommer2020-02-271-1/+1
* bsp/mpc5643l_*: Exclude some testsSebastian Huber2020-02-272-0/+4
| | | | These tests do not fit into the available memory.
* bsps/clock: Use _SMP_Get_processor_maximum()Sebastian Huber2020-02-251-1/+1
| | | | | | | Use a specific test to enable the fast idle mode instead of using the rtems_configuration_is_smp_enabled() workaround. Update #3876.
* bsps/arm: Initialize priorities of PPIsSebastian Huber2020-02-241-0/+6
| | | | | | At least on GICv1 the interrupts 0 up to including 31 are so called Peripheral Private Interrupts (PPIs). We have to initialize the priority of the PPIs on secondary processors.
* drvmgr: Fix determination of prefix in grlib uart driverDennis Pfau2020-02-201-1/+1
| | | | | drvmgr_get_dev_prefix returns 0 if a prefix was found. Therefore the if condition needs to check for 0, i.e. DRVMGR_OK.
* bsp/raspberrypi: Mini UART driverG S Niteesh2020-02-162-9/+110
| | | | | | | | This patch adds driver for Mini UART present in Raspberry Pi 3 and above, this UART is currently used as the primary UART in these models. The Mini UART is similar to ns16550, this driver is built upon libchip/ns16550.
* libchip/ns16550: Allow user calculate baud divisorG S Niteesh2020-02-162-2/+9
| | | | | | | | This patch will allow the user to pass a function to calculate the baud divisor. This will allow for more flexibility, since for some BSPs like raspberrypi, the calculation of baud divisor is different from what is in the current driver.
* score: Statically allocate idle/MPCI stacksSebastian Huber2020-02-125-3/+23
| | | | | | | Place idle and MPCI stacks into extra linker sections. This can be optionally used by applications to control the placement of the stacks. Update #3835.
* arm/xilinx-zynq: Split console driver filesSebastian Huber2020-02-124-185/+242
| | | | | This avoids to pull in via printk() the Termios support which pulls in the file system support. This fixes a spconfig02 test failure.
* bsp/imx: Parse fdt pinctrl values and setup iomuxChristian Mauderer2020-02-111-0/+44
| | | | Update #3869.
* bsp/imx: Support imx6ul iomux.Christian Mauderer2020-02-111-0/+4
| | | | Update #3869.
* bsp/imx: Allow gapless SPI transfers.Christian Mauderer2020-02-111-1/+6
| | | | | | This uses the tx-threshold to reduce gaps in SPI transmissions. Update #3869.
* bsp/imx: Use muxed mode for serials.Christian Mauderer2020-02-111-0/+1
| | | | Update #3869.
* bsp/imx: Increase device memory areaSebastian Huber2020-02-111-1/+1
| | | | | | The new area is used by the i.MX 6UltraLite for example. Update #3869.
* bsp/imx: Allow GIC in different device tree node.Christian Mauderer2020-02-111-0/+3
| | | | Update #3869.
* bsp/imx: Avoid hard-coded GIC base addressSebastian Huber2020-02-112-2/+15
| | | | Update #3869.
* config: Add CONFIGURE_DIRTY_MEMORYSebastian Huber2020-02-061-13/+0
| | | | | | | Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY configuration option. Update #3843.
* Use RTEMS_SYSINIT_ORDER_LAST_BUT_5Sebastian Huber2020-02-0414-14/+14
| | | | | | | | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838.
* bsps: Rework work area initializationSebastian Huber2020-02-0413-197/+311
| | | | | | | | | | | | | | | | | | | | The work area initialization was done by the BSP through bsp_work_area_initialize(). This approach predated the system initialization through the system initialization linker set. The workspace and C program heap were unconditionally initialized. The aim is to support RTEMS application configurations which do not need the workspace and C program heap. In these configurations, the workspace and C prgram heap should not get initialized. Change all bsp_work_area_initialize() to implement _Memory_Get() instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and malloc() heap initialization into separate system initialization steps. This makes it also easier to test the individual initialization steps. This change adds a dependency to _Heap_Extend() to all BSPs. This dependency will be removed in a follow up change. Update #3838.
* bsps: Remove uses of BSP_GET_WORK_AREA_DEBUGSebastian Huber2020-02-043-65/+0
| | | | | | | | | The code covered by BSP_GET_WORK_AREA_DEBUG was basically dead code since there was no normal way to activate it (e.g. via a BSP configuration option). A follow up patch will bring back this feature through a CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION configuration option. Update #3838.
* bsps: Add RTEMS_SYSINIT_BSP_EARLYSebastian Huber2020-02-045-38/+48
| | | | | | | Add new BSP system initialization step for work to be performed before the work areas are initialized. Update #3838.
* bsps: Add RamEnd to linker command filesSebastian Huber2020-02-0456-1/+56
| | | | Update #3838.
* bsps/arm/shared: Add GICv3 implementationKinsey Moore2020-01-174-9/+427
| | | | | | | | | This adds support for the GICv3 interrupt controller along with the redistributor to control SGIs and PPIs which wasn't present in GICv2 implementations. GICv3 implementations only optionally support memory-mapped GICC interface interaction and require system register access be implemented, so the GICC interface is accessed only through system registers.
* bsp/raspberrypi: Updated the console API.G S Niteesh2020-01-079-400/+196
| | | | | | Replaces the legacy termios API with new termios API (#3034) Replaces the custom PL011 serial driver with RTEMS arm-pl011. Update #3034
* bsp/raspberrypi: Enable FDT support.G S Niteesh2020-01-071-0/+4
| | | | This commit adds FDT support to the BSP.
* bsp/raspberrypi: Fix size of work area.Christian Mauderer2020-01-074-185/+80
| | | | | | | | | | The BSP tried to get the size of the SDRAM based on the revision code. Unfortunately the code had some bugs so that the default size has been used. Beneath that the MMU table hasn't been adapted. This patch queries the SDRAM size via a special VC Mailbox call instead. For the MMU adaption a simmilar method to the one in the imx BSP is used.
* bsps/arm: Define index of the workspace entry.Christian Mauderer2020-01-072-5/+6
| | | | | | The imx BSP contained a hack to change the workspace entry of the MMU table. This makes the used define visible for other BSPs too so that the same hack can be used for example in raspberry pi too.
