path: root/bsps (follow)
* bsps: Rework cache manager implementationSebastian Huber2018-01-3122-44/+4533
| | | | | | | | | | | | | | | | | | The previous cache manager support used a single souce file (cache_manager.c) which included an implementation header (cache_.h). This required the use of specialized include paths to find the right header file. Change this to include a generic implementation header (cacheimpl.h) in specialized source files. Use the following directories and files: * bsps/shared/cache * bsps/@RTEMS_CPU@/shared/cache * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILY/start/cache.c Update #3285.
* bsps: Move network define to source filesSebastian Huber2018-01-311-0/+5
| | | | | Define __INSIDE_RTEMS_BSD_TCPIP_STACK__ in the network interface driver source files to avoid some build system magic.
* Remove make preinstallChris Johns2018-01-251217-0/+381032
