* | bsps: Include missing header files | Sebastian Huber | 2018-11-09 | 1 | -0/+2 |
| | | | | Update #3598. | ||||
* | bsp/beatnik: Fix warnings | Sebastian Huber | 2018-11-09 | 7 | -103/+94 |
* | bsp/realview-pbx-a9: Update headers.am | Sebastian Huber | 2018-11-08 | 1 | -0/+1 |
* | score: Remove _ISR_Dispatch() | Sebastian Huber | 2018-11-08 | 1 | -1/+1 |
| | | | | | | | | This function was only used on some m68k variants. On these m68k variants there is no need to use a global symbol. Use a local label instead. Remove _ISR_Dispatch() from the architecture-independent layer. | ||||
* | score: Rename interrupt stack symbols | Sebastian Huber | 2018-11-08 | 47 | -67/+67 |
| | | | | | | | | | | | | | Rename * _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin, * _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and * _Configuration_Interrupt_stack_size in _ISR_Stack_size. Move definitions to <rtems/score/isr.h>. The new names are considerable shorter and in the right namespace. Update #3459. | ||||
* | bsp/realview-pbx-a9: Fix printk() support | Sebastian Huber | 2018-11-07 | 3 | -33/+84 |
| | | | | | Avoid dependencies on the Termios support in case only printk() is used by the application. | ||||
* | altera-cyclone-v: tweak ingroup | Gedare Bloom | 2018-11-05 | 1 | -1/+1 |
* | arm/altera-cyclone-v: update doxygen (GCI 2018) | ABR290B | 2018-11-05 | 1 | -0/+17 |
* | bsp/imx: Adjust workspace according to device tree | Sebastian Huber | 2018-10-24 | 1 | -3/+50 |
* | mpc8260ads/start/bspstart.c: Fix unused function warning | Joel Sherrill | 2018-10-18 | 1 | -0/+6 |
* | qemuppc/start/cmain.c: Cast args to memcpy and bzero to fix warnings | Joel Sherrill | 2018-10-18 | 1 | -5/+14 |
* | gen5200/mscan/mscan.c: Fix printf() format warning | Joel Sherrill | 2018-10-18 | 1 | -1/+1 |
* | or1k/shared/cache/cache.c: Remove unused methods | Joel Sherrill | 2018-10-18 | 1 | -35/+0 |
* | gdbarmsim/include/bsp.h: Include <sys/stat.h> to fix warning | Joel Sherrill | 2018-10-18 | 1 | -0/+2 |
* | bsp/atsam: Add const qualifier to AES_SetInput() | Sebastian Huber | 2018-10-18 | 2 | -2/+2 |
* | serial/ns16550: Fix precision clock synthesizer | Sebastian Huber | 2018-10-17 | 1 | -15/+16 |
| | | | | | | | The precision clock synthesizer support broke the driver on the QorIQ P1020. On this device the Alternate Function Register is accessed with DLAB == 1 instead of the FIFO Control Register (FCR). Restructure the code to account for this. | ||||
* | bsp/imx7: Add getchark() support | Sebastian Huber | 2018-10-17 | 1 | -16/+20 |
* | bsps/arm: Recognize .tm_clone_table input section | Sebastian Huber | 2018-10-15 | 1 | -0/+3 |
* | bsp/tms570: Simple fix to resolve macro redefinitions. | Pavel Pisa | 2018-10-15 | 1 | -34/+46 |
| | | | | closes #3347 | ||||
* | leon: do not use -mfix-{device} with Clang | Daniel Hellstrom | 2018-10-09 | 2 | -2/+28 |
| | | | | | | | | | Clang do not support -mfix-gr712rc, -mfix-ut700 and -mfix-ut699. Therefore we adjust the CPU_CFLAGS to remove these when compiling with Clang. Instead use GR712RC: -mcpu=gr712rc GR740: -mcpu=gr740 UT699/UT700: Not currently supported by clang, use LEON3 BSP. | ||||
* | leon, spwtdp: Initial driver commit | Javier Jalle | 2018-10-09 | 4 | -0/+1344 |
* | bsps/arm: Fix ctor/dtor invocation order | Sebastian Huber | 2018-10-09 | 1 | -31/+4 |
| | | | | Remove obsolete .ctor and .dtor output sections. | ||||
* | bsp/atsam: Use internal SRAM for stack area | Sebastian Huber | 2018-10-04 | 1 | -1/+1 |
* | Use rtems_task_exit() | Sebastian Huber | 2018-10-02 | 6 | -7/+7 |
| | | | | | Update #3530. Update #3533. | ||||
* | bsp/atsam: Use binary semaphore for I2C | Sebastian Huber | 2018-10-01 | 2 | -23/+21 |
| | | | | | | | Remove superfluous sleep before each I2C transfer. Reset I2C module after transfer timeouts. Update #3534. | ||||
* | bsp/atsam: Use binary semaphore for SPI | Sebastian Huber | 2018-10-01 | 1 | -10/+7 |
* | bsp/imx: Add imx_ccm_sdhci_hz() | Sebastian Huber | 2018-09-27 | 1 | -0/+5 |
| | | | | Update #3525. | ||||
* | leon: remove warning missing string.h | Daniel Hellstrom | 2018-09-20 | 1 | -0/+1 |
* | leon, grspw_pkt: support CCSDS/ISO16 data CRC | Martin Aberg | 2018-09-20 | 2 | -2/+17 |
| | | | | | | When the CCSDS/CCITT CRC-16 and 16-bit ISO-checksum logic is available in GRSPW2, the DCRCT field is used to determine how to generate the CRC/checksum code. grspw_hw_sup has been extended with the field ccsds_crc | ||||
* | leon,grspw_pkt: protect TX descriptor from bad input (hdrlen) | Daniel Hellstrom | 2018-09-20 | 1 | -1/+2 |
* | leon, l2cache: workaround for scrubber | Martin Aberg | 2018-09-20 | 1 | -0/+8 |
| | | | | | | | | | | This is a workaround for a L2CACHE scrubber corner case described in GR740 User's Manual, Version 1.10, section 43.2.30. The issue affects some version of the L2CACHE. However, since the performance impact of the workaround is marginal, special device probing logic has been avoided. In addition, this update does not affect users who enable the L2CACHE and scrubber before RTEMS is started. | ||||
* | leon: substitute printf with printk in driver init | Daniel Hellstrom | 2018-09-20 | 14 | -60/+60 |
* | leon3, ckinit: avoid unsued code warnings when drvmgr is enabled | Daniel Hellstrom | 2018-09-20 | 1 | -3/+6 |
* | leon3: fix warning when SMP is enabled | Daniel Hellstrom | 2018-09-20 | 1 | -0/+1 |
* | bsp/leon3: Fix typo which breaks the CPU counter | Sebastian Huber | 2018-09-20 | 1 | -1/+1 |
| | | | | Update #3456. | ||||
* | riscv: Allow platforms with no PLIC to proceed | Hesham Almatary | 2018-09-17 | 1 | -0/+5 |
| | | | | Spike simulator and QEMU's spike_v1.10 don't have a PLIC | ||||
* | bsp/tqm8xx: Remove unused files | Sebastian Huber | 2018-09-17 | 2 | -1280/+0 |
| | | | | Close #3513. | ||||
* | bsp/tqm8xx: Fix polled vs. interrupt output | Sebastian Huber | 2018-09-17 | 2 | -57/+81 |
| | | | | Update #3513. | ||||
* | bsp/tqm8xx: Convert console to new Termios API | Sebastian Huber | 2018-09-17 | 1 | -259/+99 |
* | bsp/tqm8xx: Move DMA support to channel descriptor | Sebastian Huber | 2018-09-17 | 1 | -164/+170 |
* | bsp/tqm8xx: Move rxBuf to channel descriptor | Sebastian Huber | 2018-09-17 | 1 | -58/+50 |
* | bsp/tqm8xx: Use IRQ extensions API | Sebastian Huber | 2018-09-17 | 1 | -26/+12 |
* | bsp/tqm8xx: Clear sbss section | Sebastian Huber | 2018-09-17 | 1 | -4/+7 |
* | bsp/tqm8xx: Use custom string to uint32_t | Sebastian Huber | 2018-09-17 | 1 | -2/+19 |
| | | | | Avoid C locale support which is not available at this stage. | ||||
* | network: Use kernel/user space header files | Sebastian Huber | 2018-09-10 | 58 | -74/+58 |
| | | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375. | ||||
* | bsp/qoriq: Add struct qoriq to allow forward decls | Sebastian Huber | 2018-09-06 | 1 | -2/+2 |
* | bsps/powerpc: Simplify ppc_exc_initialize() | Sebastian Huber | 2018-09-06 | 21 | -154/+22 |
| | | | | | | | Remove parameters from ppc_exc_initialize() since all BSPs passed the same values. Update #3459. | ||||
* | bsp/mpc55xxevb: Fix format warning | Sebastian Huber | 2018-09-05 | 1 | -1/+3 |
| | | | | Close #3504. | ||||
* | libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY | Sebastian Huber | 2018-09-05 | 1 | -1/+1 |
| | | | | | | | Drop unused and deprecated functions from the ATA_DRIVER_TABLE_ENTRY. Update #3358. Close #3510. | ||||
* | bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN | Sebastian Huber | 2018-09-03 | 12 | -39/+10 |
| | | | | | | | Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt stacks are now allocated by the linker. Update #3459. |
