Update #4267.
Change license to BSD-2-Clause according to file histories and
re-licensing agreement.
Update #3899.
This adds a bsp_reset implementation based on the ARM PSCI
specification often present in ARMv8 systems.
The cache of the fdt blob is flushed after copy. Therefore it should be
aligned.
Replace the BSP_DIRTY_MEMORY BSP option with a CONFIGURE_DIRTY_MEMORY
configuration option.
Update #3843.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Directly use the CPU port API in boot_card() to allow tracing of the
higher level interrupt disable/enable routines, e.g.
_ISR_Local_disable() and _ISR_Local_enable(). Currently, there is no
configuration option to enable this. Below is a patch. It may be used
to investigate some nasty low level bugs in the system.
Update #3665.
diff --git a/cpukit/include/rtems/score/isrlevel.h b/cpukit/include/rtems/score/isrlevel.h
index c42451d010..46d361ddc2 100644
--- a/cpukit/include/rtems/score/isrlevel.h
+++ b/cpukit/include/rtems/score/isrlevel.h
@@ -40,6 +40,10 @@ extern "C" {
typedef uint32_t ISR_Level;
+uint32_t rtems_record_interrupt_disable( void );
+void rtems_record_interrupt_enable( uint32_t level );
* @brief Disables interrupts on this processor.
@@ -56,8 +60,7 @@ typedef uint32_t ISR_Level;
#define _ISR_Local_disable( _level ) \
do { \
- _CPU_ISR_Disable( _level ); \
- RTEMS_COMPILER_MEMORY_BARRIER(); \
+ _level = rtems_record_interrupt_disable(); \
} while (0)
@@ -72,10 +75,7 @@ typedef uint32_t ISR_Level;
* _ISR_Local_disable().
#define _ISR_Local_enable( _level ) \
- do { \
- _CPU_ISR_Enable( _level ); \
- } while (0)
+ rtems_record_interrupt_enable( _level )
* @brief Temporarily enables interrupts on this processor.
@@ -98,9 +98,8 @@ typedef uint32_t ISR_Level;
#define _ISR_Local_flash( _level ) \
do { \
- _CPU_ISR_Flash( _level ); \
+ rtems_record_interrupt_enable( _level ); \
} while (0)
replace.
searching and sorting.
Update #3706.
Remove the BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN hack. The interrupt
stacks are now allocated by the linker.
Update #3459.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
