* | bsps/powerpc: Remove SPE enabled variants | Sebastian Huber | 2020-07-05 | 1 | -2/+1 |
| | | | | | | The PowerPC SPE support was removed from GCC. Update #3951. | ||||
* | testsuite: Make the OPERATION_COUNT a test configuration parameter. | Chris Johns | 2019-03-07 | 5 | -5/+5 |
| | | | | | - Add a small memory test config file. - Update the small memory PowerPC BSPs to use the new test config. | ||||
* | qoriq: Move -Dxxx to configure.ac | Joel Sherrill | 2018-05-18 | 3 | -6/+3 |
| | | | | Updates #3425. | ||||
* | bsps: Move make/custom/* files to bsps | Sebastian Huber | 2018-04-23 | 11 | -0/+84 |
Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285. |
