Update #3706.
Updates #3687
The size of the sample executables without this option were:
257876 3416 148812 410104 641f8 ./capture.exe
126956 2428 145836 275220 43314 ./base_sp.exe
330400 4600 146916 481916 75a7c ./cdtest.exe
1092476 23588 153684 1269748 135ff4 ./cxx_iostream.exe
654892 6056 158868 819816 c8268 ./fileio.exe
159260 2812 145956 308028 4b33c ./hello.exe
339392 7344 152824 499560 79f68 ./loopback.exe
106388 2276 142644 251308 3d5ac ./minimum.exe
156348 2960 145980 305288 4a888 ./nsecs.exe
201020 3204 146592 350816 55a60 ./paranoia.exe
547684 13548 175556 736788 b3e14 ./pppd.exe
130108 2468 145872 278448 43fb0 ./ticker.exe
129740 2436 149696 281872 44d10 ./unlimited.exe
The size of the sample executables with this option were:
246508 2856 147036 396400 60c70 ./cxx_iostream.exe
641752 6016 158548 806316 c4dac ./fileio.exe
148264 2800 145916 296980 48814 ./hello.exe
319252 7340 152756 479348 75074 ./loopback.exe
100396 2288 142556 245240 3bdf8 ./minimum.exe
148200 2932 145892 297024 48840 ./nsecs.exe
190520 3192 146552 340264 53128 ./paranoia.exe
531300 13544 175480 720324 afdc4 ./pppd.exe
124008 2472 145788 272268 4278c ./ticker.exe
127848 2432 149660 279940 44584 ./unlimited.exe
121272 2432 145752 269456 41c90 ./base_sp.exe
241104 3412 148768 393284 60044 ./capture.exe
245424 2936 146876 395236 607e4 ./cdtest.exe
Closes #2565
Move start.o to separate file.
Update #3459.
Add and use <machine/rtems-bsd-kernel-space.h> and
<machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command
line defines and defines scattered throught the code base.
Simplify cpukit/libnetworking/Makefile.am.
Update #3375.
Remove parameters from ppc_exc_initialize() since all BSPs passed the
same values.
Update #3459.
Statically initialize the interrupt stack area
(_Configuration_Interrupt_stack_area_begin,
_Configuration_Interrupt_stack_area_end, and
_Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the
interrupt stack area in a special section ".rtemsstack.interrupt". Let
BSPs define the optimal placement of this section in their linker
command files (e.g. in a fast on-chip memory).
This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and
CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the
low level initialization code has all information available via global
symbols.
This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define
superfluous, since the interrupt stacks are allocated by confdefs.h for
all architectures. There is no need for BSP-specific linker command
file magic (except the section placement), see previous ARM linker
command file as a bad example.
Remove _CPU_Install_interrupt_stack(). Initialize the hardware
interrupt stack in _CPU_Initialize() if necessary (e.g.
m68k_install_interrupt_stack()).
The optional _CPU_Interrupt_stack_setup() is still useful to customize
the registration of the interrupt stack area in the per-CPU information.
The initialization stack can reuse the interrupt stack, since
* interrupts are disabled during the sequential system initialization,
and
* the boot_card() function does not return.
This stack resuse saves memory.
Changes per architecture:
arm:
* Mostly replace the linker symbol based configuration of stacks with
the standard <rtems/confdefs.h> configuration via
CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND
mode stack is still defined via linker symbols. These modes are
rarely used in applications and the default values provided by the
BSP should be sufficient in most cases.
* Remove the bsp_processor_count linker symbol hack used for the SMP
support. This is possible since the interrupt stack area is now
allocated by the linker and not allocated from the heap. This makes
some configure.ac stuff obsolete. Remove the now superfluous BSP
variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp.
bfin:
* Remove unused magic linker command file allocation of initialization
stack. Maybe a previous linker command file copy and paste problem?
In the start.S the initialization stack is set to a hard coded value.
lm32, m32c, mips, nios2, riscv, sh, v850:
* Remove magic linker command file allocation of initialization stack.
Reuse interrupt stack for initialization stack.
m68k:
powerpc:
* Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt
stack on BSPs using the shared linkcmds.base (replacement for
REGION_RWEXTRA).
sparc:
* Remove the hard coded initialization stack. Use the interrupt stack
for the initialization stack on the boot processor. This saves
16KiB of RAM.
Update #3459.
Use a dedicated memory region or place it between the BSS and workspace.
Update #3459.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Updates #3425.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
