path: root/bsps/m68k/mcf5235 (follow)
* bsp_specs: Delete last remnants of these.Joel Sherrill2021-11-291-0/+0
| | | | Updates #3937.
* build: Remove old build systemSebastian Huber2021-09-211-10/+0
| | | | | Close #3250. Close #4081.
* bsps: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-023-0/+12
| | | | Update #3866.
* bsps: Remove networking driversVijay Kumar Banerjee2021-04-071-879/+0
| | | | Update #3850
* bsps: Replace bsp_specs with an empty fileSebastian Huber2021-01-281-10/+0
| | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250.
* bsps: Add RamEnd to linker command filesSebastian Huber2020-02-043-0/+3
| | | | Update #3838.
* bsps: Regenerate headers.amSebastian Huber2019-07-051-0/+4
| | | | Update #3269.
* bsps: Always build generic interrupt supportSebastian Huber2019-05-161-0/+1
| | | | | | | This makes it possible to write tests for the generic interrupt controller support. Update #3269.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-081-0/+20
| | | | Update #3706.
* m68k/mcf5235:Add per-section compilation and linking support (GCI 2018)Shashvat Jain2018-11-281-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The size of the sample executables without this option were: text data bss dec hex filename 83152 1152 11904 96208 177d0 base_sp.exe 198784 2096 14848 215728 34ab0 capture.exe 252496 2912 12912 268320 41820 cdtest.exe 861744 21888 19648 903280 dc870 cxx_iostream.exe 564768 4640 24304 593712 90f30 fileio.exe 117184 1504 12048 130736 1feb0 hello.exe 261024 6016 18688 285728 45c20 loopback.exe 67232 1008 8768 77008 12cd0 minimum.exe 106304 1632 12016 119952 1d490 nsecs.exe 191840 1904 12624 206368 32620 paranoia.exe 429824 12048 41472 483344 76010 pppd.exe 85904 1168 11936 99008 182c0 ticker.exe 86016 1120 15808 102944 19220 unlimited.exe The size of the sample executables with this option were: text data bss dec hex filename 78512 1136 11824 91472 16550 base_sp.exe 185184 2096 14800 202080 31560 capture.exe 184192 2144 12864 199200 30a20 cdtest.exe 184416 2224 13072 199712 30c20 cxx_iostream.exe 552240 4624 23984 580848 8dcf0 fileio.exe 108256 1504 12016 121776 1dbb0 hello.exe 245008 6016 18608 269632 41d40 loopback.exe 62448 1008 8688 72144 119d0 minimum.exe 100240 1616 11936 113792 1bc80 nsecs.exe 183216 1904 12592 197712 30450 paranoia.exe 417248 12048 41392 470688 72ea0 pppd.exe 81024 1168 11856 94048 16f60 ticker.exe 84208 1120 15776 101104 18af0 unlimited.exe Closes #2571
* bsps/m68k: Use interrupt stack for init stackSebastian Huber2018-11-191-0/+1
| | | | Update #3459.
* network: Use kernel/user space header filesSebastian Huber2018-09-101-1/+1
| | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
* bsps: Support .rtemsstack.* linker input sectionsSebastian Huber2018-06-273-0/+10
| | | | | | Use a dedicated memory region or place it between the BSS and workspace. Update #3459.
* Remove Clock_driver_support_shutdown_hardware()Sebastian Huber2018-06-271-8/+0
| | | | | | | | | | | | | | | | | The aim of this clock driver hook was to stop clock tick interrupts at some late point in the exit() procedure. The use of atexit() pulls in malloc() which pulls in errno. It is incompatible with the intention of the CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option. The exit() function must be called from thread context, so accompanied clock tick interrupts should cause no harm. On the contrary, someone may assume a normal operating system operation, e.g. working timeouts. Remove the Clock_driver_support_shutdown_hardware() clock driver hook. Close #3436.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-262-0/+497
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move legacy network drivers to bspsSebastian Huber2018-04-231-0/+879
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-231-0/+31
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move benchmark timer to bspsSebastian Huber2018-04-201-0/+34
* bsps: Move startup files to bspsSebastian Huber2018-04-208-0/+809
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move start files to bspsSebastian Huber2018-04-201-0/+387
* bsps: Move console drivers to bspsSebastian Huber2018-04-201-0/+745
* bsps: Move clock drivers to bspsSebastian Huber2018-04-201-0/+61
* Remove make preinstallChris Johns2018-01-253-0/+111
