path: root/bsps/m68k/gen68360 (follow)
* bsps: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-023-0/+12
| | | | Update #3866.
* bsps: Remove networking driversVijay Kumar Banerjee2021-04-071-1062/+0
| | | | Update #3850
* bsps: Replace bsp_specs with an empty fileSebastian Huber2021-01-281-9/+0
| | | | | | | This fixes an issue with the latest tool chain which adds the default linker script in the endfile specification. Update #3250.
* bsps: Add RamEnd to linker command filesSebastian Huber2020-02-043-0/+3
| | | | Update #3838.
* bsps: Regenerate headers.amSebastian Huber2019-07-051-0/+4
| | | | Update #3269.
* bsps: Always build generic interrupt supportSebastian Huber2019-05-161-0/+1
| | | | | | | This makes it possible to write tests for the generic interrupt controller support. Update #3269.
* bsps: Adjust bsp.h Doxygen groupsSebastian Huber2019-03-083-11/+15
| | | | Update #3706.
* bsps: Adjust architecture Doxygen groupsSebastian Huber2019-03-041-15/+0
| | | | | | | | | | - Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
* m68k/gen68360:Add per-section compilation and linking supportShashvat Jain2018-11-253-8/+8
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The size of the sample executables without this option were: text data bss dec hex filename 76560 1200 19504 97264 17bf0 ./base_sp.exe 191776 2160 22448 216384 34d40 ./capture.exe 243760 2976 20496 267232 413e0 ./cdtest.exe 827184 21872 26928 875984 d5dd0 ./cxx_iostream.exe 532960 4688 31904 569552 8b0d0 ./fileio.exe 97888 1472 19360 118720 1cfc0 ./hello.exe 250368 6080 26272 282720 45060 ./loopback.exe 34336 304 15056 49696 c220 ./minimum.exe 99840 1680 19616 121136 1d930 ./nsecs.exe 185936 1968 20240 208144 32d10 ./paranoia.exe 414992 12096 49072 476160 74400 ./pppd.exe 79472 1232 19536 100240 18790 ./ticker.exe 66368 1088 23120 90576 161d0 ./unlimited.exe The size of the sample executables with this option were: text data bss dec hex filename 59200 1120 19136 79456 13660 ./base_sp.exe 178912 2160 22400 203472 31ad0 ./capture.exe 163712 2112 20160 185984 2d680 ./cdtest.exe 163696 2192 20352 186240 2d780 ./cxx_iostream.exe 521344 4672 31584 557600 88220 ./fileio.exe 89600 1472 19328 110400 1af40 ./hello.exe 222384 5984 25920 254288 3e150 ./loopback.exe 33728 304 15024 49056 bfa0 ./minimum.exe 81280 1584 19248 102112 18ee0 ./nsecs.exe 164960 1872 19904 186736 2d970 ./paranoia.exe 402928 12096 48992 464016 71490 ./pppd.exe 62112 1136 19168 82416 141f0 ./ticker.exe 64864 1072 23088 89024 15bc0 ./unlimited.exe Closes #2566.
* score: Rename interrupt stack symbolsSebastian Huber2018-11-081-1/+1
| | | | | | | | | | | | | Rename * _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin, * _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and * _Configuration_Interrupt_stack_size in _ISR_Stack_size. Move definitions to <rtems/score/isr.h>. The new names are considerable shorter and in the right namespace. Update #3459.
* network: Use kernel/user space header filesSebastian Huber2018-09-101-1/+1
| | | | | | | | | | Add and use <machine/rtems-bsd-kernel-space.h> and <machine/rtems-bsd-user-space.h> similar to the libbsd to avoid command line defines and defines scattered throught the code base. Simplify cpukit/libnetworking/Makefile.am. Update #3375.
* Rework initialization and interrupt stack supportSebastian Huber2018-06-274-16/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Statically initialize the interrupt stack area (_Configuration_Interrupt_stack_area_begin, _Configuration_Interrupt_stack_area_end, and _Configuration_Interrupt_stack_size) via <rtems/confdefs.h>. Place the interrupt stack area in a special section ".rtemsstack.interrupt". Let BSPs define the optimal placement of this section in their linker command files (e.g. in a fast on-chip memory). This change makes makes the CPU_HAS_SOFTWARE_INTERRUPT_STACK and CPU_HAS_HARDWARE_INTERRUPT_STACK CPU port defines superfluous, since the low level initialization code has all information available via global symbols. This change makes the CPU_ALLOCATE_INTERRUPT_STACK CPU port define superfluous, since the interrupt stacks are allocated by confdefs.h for all architectures. There is no need for BSP-specific linker command file magic (except the section placement), see previous ARM linker command file as a bad example. Remove _CPU_Install_interrupt_stack(). Initialize the hardware interrupt stack in _CPU_Initialize() if necessary (e.g. m68k_install_interrupt_stack()). The optional _CPU_Interrupt_stack_setup() is still useful to customize the registration of the interrupt stack area in the per-CPU information. The initialization stack can reuse the interrupt stack, since * interrupts are disabled during the sequential system initialization, and * the boot_card() function does not return. This stack resuse saves memory. Changes per architecture: arm: * Mostly replace the linker symbol based configuration of stacks with the standard <rtems/confdefs.h> configuration via CONFIGURE_INTERRUPT_STACK_SIZE. The size of the FIQ, ABT and UND mode stack is still defined via linker symbols. These modes are rarely used in applications and the default values provided by the BSP should be sufficient in most cases. * Remove the bsp_processor_count linker symbol hack used for the SMP support. This is possible since the interrupt stack area is now allocated by the linker and not allocated from the heap. This makes some configure.ac stuff obsolete. Remove the now superfluous BSP variants altcycv_devkit_smp and realview_pbx_a9_qemu_smp. bfin: * Remove unused magic linker command file allocation of initialization stack. Maybe a previous linker command file copy and paste problem? In the start.S the initialization stack is set to a hard coded value. lm32, m32c, mips, nios2, riscv, sh, v850: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. m68k: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. powerpc: * Remove magic linker command file allocation of initialization stack. Reuse interrupt stack for initialization stack. * Used dedicated memory region (REGION_RTEMSSTACK) for the interrupt stack on BSPs using the shared linkcmds.base (replacement for REGION_RWEXTRA). sparc: * Remove the hard coded initialization stack. Use the interrupt stack for the initialization stack on the boot processor. This saves 16KiB of RAM. Update #3459.
* bsps: Support .rtemsstack.* linker input sectionsSebastian Huber2018-06-273-0/+9
| | | | | | Use a dedicated memory region or place it between the BSS and workspace. Update #3459.
* Remove Clock_driver_support_shutdown_hardware()Sebastian Huber2018-06-271-8/+0
| | | | | | | | | | | | | | | | | The aim of this clock driver hook was to stop clock tick interrupts at some late point in the exit() procedure. The use of atexit() pulls in malloc() which pulls in errno. It is incompatible with the intention of the CONFIGURE_DISABLE_NEWLIB_REENTRANCY configuration option. The exit() function must be called from thread context, so accompanied clock tick interrupts should cause no harm. On the contrary, someone may assume a normal operating system operation, e.g. working timeouts. Remove the Clock_driver_support_shutdown_hardware() clock driver hook. Close #3436.
* bsps: Move documentation, etc. files to bspsSebastian Huber2018-04-261-0/+299
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move legacy network drivers to bspsSebastian Huber2018-04-231-0/+1062
* bsps: Move SPI drivers to bspsSebastian Huber2018-04-232-0/+1013
* bsps: Move make/custom/* files to bspsSebastian Huber2018-04-233-0/+46
| | | | | | | | | Adjust various build files. Remove automatic generation of the c/src/lib/libbsp/*/acinclude.m4 files from bootstrap script. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move benchmark timer to bspsSebastian Huber2018-04-201-0/+83
* bsps: Move startup files to bspsSebastian Huber2018-04-206-0/+1498
| | | | | | | | Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
* bsps: Move start files to bspsSebastian Huber2018-04-201-0/+418
* bsps: Move console drivers to bspsSebastian Huber2018-04-201-0/+390
* bsps: Move clock drivers to bspsSebastian Huber2018-04-201-0/+101
* bsps: Move doxygen.h files to bspsSebastian Huber2018-04-201-0/+15
* Remove make preinstallChris Johns2018-01-253-0/+157
