Update #3706.
Update #3706.
Update #3706.
They are only used by PowerPC BSPs.
replace.
searching and sorting.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Update #3678.
Update #3678.
Update #3678.
Update #3678.
Drop unused and deprecated functions from the ATA_DRIVER_TABLE_ENTRY.
Update #3358.
Close #3510.
Update #3358.
Set the FIFO control register while DLAB == 1 in the line control
register. At least on the QorIQ T4240 the driver still works with the
re-ordered FIFO control register access.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
Pass current processor control as first parameter in
bsp_start_on_secondary_processor() and qoriq_start_thread() to make
dependency more explicit.
Update #3433.
Use device tree provided timebase frequency. Do not write to read-only
mtime register.
Update #3433.
Update #3285.
This function is only used by the raspberrypi BSP.
Update #3285.
Update #2408.
The VME support is only used by powerpc BSPs.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
