path: root/bsps/include/bsp/stackalloc.h (follow)
* bsps: Adjust architecture Doxygen groupsSebastian Huber2019-03-041-1/+1
| | | | | | | | | | - Use CamelCase as it is not used in our C code. Enables simple search and replace. - Prefix with "RTEMS" to aid deployment and integration. It aids searching and sorting. Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+94
