path: root/bsps/arm/include/bsp/arm-cp15-start.h (follow)
* bsps/arm/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* bsps: Support RTEMS_NOINIT in linkcmdsSebastian Huber2021-05-021-1/+5
| | | | Update #3866.
* bsps/arm: ARMV7_CP15_START_WORKSPACE_ENTRY_INDEXSebastian Huber2021-04-291-1/+1
| | | | | | | Change the ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX value to be in line with the workspace entry in ARMV7_CP15_START_DEFAULT_SECTIONS. Close #4395.
* bsps/arm: Fix MMU configurationSebastian Huber2020-12-151-0/+4
| | | | Update #4184.
* bsps/arm: Fix MMU small pages supportJan Sommer2020-12-111-1/+1
| | | | | | - For small tables only round to the next 4kiB instead of 1MiB Close #4184.
* bsps/arm: Define index of the workspace entry.Christian Mauderer2020-01-071-0/+2
| | | | | | The imx BSP contained a hack to change the workspace entry of the MMU table. This makes the used define visible for other BSPs too so that the same hack can be used for example in raspberry pi too.
* bsps/arm: Add support for small pages MMUSebastian Huber2019-10-311-9/+48
| | | | | | | The small page MMU support reduces the granularity for memory settings through the MMU from 1MiB sections to 4KiB small pages. Enable it by default on the realview_pbx_a9_qemu BSP.
* Remove make preinstallChris Johns2018-01-251-0/+187
