Updates #3053.
Updates #4625.
A device tree binary has to be 8 byte aligned in memory. This is checked
since RTEMS commit 34052ef78cf8724dee73e9279b2c6bff8cfed234 "libfdt: Add
FDT alignment check to fdt_check_header()".
It wasn't possible to keep the CS line low between multiple message
descriptors in one transfer. This patch reworks the driver so that it is
possible.
Update #4180
Calling the memory FLASH and EXTRAM instead of FLEXSPI and SDRAM makes
it simpler to support other types of external RAM. This patch also
removes some of the calculations and improves names and documentation to
avoid pitfalls. It removes a unnecessary memory definition.
Update #4180
Update #4180
This define is no longer used.
Update #3269.
Assert BSP_INTERRUPT_VECTOR_MAX + 1 == BSP_INTERRUPT_VECTOR_COUNT.
After building all BSPs with this patch, BSP_INTERRUPT_VECTOR_MAX can be
removed and replaced by BSP_INTERRUPT_VECTOR_COUNT. The
BSP_INTERRUPT_VECTOR_COUNT allows a default implementation which supports no
interrupt vector at all. Using COUNT instead of MAX may avoid some
interpretation issues, for example is the maximum value a valid vector number
or not.
Update #3269.
Remove BSP_INTERRUPT_VECTOR_MIN and unconditionally let interrupt vector
numbers start with zero.
The BSP_INTERRUPT_VECTOR_MIN == 0 invariant was tested by the previous commit
and building all BSPs.
Update #3269.
The EDMA is intialized so make sure the the clock is initialized too.
Update #4180
The sizes are configurable via fuses or per software via some registers.
At the moment the registers are not changed. Changing the registers
destroys data stored in the RAM areas (like application code or data).
So either the fuses or some bootloader should be used to set them before
the application starts.
This also adds an OCRAM only linker command file.
Update #4180
Add addresses and interrupts for most internal peripherals to the dts.
The additional aliases make it possible for an application to easily
access these informations.
Update #4180
Remove symbols that would be necessary for overlays and decrease padding
that would be necessary for adding stuff during run-time.
Update #4180
Update #4180
Makes it simpler to access the QTMR in an application via a FDT name or
link in an application specific FDT entry.
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
Also currently no driver uses these numbers, it is usefull for
applications that want to use the DMA.
Update #4180
Note: The changes have been done with portability in mind. The driver
should (in theory) be able to replace the original one in the MPC BSPs
too. For full compatibility an adaption layer and especially a test
would be necessary. Because both are missing, don't integrate it into
the MPC BSP now.
Update #4180
If spi or i2c slaves are "connected" to the spi or i2c bus, the device
tree compiler complains if the busses are not named spi or i2c.
Update #4180
This allows simpler creation of own dts files for custom boards.
Update #4180
Update #4180
Update #4180
Update #4180
The following files have been imported:
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h
cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050
cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h
cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include
cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers
cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include
cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include
cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c
cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include
Update #4180
