path: root/bsps/arm/imxrt (follow)
* bsps/imxrt: Use standard names to avoid warningsChristian Mauderer2021-01-212-106/+103
| | | | | | | If spi or i2c slaves are "connected" to the spi or i2c bus, the device tree compiler complains if the busses are not named spi or i2c. Update #4180
* bsps/imxrt: Split up dts.Christian Mauderer2020-12-142-290/+311
| | | | | | This allows simpler creation of own dts files for custom boards. Update #4180
* bsp/imxrt: Add new BSPChristian Mauderer2020-11-2023-35/+4858
| | | | Update #4180
* bsp/imxrt: Adapt imported filesChristian Mauderer2020-11-208-26/+80
| | | | Update #4180
* bsp/imxrt: Fix warnings for imported filesChristian Mauderer2020-11-205-0/+307
| | | | Update #4180
* bsp/imxrt: Import files from MCUXpresso SDK V2.8.5Christian Mauderer2020-11-20145-0/+141919
The following files have been imported: cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.c nxp/boards/evkbimxrt1050 cp ${SDK}/boards/evkbimxrt1050/project_template/clock_config.h include/fsl_clock_config.h cp ${SDK}/boards/evkbimxrt1050/project_template/dcd.c start/flash-dcd.c cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.c nxp/boards/evkbimxrt1050 cp ${SDK}/boards/evkbimxrt1050/project_template/pin_mux.h include/fsl_pin_mux.h cp ${SDK}/boards/evkbimxrt1050/xip/evkbimxrt1050_flexspi_nor_config.h include/fsl_flexspi_nor_config.h cp ${SDK}/devices/MIMXRT1052/MIMXRT1052.h include cp ${SDK}/devices/MIMXRT1052/MIMXRT1052_features.h include cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.c nxp/devices/MIMXRT1052/drivers cp ${SDK}/devices/MIMXRT1052/drivers/fsl_*.h include cp ${SDK}/devices/MIMXRT1052/fsl_device_registers.h include cp ${SDK}/devices/MIMXRT1052/system_MIMXRT1052.h include/ cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c nxp/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.c cp ${SDK}/devices/MIMXRT1052/xip/fsl_flexspi_nor_boot.h include Update #4180
