Fixes:
bsps/shared/dev/irq/arm-gicv2.c:53:6: warning: no previous prototype for
'bsp_interrupt_dispatch' [-Wmissing-prototypes]
Close #4227.
Sort alphabetically.
GCC 11 uses DWARF 5 by default.
Both Qemu and actual hardware treat the second UART in memory map as the
primary UART. This adjusts the ZynqMP BSPs to match.
This avoids a function call overhead in the interrupt dispatching.
Update #4202.
Update #4202.
Avoid one level of indirection.
Update #4202.
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64
code.
The SUBALIGN(4) required on rtemsroset and rtemsrwset for ILP32 builds
was previously present on LP64 builds and causes no issues within RTEMS,
but causes relocation/alignment issues when building libbsd. This
restricts those alignment changes to ILP32 builds.
This adds an AArch64 ILP32 BSP variant based on Qemu's Cortex-A53
emulation with interrupt support using GICv3 and clock support using
the ARM GPT.
This adds an AArch64 basic BSP based on Qemu's Cortex-A53 emulation with
interrupt support using GICv3 and clock support using the ARM GPT.
