This tool is now included in the RTEMS tools repository.
Close #3380.
The d542af2e4304b663461330a60313fb6c4fdbf4db commit was a bad one.
The riscv32 and riscv64 targets share a riscv source directory. The
potential future powerpcspe and powerpc targets need this change as
well.
For example ${target_arch} is "riscv32" and ${cfg_arch} is "riscv".
well.
Update #3285.
Also generate an error if the architecure does not match the --target
architecture given to configure's command line.
Close #2641.
Close 3383.
Close #3385.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3520.
This fixes the legacy Makefile based build system which expects
RTEMS_API to be identical to the tool chain version.
Update #3220.
Tool name will be "rtems5", e.g. arm-rtems5-gcc.
Next release will 5.1.0. Branch version after release will be 5.1.1.
Next master will be 6.0.0.
* Use #ifdefs for 32/64 bit code
* Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size)
* Move the code to a new shared riscv folder to be shared between riscv32 and riscv64
* Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv
Update #3109
We always build a C++ compiler and building with C++ does not effect
RTEMS or the runtime. This patch always enabled the support. There is
no need to manually enable it any more.
You can disable C++ with '--disable-cxx'.
If an architecture does not have a C++ compiler support is automatically
disabled.
Virtual machines with paravirtualization exist not only on x86.
for details.
PR 1810/misc
* ChangeLog: Fix previous damage.
PR 1729/cpukit
* aclocal/enable-smp.m4: New file.
* aclocal/rtems-top.m4: Add pkgdatadir.
Override pkgdatadir to $(datadir)/rtems$_RTEMS_API.
* Makefile.am: Install make/Templates to pkgdatadir.
* Makefile.maint, aclocal/rpm.m4, aclocal/rtems-top.m4,
aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
* aclocal/enable-itron.m4: Remove.
* configure.ac: Remove itron.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/bsp-alias.m4: Change quoting to work-round
http://www.freebsd.org/cgi/query-pr.cgi?pr=146378.
* aclocal/check-custom-bsp.m4: Be less verbose.
* aclocal/bsp-alias.m4: Fix quoting bug.
* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned).
* aclocal/bsp-alias.m4: Pickup bsps from
c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
* aclocal/check-bsps.m4: Pickup bsps from
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* aclocal/check-bsps.m4: Add csb337 bsp family.
* aclocal/enable-itron.m4: Default to not building itron.
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
