* aclocal/bsp-alias.m4: Remove bare BSP (Abandoned).
* aclocal/bsp-alias.m4: Pickup bsps from
c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg.
* aclocal/check-bsps.m4: Pickup bsps from
* aclocal/check-custom-bsp.m4: Let _RTEMS_CHECK_CUSTOM_BSP look for
*.cfg into c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom.
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* aclocal/check-bsps.m4: Add csb337 bsp family.
* aclocal/enable-itron.m4: Default to not building itron.
* aclocal/bsp-alias.m4: Add csb637 as variant of csb337.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* aclocal/bsp-alias.m4: Add simsh2e.
* aclocal/canonical-target-name.m4:
Remove comment referring to HPUX9.
* aclocal/check-bsps.m4: remove stray ")" from rtl22xx_t alias.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add h8sxsim as variant
of h8sim.
* README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Add
M32C port and m32csim BSP.
PR 1324/bsps
* aclocal/check-bsps.m4: Revert Joel's icecube patch.
Recognize the the GDB SuperH simulator is just an architectural
simulator and does not include devices. Rename existing simulator BSP
configurations to simsh1 and simsh2 and add simsh4.
PR 1324/bsps
* aclocal/check-bsps.m4: Add missing icecube.
* aclocal/version.m4: Bump RTEMS_API to 4.10.
Bump _RTEMS_VERSION to 4.9.99.0.
* src/lib/libbsp/mips/jmr3904/tools/runtest: Add bf537Stamp.
AC_PREREQ(2.62).
updated haleakala BSP
added MPC55xx BSP
adapted PPC exception code
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* README.configure, aclocal/bsp-alias.m4: Rename EP5200 to IceCube
since that is the nickname for the Freescale evaluation board it is
based upon. BSP was tested on a Freescale MPC5200LITE.
* Makefile.maint, configure.ac, release_support: Remove RDBG.
* aclocal/enable-rdbg.m4: Removed.
many different versions of new exception handling code to shared sources.
* aclocal/bsp-alias.m4, README.configure: Add ep5200, IceCube, 5200Lite.
* README.configure, aclocal/check-bsps.m4: Remove references to
mbx860_1b since it is just an alternate name for the mbx860_001b.
Per Jiri Gaisler remove unused erc32nfp and leon1 BSP variants.
* configure.ac: Remove all macro implementations and use only the
static inline. Static inline functions are now well supported so
there is no reason for duplicate maintenance.
* aclocal/enable-inlines.m4: Removed.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/version.m4: Bump version to 4.7.99.0.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
* aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change.
Alpha-sort the aliases list.
