path: root/aclocal/check-itron.m4 (follow)
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-061-1/+6
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ----------------------------------------------------------------------
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-091-0/+29
for RTEMS.
