* | Updated information on building your own application. | Joel Sherrill | 1997-10-08 | 1 | -6/+6 |
* | Added --enable-gmake-print-directory option and ods68302 bsp. | Joel Sherrill | 1997-08-01 | 1 | -1/+2 |
* | Merged very large and much appreciated patch from Chris Johns | Joel Sherrill | 1997-07-31 | 1 | -0/+5 |
| | | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test. | ||||
* | added ka9q stack | Joel Sherrill | 1997-05-27 | 1 | -0/+4 |
* | KA9Q stack removed prior to testing for 4.0.0 public release. | Joel Sherrill | 1997-05-23 | 1 | -4/+0 |
* | Updated to reflect --enable-gcc28 and --enable-libcdir options. | Joel Sherrill | 1997-04-18 | 1 | -13/+22 |
* | Added --disable-tcpip option. | Joel Sherrill | 1997-04-16 | 1 | -5/+45 |
| | | | | Add discussion of the pecularities of the i386-go32-rtems configuration. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -0/+179 |
GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. |
