path: root/README.configure (follow)
* Updated to reflect --enable-gcc28 and --enable-libcdir options.Joel Sherrill1997-04-181-13/+22
* Added --disable-tcpip option.Joel Sherrill1997-04-161-5/+45
| | | | Add discussion of the pecularities of the i386-go32-rtems configuration.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+179
