path: root/README.configure (follow)
* Updated to reflect stack transition.Joel Sherrill1998-08-201-3/+4
* Bare BSP patch from Chris Johns <cjohns@plessey.com.au>. He alsoJoel Sherrill1998-06-271-2/+16
| | | | sent an example bare bsp but we have not decided how to integrate it yet.
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-2/+2
| | | | the CPU family name constants.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1998-02-171-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Yep, I have a bunch of bug-fixes and additions pending (Yet another monster patch, ... I can hear you scream :-). 1) configure.in : one AC_CONFIG_HEADER(...) line too much. 2) configure.in: gcc28 support is enabled by default, i.e. if no --enable-gcc28 option is passed on the command line. I am not sure if this is intentional. IMO, AC_ARG_ENABLE for --enable-gcc28 should look like: AC_ARG_ENABLE(gcc28, \ [ --enable-gcc28 enable use of gcc 2.8.x features], \ [case "${enableval}" in yes) RTEMS_USE_GCC272=no ;; no) RTEMS_USE_GCC272=yes ;; *) AC_MSG_ERROR(bad value ${enableval} for gcc-28 option) ;; esac],[RTEMS_USE_GCC272=yes]) 3) At the end of c/src/exec/score/cpu/m68k/m68k.h > #ifdef __cplusplus > } > #endif > > #endif /* !ASM */ in my opinion these two statements should be swapped: > #endif /* !ASM */ > > #ifdef __cplusplus > } > #endif I didn't try to compile for m68k, but does't this give an error? Is it compensated somewhere else - or didn't I look carefully enough? 5) configure.in: --enable-cpp should probably be renamed to --enable-cxx, as gnu-programs use "cxx" to specify C++ specific configure options, while cpp is used for the preprocessor (e.g egcs uses --with-cxx-includedir, autoconf internally uses $CXX), 6) The macro files from aclocal/*.m4 contain the buggy sed-rules formerly contained in aclocal..m4, i.e. the sed/sort-bug fix to aclocal.m4 didn't make it to aclocal/*.m4. I think I should feel guilty for that - Obviously I submitted the contents of an old aclocal-directory last time. - Sorry. 7) For sh-rtems, we currently need to add additional managers to MANAGERS_REQUIRED (from inside of custom/*.cfg). Currently MANAGERS_REQUIRED is defined in make/compilers/*.cfg. This seems to prevent overriding MANAGERS_REQUIRED from custom/*.cfg files - Obviously the files are included in such a way that the settings from compilers/*cfg always override settings from custom/*.cfg files. Furthermore, I think, defining MANAGERS_* inside gcc-<target>.cfg files is not correct - MANAGERS are not gcc-variant-dependent, but depend on targets/bsps and therefore should be defined in a bsp/target dependent file, e.g. in custom/*.cfg or target.cfg.in. I think defining default settings for MANAGERS* in custom/default.cfg could be an appropriate location. But this requires all custom/*.cfg files to include default.cfg, which *-posix.cfg files don't seem to do. Therefore I would like propose to move MANAGERS* to target.cfg.in - they are included by all custom/*.cfg files. Perhaps we/you should use this opportunity to merge parts from custom/default.cfg into target.cfg.in. This ensures to have the setting included once per target makefile and will open the opportunity to have autoconf doing additional work on bsp-configurations. Peanuts sofar, ... but here it comes ... (:-) 8) I am preparing a major enhancement to autoconf support for gnutools/compilers. It is not yet finished, but usable and I'll therefore attach a preliminary version to this mail. Motivation: * Fix problems with --enable-gcc28, if target-cc is not gcc28 compatible * Fix -pipe problems * Fix problems with hard-coded paths in configuration files (esp. posix) * Fix consistency problems with explictly given gnutools and gcc's gnutools Currently included: * detection and checking of host and target compiler (gcc/g++) * checking if target gnutools are in path * checking if <target>-gcc -specs works (autodisabling gcc28 if not) * checking if <target>-gcc -pipe works Todo : * *posix.cfg files are not yet adapted => The hard-coded paths for these systems are still in use. * Check if the host compiler $CC is properly propagated to the Makefiles (I doubt it, but this should not matter) * Check if rtems' generic tools still work properly (It looks like, but who knows) * Integrate CXX support into default.cfg or gcc-target-default.cfg (It looks like C++ support is only used by posix BSPs) * Automatically handle RANLIB/MKLIB for targets * Plenty ... (:-) Open problems: * Untested for non-gcc compatible host and target compilers. This should be no problem if the tools are named follow gnutool's naming convention and are included in $PATH while running configure. * Intentionally using different tools than that gcc has been configured for, e.g. use a different assembler ? This should be still possible if XX_FOR_TARGET is hard-coded into custom/*.cfg. I don't see why anybody should want to do this, but who knows? I have tested this version on linux and solaris hosts, with gcc's directories mounted at weird non-standard mount points, using egcs (linux/sh-rtemscoff), gcc-2.7.2.2 using native tools (solaris), gcc-2.7.2.3 w/ gnutools (solaris/linux). I don't expect it to break anything, but of cause I can't promise it. It will break most/all *-posix.cfg configuration almost for certain, but not more as rtems' current *posix.cfg configurations already do (hard-coded configurations). I am not sure if this is ready to be included into the next snapshot or not. Perhaps you might try this on your systems and if it you don't notice serious bugs you might put it into the snapshot for public testing (I don't like this, but I don't see another possiblity to test generality). I enclose a patch for configure.in and some configuration files which comprizes fixes for all items mentioned except of #3 . Don't forget to run "aclocal -I aclocal; autoconf;" after applying the patch (:-).
* Robin Kirkham reported that the install point was incorrect in this file.Joel Sherrill1998-02-101-1/+1
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+3
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Removed reference to CC_FOR_TARGET since I don't want anyone overridingJoel Sherrill1997-12-221-4/+8
| | | | | | it anyway. :) Added hints about --prefix and --program-prefix options.
* Corrected minor things including changing RTEMSBSP to RTEMS_BSP.Joel Sherrill1997-12-161-8/+8
* Added comment about using --enable-gcc28 and --enable-libcdirJoel Sherrill1997-10-081-1/+3
| | | | options together.
* Updated information on building your own application.Joel Sherrill1997-10-081-6/+6
* Added --enable-gmake-print-directory option and ods68302 bsp.Joel Sherrill1997-08-011-1/+2
* Merged very large and much appreciated patch from Chris JohnsJoel Sherrill1997-07-311-0/+5
| | | | | <cjohns@plessey.com.au>. This patch includes the ods68302 bsp, the RTEMS++ class library, and the rtems++ test.
* added ka9q stackJoel Sherrill1997-05-271-0/+4
* KA9Q stack removed prior to testing for 4.0.0 public release.Joel Sherrill1997-05-231-4/+0
* Updated to reflect --enable-gcc28 and --enable-libcdir options.Joel Sherrill1997-04-181-13/+22
* Added --disable-tcpip option.Joel Sherrill1997-04-161-5/+45
| | | | Add discussion of the pecularities of the i386-go32-rtems configuration.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+179
