path: root/ChangeLog (follow)
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+7
| | | | | | | * aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY. * aclocal/prog-cc.m4: Reworked CFLAGS handling. * aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-0/+4
| | | | * aclocal/rtems-flags.m4: New.
* 2002-12-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-041-0/+4
| | | | * bootstrap: Allow autoconf-2.57.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-0/+4
| | | | * aclocal/prog-cc.m4: Remove GCCSED.
* 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-011-0/+9
| | | | | | | | | * automake/compile.am: Remove LDFLAGS_INCOMPLETE. Remove LDFLAGS. Add CCAS, CCASCOMPILE. Remove compilation rules for *.cpp, *.cxx, *.C. Use CCASCOMPILE to compile *.S. Add -pg to RTEMS_CFLAGS_PROFILE_V.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-0/+4
| | | | * configure.ac: Remove c/make.
* 2002-11-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-291-0/+7
| | | | | | | * aclocal/prog-ccas.m4: New. * aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4. * aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP. * aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* 2002-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-201-0/+4
| | | | * acinclude.m4: Conditionally append --target=.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-201-0/+4
| | | | * aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-0/+6
| | | | | | * automake/compile.am: Remove LD_PATHS (Unused). * aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK is announced obsolete).
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-0/+4
| | | | * Makefile.am: Reflect having removed aclocal/sysv-ipc.m4.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-0/+5
| | | | | * aclocal/sysv-ipc.m4: Remove (Unused). * aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
| | | | * acinclude.m4: Lots of changes addressing PR 312.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-0/+9
| | | | | * aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix to PR 312).
* 2002-11-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-181-0/+4
| | | | * VERSION: Updated to rtems-ss-20021118.
| | | | * aclocal/version.m4: Updated to rtems-ss-20021118.
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-181-0/+5
| | | | | * aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for Motorola MTX603e.
* 2002-11-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-181-0/+5
| | | | | * acinclude.m4: Use AS_IF instead of if/then/else/endif. * configure.ac: Ditto.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-0/+6
| | | | | | * automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V, CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT. Support @CFLAGS@, @CXXFLAGS@.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-0/+4
| | | | * bootstrap: Allow autoconf-2.56.
* 2002-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-151-0/+7
| | | | | | | * acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*. Fix stupid typo (continue/configure). * aclocal/prog-cc.m4: Remove obsolete comments. Acknowledge CFLAGS.
* 2002-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-141-0/+6
| | | | | | * acinclude.m4: _RTEMS_OUTPUT_SUBDIRS: Move ac_subconfigure_vars to the end of the args passed to sub-configure-scripts. (Reported by Wulf Hofbauer <wh73@cornell.edu>)
* 2002-11-12 Joel Sherrill <joel@OARcorp.com>Ralf Corsepius2002-11-121-0/+4
| | | | * configure.ac: Remove make/compilers/Makefile.
* 2002-11-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-111-0/+4
| | | | * VERSION: Updated to rtems-ss-20021111.
| | | | * aclocal/version.m4: Updated to rtems-ss-20021111.
* 2002-11-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-081-0/+4
| | | | * automake/compile.am: Remove rel rule.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-0/+4
| | | | * bootstrap: Allow autoconf > 2.52, automake > 1.6.
* 2002-11-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-071-0/+5
| | | | | * configure.ac: Remove make/Templates/Makefile. * README.configure: Minor massaging.
* 2002-11-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-061-0/+7
| | | | | | | Further preparations for autoconf > 2.52: * aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else. * aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg. * aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* 2002-11-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-051-0/+4
| | | | * acinclude.m4: Adapations to autoconf > 2.52.
* 2002-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-011-24/+3
| | | | * ChangeLog: Corrected.
* Till Straumann's patch to:Eric Norum2002-11-011-0/+16
| | | | | use bootp option 129 to get command line string change inet_ntoa->inet_ntop
* Reflect changes to signal names in newlib sys/signal.h.Eric Norum2002-10-311-0/+3
* Add vprintk function for kernel printing from routinesEric Norum2002-10-301-0/+6
| | | | which have already obtained the va_list pointer.
* 2002-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-301-0/+7
| | | | | | | * bootstrap: Add generate_bspdir_acinclude to automatically update c/src/lib/libbsp/<cpu>/acinclude.m4. Use #! /bin/sh instead of #!/bin/sh. Remove autom4te*.cache during ./bootstrap --clean.
* 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-291-0/+15
| | | | | | | | | | | | | | | * aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING. * aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING. (autoconf > 2.54 seems to have problems with the old form of quoting).
* 2002-10-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-281-0/+5
| | | | | * aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR (autoconf > 2.54 complains about).
* 2002-10-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-211-0/+4
| | | | * VERSION: Updated to rtems-20021021-test.
| | | | * aclocal/version.m4: Updated to rtems-20021021-test.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-0/+4
| | | | * aclocal/ppc.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-111-0/+5
| | | | | * aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE). * acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* 2002-10-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-091-0/+5
| | | | | * bootstrap: Add autoconf/automake version checks by popular demand. [FWIW: I dislike this.]
* 2002-10-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-071-0/+4
| | | | * VERSION: Updated to rtems-ss-20021007.
| | | | * aclocal/version.m4: Updated to rtems-ss-20021007.
* 2002-10-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-041-0/+4
| | | | * VERSION: Updated to rtems-JUNK.
| | | | * aclocal/version.m4: Updated to rtems-JUNK.
| | | | * VERSION: Updated to rtems-ss-20021004.
