* acinclude.m4: Use AS_IF instead of if/then/else/endif.
* configure.ac: Ditto.
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V,
CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT.
Support @CFLAGS@, @CXXFLAGS@.
* bootstrap: Allow autoconf-2.56.
* acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*.
Fix stupid typo (continue/configure).
* aclocal/prog-cc.m4: Remove obsolete comments.
Acknowledge CFLAGS.
* acinclude.m4: _RTEMS_OUTPUT_SUBDIRS: Move ac_subconfigure_vars to the
end of the args passed to sub-configure-scripts. (Reported by
Wulf Hofbauer <wh73@cornell.edu>)
* configure.ac: Remove make/compilers/Makefile.
* VERSION: Updated to rtems-ss-20021111.
* aclocal/version.m4: Updated to rtems-ss-20021111.
* automake/compile.am: Remove rel rule.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
Further preparations for autoconf > 2.52:
* aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else.
* aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg.
* aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* acinclude.m4: Adapations to autoconf > 2.52.
* ChangeLog: Corrected.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
which have already obtained the va_list pointer.
* bootstrap: Add generate_bspdir_acinclude to automatically update
c/src/lib/libbsp/<cpu>/acinclude.m4.
Use #! /bin/sh instead of #!/bin/sh.
Remove autom4te*.cache during ./bootstrap --clean.
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING.
(autoconf > 2.54 seems to have problems with the old form of
quoting).
* aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR
(autoconf > 2.54 complains about).
* VERSION: Updated to rtems-20021021-test.
* aclocal/version.m4: Updated to rtems-20021021-test.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* aclocal/ppc.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* aclocal/quoting.m4: New (Implements RTEMS_CONFIGURE_ARGS_QUOTE).
* acinclude.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE.
* bootstrap: Add autoconf/automake version checks by popular demand.
[FWIW: I dislike this.]
* VERSION: Updated to rtems-ss-20021007.
* aclocal/version.m4: Updated to rtems-ss-20021007.
* VERSION: Updated to rtems-JUNK.
* aclocal/version.m4: Updated to rtems-JUNK.
* VERSION: Updated to rtems-ss-20021004.
* aclocal/version.m4: Updated to rtems-ss-20021004.
* aclocal/bsp-configure.m4: Create bspopts.h on the fly, filter out
autoconf-2.53 PACKAGE crap.
* aclocal/prog-gnat.m4: New.
* aclocal/bsp-configure.m4: Fix small typo in comment.
* aclocal/env-rtemsbsp.m4: RTEMS_ROOT="\$(PROJECT_ROOT)/c/$RTEMS_BSP".
* aclocal/check-bsp-cache.m4: Convert to autoconf-2.5x quoting
rules. Add RTEMS_BSP_CFLAGS, RTEMS_BSP_CFLAGS_OPTIMIZE_V,
RTEMS_BSP_CFLAGS_DEBUG_V, RTEMS_BSP_CFLAGS_PROFILE_V.
* aclocal/version.m4: Updated to rtems-ss-20020807.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/rtems-cpu-subdirs.m4: Removed the or16 port
was just a stub and only the OR32 port is getting worked on.
* aclocal/subdirs.m4: Remove.
* acinclude.m4: New (Replaces aclocal/subdirs.m4).
* aclocal/check-cpu.m4: Peek into cpukit/score/cpu instead of
exec/score/cpu.
* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING.
* automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all
compilation rules (Work-around to an automake bug).
* automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to
make-library.
* configure.ac: Activate cpukit. Remove references to c/src/exec.
