path: root/ChangeLog (follow)
* 2005-07-06 Philippe SimonsPhilippe Simons2005-07-071-0/+4
| | | | * MAINTAINERS: Added me as arm/gp32 bsp maintainer.
* 2005-04-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-04-281-0/+5
| | | | | * README.configure: Updated to account for removal of dmv177 and ppcn_60x as well as other additions and deletions.
* 2005-02-04 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-041-0/+4
| | | | * aclocal/enable-itron.m4: Allow unix.
* 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-021-0/+4
| | | | * Makefile.am: Remove ACLOCAL_FILES.
* 2004-11-16 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-161-0/+5
| | | | | * aclocal/check-bsps.m4: Use ls instead of globs to pickup bsp_specs.
* 2004-11-12 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-121-0/+5
| | | | | * aclocal/check-bsps.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-11-10 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2004-11-101-0/+4
| | | | * aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* 2004-10-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-221-0/+4
| | | | * alocal/check-custom-bsp.m4: Reflect new location of bspkit*cfg.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+6
| | | | | | * aclocal/check-bsps.m4: Add bspkit support. Don't check for presence of *.cfg. * aclocal/check-custom-bsp.m4: Add bspkit support.
* 2004-10-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-181-0/+4
| | | | * aclocal/enable-bare.m4: Remove.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-0/+5
| | | | | * MAINTAINERS, README.configure, c/ACKNOWLEDGEMENTS, c/TOOL_TARGETS: i960 obsoleted and all references removed.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-0/+4
| | | | * configure.ac: Require automake > 1.9.
| | | | * aclocal/rtems-cpu-subdirs.m4: Remove (unused).
* 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-0/+7
| | | | | | PR 673/make_build * config-ml.in: Quote 'cd "${ml_origdir}"'. Quote 'cd "${ML_POPDIR}"'.
* 2004-08-17 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-08-181-1/+5
| | | | * acinclude.m4 (_RTEMS_CONFIG_SUBDIR): Quote ac_popdir uses.
* Removing message from cut release trial.Joel Sherrill2004-07-291-8/+0
* 2004-07-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-07-281-0/+4
| | | | * VERSION: Updated to rtems-4.6.99.1.
| | | | * aclocal/version.m4: Updated to rtems-4.6.99.1.
* Back off version again.Joel Sherrill2004-07-281-12/+0
| | | | * release_support: Have a user name.
* Back off version.Joel Sherrill2004-07-281-8/+0
* 2004-07-28Joel Sherrill2004-07-281-0/+4
* 2004-07-14 Jay MonkmanJay Monkman2004-07-151-0/+4
| | | | * MAINTAINERS: Added Jay Monkman as ARM architecture maintainer
* 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-311-0/+6
| | | | | | * aclocal/rtems-top.m4: Remove ENDIF. Remove with_target_subdir defaulting to '.'. * acinclude.m4: Add --includedir to sub_configure_args.
* 2004-02-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-171-0/+7
| | | | | | | * Makefile.am: DIST_SUBDIRS = $(SUBDIRS). Rework dist-hook. * configure.ac: Reflect changes to RTEMS_ENABLE_RTEMSBSP. * aclocal/enable-rtemsbsp.m4: Add support for --disable-rtemsbsp.
* 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-141-0/+4
| | | | * configure.ac: RTEMS_BUILD_CONFIG_SUBDIRS([testsuites/tools]).
* 2004-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-131-0/+9
| | | | | | | | | * Makefile.am: Remove AUTOMAKE_FILES. Cleanup duplicate ACLOCAL_FILES. EXTRA_DIST += config-ml.in. DIST_SUBDIRS += make. Add dist-hook. * configure.ac: Add dist-bzip2 no-dist-gzip to AUTOMAKE_OPTIONS.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-0/+4
| | | | * bootstrap: RTEMS_CHECK_BSPDIR(RTEMS_BSP_FAMILY).
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-0/+5
| | | | | * VERSION: 4.6.99.0. * aclocal/version.m4: 4.6.99.0.
* 2004-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-02-061-0/+5
| | | | | * aclocal/bsp-alias.m4: Readd aliases for p4600 and p4650 which were accidentally removed when purging the mips64orion.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-031-1/+7
| | | | | | * aclocal/rpm.m4: Make osversions the default. * aclocal/rtems-top.m4: Remove check for version.m4 (Breaks make distcheck).
* 2004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-011-0/+4
| | | | * aclocal/rpms.m4: New (extracted from scripts/configure.ac).
* 2004-01-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-161-0/+5
| | | | | * configure.ac: Require automake >= 1.8.2. * aclocal/check-bsps.m4: Also test for make/custom/*.cfg.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-121-0/+4
| | | | * configure.ac: Requires automake >= 1.8.1.
* 2004-01-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-091-0/+5
| | | | | * .cvsignore: Remove mkinstalldirs. * bootstrap: Remove compile during "clean".
* 2004-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-081-0/+4
| | | | * .cvsignore: Add compile.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-0/+5
| | | | | * README.configure: Remove efi68k and efi332 references as they are no longer in the tree.
| | | | | * aclocal/bsp-alias.m4, aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-191-0/+5
| | | | | * README.configure: Reflect requireing autoconf-2.59 and automake-1.8.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-0/+4
| | | | * VERSION: Updated to rtems-20031217-test.
| | | | * aclocal/version.m4: Updated to rtems-20031217-test.
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-0/+5
| | | | | * release_support: Correct method used to find ChangeLog associated with the version.m4 files. Keep going until I can get a tarball cut.
* Remove junk entries.Joel Sherrill2003-12-171-8/+0
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-0/+8
* 2003-12-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-12-171-5/+2
| | | | | * release_support: Use dirname not basedir. Keep going until I can get a tarball cut.
| | | | * release_support: New file -- assistant to new cut_release script.
