* aclocal/rtems-cpu-subdirs.m4: Print out RTEMS_CPU in error message.
* aclocal/enable-cxx.m4: Use $enable_cxx instead of $enableval.
* aclocal/prog-cxx.m4: Remove RTEMS_PROG_CXX.
Rework RTEMS_PROG_CXX_FOR_TARGET.
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
* configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
* aclocal/bsp-configure.m4: Remove RTEMS_CHECK_BSP_CACHE.
* aclocal/env-rtemsbsp.m4: Add comments to AC_ARG_VARs.
Add AC_ARG_VAR(RTEMS_CPU_MODEL).
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* automake/compile.am: Remove hard-coded *_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Remove CPPFLAGS_GCC.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V, RTEMS_BSP_FAMILY.
* aclocal/prog-cc.m4: Reworked CFLAGS handling.
* aclocal/prog-cxx.m4: Reworked CXXFLAGS handling.
* aclocal/rtems-flags.m4: New.
* bootstrap: Allow autoconf-2.57.
* aclocal/prog-cc.m4: Remove GCCSED.
* automake/compile.am: Remove LDFLAGS_INCOMPLETE.
Remove LDFLAGS.
Add CCAS, CCASCOMPILE.
Remove compilation rules for *.cpp, *.cxx, *.C.
Use CCASCOMPILE to compile *.S.
Add -pg to RTEMS_CFLAGS_PROFILE_V.
* configure.ac: Remove c/make.
* aclocal/prog-ccas.m4: New.
* aclocal/check-custom-bsp.m4: New, split out from check-bsps.m4.
* aclocal/check-bsps.m4: Split out RTEMS_CHECK_CUSTOM_BSP.
* aclocal/canonicalize-tools.m4: Remove RTEMS_GCC_PRINT.
* acinclude.m4: Conditionally append --target=.
* aclocal/quoting.m4: Reworked (Part of fix to PR 312).
* automake/compile.am: Remove LD_PATHS (Unused).
* aclocal/check-newlib.m4: Adaptation to autoconf-2.5x (AC_TRY_LINK
is announced obsolete).
* Makefile.am: Reflect having removed aclocal/sysv-ipc.m4.
* aclocal/sysv-ipc.m4: Remove (Unused).
* aclocal/target.m4: Sync with acinclude.m4 (Part of fix to PR 312).
* acinclude.m4: Lots of changes addressing PR 312.
* aclocal/target.m4: Apply RTEMS_CONFIGURE_ARGS_QUOTE (Part of fix
to PR 312).
* VERSION: Updated to rtems-ss-20021118.
* aclocal/version.m4: Updated to rtems-ss-20021118.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Added support for
Motorola MTX603e.
* acinclude.m4: Use AS_IF instead of if/then/else/endif.
* configure.ac: Ditto.
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V,
CXXFLAGS_DEBUG_OPTIMIZE_V, LDFLAGS_DEBUG_V, CFLAGS_DEFAULT.
Support @CFLAGS@, @CXXFLAGS@.
* bootstrap: Allow autoconf-2.56.
* acinclude.m4: Add CXX_FOR_*, CXXFLAGS_FOR_*.
Fix stupid typo (continue/configure).
* aclocal/prog-cc.m4: Remove obsolete comments.
Acknowledge CFLAGS.
* acinclude.m4: _RTEMS_OUTPUT_SUBDIRS: Move ac_subconfigure_vars to the
end of the args passed to sub-configure-scripts. (Reported by
Wulf Hofbauer <wh73@cornell.edu>)
* configure.ac: Remove make/compilers/Makefile.
* VERSION: Updated to rtems-ss-20021111.
* aclocal/version.m4: Updated to rtems-ss-20021111.
* automake/compile.am: Remove rel rule.
* bootstrap: Allow autoconf > 2.52, automake > 1.6.
* configure.ac: Remove make/Templates/Makefile.
* README.configure: Minor massaging.
Further preparations for autoconf > 2.52:
* aclocal/enable-inlines.m4: Use AS_IF instead of if/then/else.
* aclocal/quoting.m4: Use `eval echo $ac_args` to unquote $ac_arg.
* aclocal/target.m4: Use `eval echo $rtems_args` to unquote $ac_arg.
* acinclude.m4: Adapations to autoconf > 2.52.
* ChangeLog: Corrected.
use bootp option 129 to get command line string
change inet_ntoa->inet_ntop
which have already obtained the va_list pointer.
* bootstrap: Add generate_bspdir_acinclude to automatically update
c/src/lib/libbsp/<cpu>/acinclude.m4.
Use #! /bin/sh instead of #!/bin/sh.
Remove autom4te*.cache during ./bootstrap --clean.
* aclocal/enable-bare.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-cxx.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-inlines.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-itron.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-multiprocessing.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-networking.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-posix.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rdbg.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-rtemsbsp.m4: Improve quoting of AC_HELP_STRING.
* aclocal/enable-tests.m4: Improve quoting of AC_HELP_STRING.
(autoconf > 2.54 seems to have problems with the old form of
quoting).
* aclocal/enable-rtemsbsp.m4: Remove '\' in AC_MSG_ERROR
(autoconf > 2.54 complains about).
* VERSION: Updated to rtems-20021021-test.
* aclocal/version.m4: Updated to rtems-20021021-test.
