* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 64 | -128/+0 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
| | | | | * wrapup/Makefile.am: Add preinstall.am. | ||||
* | Add preinstall.am | Ralf Corsepius | 2006-01-12 | 1 | -15/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 9 | -0/+24 |
* | New. | Ralf Corsepius | 2006-01-12 | 3 | -0/+21 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+15 |
| | | | | | | | | | | | | | | | * Makefile.am, ftpd/Makefile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, score/cpu/arm/Makefile.am, score/cpu/avr/Makefile.am, score/cpu/c4x/Makefile.am, score/cpu/h8300/Makefile.am, score/cpu/i386/Makefile.am, score/cpu/m68k/Makefile.am, score/cpu/mips/Makefile.am, score/cpu/no_cpu/Makefile.am, score/cpu/powerpc/Makefile.am, score/cpu/sh/Makefile.am, score/cpu/sparc/Makefile.am, score/cpu/unix/Makefile.am, telnetd/Makefile.am, zlib/Makefile.am: Remove all-local:. | ||||
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 29 | -72/+19 |
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -10/+24 |
| | | | | | | * ampolish3.in: Add all: for PREINSTALL_FILES. Add all-local for TMPINSTALL_FILES. Misc bug fixes. | ||||
* | New. | Ralf Corsepius | 2006-01-12 | 1 | -0/+26 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 4 | -37/+31 |
| | | | | | | * libchip/Makefile.am: Build libchip/network/smc91111. * libchip/network/smc91111.c, libchip/network/smc91111config.h: Eliminate cyg_int* crap. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -3/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 58 | -116/+99 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 3 | -9/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 56 | -109/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 2 | -2/+2 |
* | Remove unnecessary CLEANFILES. | Ralf Corsepius | 2006-01-12 | 5 | -12/+3 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 4 | -4/+4 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 21 | -46/+46 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 27 | -106/+12 |
* | 2006-10-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -3/+26 |
| | | | | | * ampolish3.in: Check if Makefile.am already contains CLEANFILES or DISTCLEANFILES. | ||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 2 | -11/+12 |
| | | | | | * aclocal/bsp-alias.m4: Revert Joel's 2006-01-10 change. Alpha-sort the aliases list. | ||||
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 1 | -0/+5 |
| | | | | | * automake/host.am, automake/local.am, automake/subdirs.am: Remove depend-am, depend-recursive. | ||||
* | Remove depend-recursive: | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Remove depend-am: | Ralf Corsepius | 2006-01-12 | 2 | -8/+0 |
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h, | Till Straumann | 2006-01-12 | 5 | -20/+81 |
| | | | | | | | | | vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h: No longer enable posted-writes on master windows (creates race-condition on memory-mapped devices). A new flag allows for signalling that a window maps 'ordinary memory'. Disable VME IRQ level if no handler is registered with interrupting vector. | ||||
* | * vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h: | Till Straumann | 2006-01-12 | 3 | -8/+17 |
| | | | | Eliminate obsolete types. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 1 | -0/+4 |
| | | | | * rtems/score/types.h: Eliminate unsigned16. | ||||
* | Eliminate unsigned32. | Ralf Corsepius | 2006-01-11 | 1 | -2/+2 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -69/+3 |
| | | | | * librdbg/Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 1 | -0/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 4 | -0/+216 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 18 | -538/+73 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 5 | -0/+310 |
* | Remove leftovers of consolex. | Ralf Corsepius | 2006-01-11 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -283/+30 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 27 | -683/+82 |
* | New. | Ralf Corsepius | 2006-01-11 | 22 | -0/+1306 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 20 | -545/+72 |
* | New. | Ralf Corsepius | 2006-01-11 | 6 | -0/+364 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 34 | -68/+85 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-11 | 3 | -4/+1 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -4/+16 |
| | | | | | * aclocal/bsp-configure.m4: Add ampolish3. New header guards. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2006-01-11 | 2 | -7/+4 |
| | | | | * bspstart.am: Remove. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 1 | -0/+4 |
| | | | | * libcsupport/src/error.c: include and use inttypes.h. | ||||
* | include and use inttypes.h. | Ralf Corsepius | 2006-01-10 | 1 | -2/+2 |
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 33 | -900/+139 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -246/+33 |
