* libchip/network/greth.c, libchip/network/open_eth.c: Add constants
for buffer modes.
* libmisc/fb/fb.h: Add constants for buffer modes.
* rtems/score/lm32.h: Add lm32_read_interrupts().
* shared/milkymist_ac97/ac97.c, shared/milkymist_clock/ckinit.c,
shared/milkymist_clock/clock.h, shared/milkymist_console/console.c,
shared/milkymist_console/uart.c, shared/milkymist_console/uart.h,
shared/milkymist_framebuffer/framebuffer.c,
shared/milkymist_gpio/gpio.c, shared/milkymist_networking/mm_crc32.c,
shared/milkymist_networking/network.c,
shared/milkymist_networking/network.h,
shared/milkymist_timer/timer.c: New files.
* acinclude.m4, configure.ac: Add Milkymist BSP developed as part of
GSOC 2010.
Add Milkymist BSP developed as part of GSOC 2010.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, Documentation/uart.txt, include/.cvsignore,
include/bsp.h, include/system_conf.h, include/tm27.h,
make/custom/milkymist.cfg, startup/linkcmds: New files.
PR 1682/bsps
* startup/bspstart.c: Add BSP_poll_char.
PR 1684/bsps
PR 1685/bsps
PR 1686/bsps
* console/console.c: Add BSP_poll_char.
* posix/include/rtems/posix/aio_misc.h: Add decl for aio_request_queue.
* posix/src/aio_misc.c: Add aio_request_queue.
* posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_request_s,
rtems_aio_request_chain_s, rtems_aio_queue_s;
* posix/include/aio.h: Separate LIO-modes from LIO-opcodes (From
freebsd).
* sapi/include/rtems/chain.h: Move extern "C".
PR 1681/cpukit
* shared/score/interrupt.S: With the percpu patch, ASM uses
INTERRUPT_STACK_HIGH instead of _CPU_Interrupt_stack_high. The
sparc64 was still using the old variable, which was declared in its
cpu.h file. This patch to comment out the declaration and switch to
using INTERRUPT_STACK_HIGH.
* posix/include/aio.h: Add LIO_SYNC.
* posix/include/rtems/posix/aio_misc.h: Add aio_request_queue,
Cosmetics.
* posix/src/aio_cancel.c, posix/src/aio_fsync.c, posix/src/aio_misc.c:
Rework.
* psxenosys/init.c, psxenosys/psxenosys.scn: Update to reflect AIO
submission.
* psxaio01/.cvsignore, psxaio02/.cvsignore: New files.
PR 1680/cpukit
* score/src/isr.c: Correct initialization of _CPU_Interrupt_stack_high
to properly do the alignment. This most likely only would have caused
a propblem on CPUs where the stack grows down and have strict
alignment.
PR 1681/cpukit
* rtems/score/cpu.h: With the percpu patch, ASM uses
cpu.h file. This patch comments out the declaration and switch to
PR 1677/filesystem
* libfs/src/imfs/imfs_creat.c: Fix creating of a file. Lost in the
change from a switch statement.
* libchip/ide/ata_internal.h: C++ compatibility.
* libchip/Makefile.am, libchip/preinstall.am: Install
<libchip/ata_internal.h>.
* libchip/ide/ata_util.c: New file.
* libchip/Makefile.am: Reflect change from above.
* libchip/ide/ata.c: Moved ata_breq_init(), ata_identify_device(), and
ata_process_request_on_init_phase() into new file.
* libchip/ide/ata_internal.h, libchip/ide/ata.c: Moved code into
separate functions. Added public ata_breq_init(),
ata_identify_device(), and ata_process_request_on_init_phase()
functions.
* fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP).
* configure.ac: Remove AM_CONDITIONAL(LIBCHIP).
Force autoconf-2.67, automake-1.11.1.
rtems_aio_queue_s.size (Unused).
* posix/src/aio_misc.c: Remove aio_request_queue.size.
Cosmetics.
* Makefile.am, configure.ac: Add psxaio01/, psxaio02/.
* psxaio01/Makefile.am, psxaio01/init.c, psxaio01/psxaio01.scn,
psxaio01/system.h: New.
* psxaio02/Makefile.am, psxaio02/init.c, psxaio02/psxaio02.scn,
psxaio02/system.h: New.
* posix/Makefile.am: Reflect aio-changes.
* posix/src/aio_misc.c: New.
* posix/src/aio_error.c, posix/src/aio_read.c,
* posix/src/aio_return.c, posix/src/aio_write.c:
New implementation.
* posix/include/aio.h: Extend struct aiocb.
* posix/include/rtems/posix/aio_misc.h: New.
* src/uart-output-char.c: Add BSP_poll_char.
* shared/console/polled_io.c: Add BSP_poll_char.
* console/polled_io.c: Add BSP_poll_char.
* mpc55xx/esci/esci.c: Add BSP_poll_char.
* at91rm9200/dbgu/dbgu.c, pxa255/ffuart/ffuart.c: Add BSP_poll_char.
* Makefile.am: Do not use .rel files for libbsp pieces.
* startup/syscalls.c:
* spurious/spinit.c: Add include of bootcard.h to fix warning.
PR 1674/docs
* user/Makefile.am, user/dirstat.texi: Fix bad node reference.
