* | Added missing dependency for libmisc.a based on a bug report by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 2 | -0/+2 |
* | Fixed indexing bug reported by Phil Wilshire. | Joel Sherrill | 1997-12-07 | 3 | -3/+3 |
* | Redid hwapi makefile search to remove need for -follow option to find. | Joel Sherrill | 1997-12-06 | 2 | -44/+160 |
| | | | | Avoid generating Makefiles for KA9Q and C++ when they are disabled. | ||||
* | Removed need for -follow option to find. | Joel Sherrill | 1997-12-06 | 1 | -1/+1 |
* | Changed the uuencode line to work better with VPATH setups. | Joel Sherrill | 1997-12-06 | 1 | -2/+2 |
* | Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined. | Joel Sherrill | 1997-12-06 | 3 | -6/+6 |
| | | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find. | ||||
* | Reworked mkdir line to invoke smaller lines. | Joel Sherrill | 1997-12-04 | 1 | -1/+4 |
* | Added better/more correct support for Linux and Solaris simulators. | Joel Sherrill | 1997-12-04 | 2 | -24/+47 |
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano | Joel Sherrill | 1997-12-01 | 33 | -0/+4898 |
| | | | | | <pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/). | ||||
* | Fixed test for RTEMS_HAS_POSIX_API so the executive POSIX API related | Joel Sherrill | 1997-12-01 | 2 | -18/+18 |
| | | | | Makefiles would be properly generated. | ||||
* | Even more cleanup to make sure all the --enable/disable options avoid | Joel Sherrill | 1997-12-01 | 2 | -99/+176 |
| | | | | | | | generating Makefiles where possible. Added code to make sure make/custom file and bsp directory exist for configured bsps. This code also accounts for "aliased" BSPs. | ||||
* | Since test suite Makefiles are not always generated, use wildcard | Joel Sherrill | 1997-11-30 | 1 | -4/+3 |
| | | | | to determine which directories to descend into. | ||||
* | Corrected call to rtems_termios_open. | Joel Sherrill | 1997-11-30 | 1 | -1/+2 |
* | Corrected comment. | Joel Sherrill | 1997-11-30 | 3 | -10/+1 |
* | Do not generate make/os at install point. | Joel Sherrill | 1997-11-30 | 1 | -2/+1 |
* | Serious cleanup to reduce the number of explicitly listed Makefiles, | Joel Sherrill | 1997-11-30 | 4 | -1411/+461 |
| | | | | | eliminated autoconf looking for commands which are unused, and reduce the number of Makefiles generated. | ||||
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 6 | -3/+18 |
* | Added credit for host.cfg stuff from Ralf Corsepius (corsepiu@faw.uni-ulm.de). | Joel Sherrill | 1997-11-29 | 1 | -0/+4 |
* | Changes from Ralf Corsepius (corsepiu@faw.uni-ulm.de) to automatically | Joel Sherrill | 1997-11-29 | 4 | -547/+363 |
| | | | | generate the list of Makefiles in the configure script. | ||||
* | Patch from Chris Johns to filter out the trace bit on CPU models | Joel Sherrill | 1997-11-29 | 1 | -2/+5 |
| | | | | which have hardware support for a separate interrupt stack. | ||||
* | Removed warning. | Joel Sherrill | 1997-11-18 | 2 | -2/+2 |
* | New file. | Joel Sherrill | 1997-11-18 | 2 | -0/+90 |
* | Removed warning under linux port. | Joel Sherrill | 1997-11-18 | 3 | -0/+15 |
* | Removed warnings. | Joel Sherrill | 1997-11-18 | 2 | -1/+6 |
* | Added argument as required by new version of termios_open. | Joel Sherrill | 1997-11-18 | 1 | -2/+4 |
* | Fixed assignment to dereference ch. | Joel Sherrill | 1997-11-18 | 1 | -1/+1 |
* | Changed from DOS style CR/LF to Unix style. | Joel Sherrill | 1997-11-18 | 1 | -534/+534 |
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 3 | -3/+18 |
* | Merged code from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to generate | Joel Sherrill | 1997-11-18 | 2 | -300/+1336 |
| | | | | the information in the make/os/XYZ.cfg files using autoconf. | ||||
* | Modified to rezongize CPU-rtemsXYZ rather than just CPU-rtems. | Joel Sherrill | 1997-11-18 | 1 | -9/+15 |
* | Submitted by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1997-11-18 | 1 | -0/+41 |
* | interrupt driven change from Eric Norum | Joel Sherrill | 1997-11-15 | 8 | -261/+618 |
* | Fixed prototype | Joel Sherrill | 1997-11-10 | 4 | -4/+4 |
* | Set return code to avoid spurious errors. | Joel Sherrill | 1997-11-10 | 3 | -0/+3 |
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | ||||
* | added katsutoshi Shibuya | Joel Sherrill | 1997-10-24 | 3 | -3/+24 |
* | Changed prototype of read routine. | Joel Sherrill | 1997-10-23 | 7 | -43/+22 |
* | Switched to new style for read support routine. | Joel Sherrill | 1997-10-23 | 1 | -10/+6 |
* | Added TOD driver from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 6 | -3/+190 |
* | Removed GEN68360_INIT. | Joel Sherrill | 1997-10-23 | 1 | -8/+0 |
* | Update from Eric Norum. | Joel Sherrill | 1997-10-23 | 1 | -161/+153 |
* | Updated console driver to use new read routine conventions. | Joel Sherrill | 1997-10-23 | 1 | -6/+3 |
* | Added TOD code for MVME162 BSP from Katsutoshi Shibuya. | Joel Sherrill | 1997-10-23 | 2 | -6/+8 |
* | Added new test for termios style consoles from Eric Norum. | Joel Sherrill | 1997-10-23 | 4 | -1/+346 |
* | Added console_reserve_resources. | Joel Sherrill | 1997-10-23 | 2 | -6/+15 |
