PR 1532/testing
* aclocal/project-root.m4: Add initial tests for untar capabilities.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.c: Now supports
both pax and GNU tar created tar files.
* posix/src/sigsuspend.c: Do not assert unless RTEMS_DEBUG is defined.
PR 1629/cpukit
* posix/src/sigsuspend.c: sigsuspend() was not completely following the
POSIX specification.
PR 1629/cpukit
* psx04/init.c: sigsuspend() was not completely following the POSIX
specification.
PR 1630/cpukit
* posix/src/psignalchecksignal.c, posix/src/sigtimedwait.c:
sigtimedwait() was not completely following the POSIX specification.
PR 1634/bsps
* shared/console/conscfg.c: Add BSP_poll_char.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
PR 1632/testing
* devfs04/init.c, devfs04/test_driver.c: Added cases to exercise
null_initialize() and null_write().
* rtems/score/cpu.h: Assembler compatibility fixes.
* rtems/asm.h: Fixed header guard.
* umon/tfsDriver.c: Update for LibIO API changes.
* score/src/threadget.c: Conditionalize a check that can only occur
when POSIX is disabled.
* rtems/src/taskmode.c, score/inline/rtems/score/thread.inl: Rework a
bit to eliminate unreachable path for task blocked while calling
rtems_task_mode() on itself.
* sapi/include/confdefs.h: Spelling.
* libcsupport/src/privateenv.c, libmisc/cpuuse/cpuusagereport.c,
posix/Makefile.am, posix/include/rtems/posix/key.h,
posix/src/keycreate.c, posix/src/keydelete.c,
score/src/iterateoverthreads.c: Since removing ITRON, the loop over
all APIs for tasks has a path that cannot be reached. Either modify
the code or mark tests for NULL as RTEMS_DEBUG.
* posix/src/keyfreememory.c: New file.
* libfs/src/imfs/imfs_load_tar.c: Formatting.
* sapi/include/confdefs.h: Do not cover up user configuation mistakes
on filesystems -- cite them as errors.
* rtems/src/ratemonperiod.c: Remove tabs.
* Makefile.am, configure.ac: Add test to extract a task blocked with
timeout on a priority ordered thread queue.
* sp72/.cvsignore, sp72/Makefile.am, sp72/init.c, sp72/sp72.doc,
sp72/sp72.scn: New files.
* rtems/src/ratemonperiod.c: Use if not switch since all cases of enum
are not valid and switch was generating dead code.
* gxx01/gxx01.scn, gxx01/init.c: Remove local _exit().
* gxx01/gxx01.scn, gxx01/init.c: Add test f0r rtems_gxx_key_dtor().
* sapi/include/rtems/init.h: Mark rtems_shutdown_executive as a
noreturn method.
* gxx01/gxx01.scn, gxx01/init.c: Add more testcases.
* libcsupport/src/gxx_wrappers.c: Free contents of key not key itself.
Kye pointer will never be malloc'ed.
* libcsupport/Makefile.am, libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_num2baud.c: Use RTEMS associations to
simplify code and make easier for coverage.
* libcsupport/src/termios_baudtable.c: New file.
* start/start.S: Replace the call to _return_to_monitor by
hlt instruction.
* startup/ldsegs.S: Remove the _return_to_monitor function.
PR 1627/testing
* libfs/src/devfs/devstat.c:
* devfs02/init.c, devfs02/devfs02.doc, devfs02/devfs02.scn,
devfs02/Makefile.am: New tests added
* devfs03/init.c, devfs03/devfs03.doc, devfs03/devfs03.scn,
devfs03/Makefile.am: New tests added
* devfs04/init.c, devfs04/devfs04.doc, devfs04/devfs04.scn,
devfs04/Makefile.am: New tests added
* Makefile.am, configure.ac: Changes to accommodate the above
newly added tests.
* timer/timer.c: Do not do the indirect call if NULL.
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
PR 1623/testing
* psx13/test.c, psx13/psx13.scn: New cases to improve coverage of
utime() and fpathconf().
* psxfile01/test.c, psxfile01/psxfile01.scn: New cases to improve
coverage of rmdir(), unlink(), mknod(), link(), open(), read(),
write().
* psxstat/test.c, psxstat/psxstat.scn: New case to improve
coverage of readlink().
