* | 2005-07-06 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-06 | 2 | -1/+12 |
| | | | | | * binutils/binutils.add: Take out -D_FORTIFY_SOURCE from CFLAGS to prevent fortify from rendering ar unusable. | ||||
* | Enable CS1* and CS2* now that Arcturus bootstrap PROMs no longer take care ↵ | Eric Norum | 2005-07-06 | 2 | -0/+5 |
| | | | | of that for us. | ||||
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 2 | -1/+11 |
| | | | | * libblock/include/rtems/ide_part_table.h: Add C++ guards. | ||||
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 4 | -27/+29 |
| | | | | | * binutils/mkspec.in, gccnewlib/mkspec.in, gdb/mkspec.in: Use ',' as sed pattern delimiter. | ||||
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 3 | -3/+6 |
| | | | | | | * autotools/automake.add: Add %{?dist}. * autotools/autoconf.add: Add %{?dist}. Replace Copyright: by Licence:. | ||||
* | 2005-07-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-07-05 | 2 | -1/+4 |
| | | | | * gccnewlib/gccnewlib.add: Remove Epoch. | ||||
* | Add description of external interrupt request assignments. | Eric Norum | 2005-06-30 | 1 | -0/+3 |
* | The DHCP header. | Chris Johns | 2005-06-30 | 1 | -0/+47 |
* | DHCP server for RTEMS. | Chris Johns | 2005-06-30 | 1 | -0/+1133 |
* | Reflect changes to network driver. | Eric Norum | 2005-06-29 | 1 | -1/+1 |
* | Drive LEDs with more useful information. | Eric Norum | 2005-06-29 | 1 | -0/+2 |
* | Add duplex negotation support. | Eric Norum | 2005-06-29 | 2 | -46/+99 |
* | Minor tweak to make it easier to insert some code to test realignment. | Eric Norum | 2005-06-22 | 1 | -2/+2 |
* | Clean up transmit buffer realignment. | Eric Norum | 2005-06-20 | 3 | -74/+84 |
| | | | | Many thanks to Mr. Kolja Waschk for identifying the problem. | ||||
* | 2005-06-17 Markku Puro <markku.puro@kopteri.net> | Joel Sherrill | 2005-06-17 | 3 | -1/+66 |
| | | | | | * Makefile.am: Adding GameBoy Advance BSP. * custom/gba.cfg: New file. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -1/+7 |
| | | | | | * libnetworking/net/if.h: Avoid use of struct mbuf to avoid unintended dependencies added by the RTEMS specific tap interface. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -1/+9 |
| | | | | | * librdbg/src/powerpc/excep_f.c: Conditionalize use of ISI vector since it is not supported by the MPC5xx. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 1 | -0/+4 |
| | | | | * mpc5xx/vectors/vectors.h: Add hack to avoid warning. | ||||
| | | | | * include/.cvsignore: New file. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -7/+28 |
| | | | | | | * libchip/network/if_dc.c: Begin to convert to new PCI and IRQ interface. Also correct attempting to build on other than PowerPC and x86. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -0/+6 |
| | | | | * acinclude.m4: Added mcf5235. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -0/+71 |
| | | | | * user/region.t: Add documentation on region_resize_segment. | ||||
* | 2005-06-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-06-17 | 5 | -0/+3030 |
| | | | | | | * ChangeLog, Makefile.am, configure.ac, preinstall.am: Addition of mcf5235 support. * mcf5235/include/mcf5235.h: New file. | ||||
* | 2005-06-17 Mike Bertosh <mbertosh@motioncontrol.org> | Joel Sherrill | 2005-06-17 | 20 | -0/+3885 |
| | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock.c, console/console.c, include/bsp.h, include/coverhd.h, include/tm27.h, network/network.c, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/init5235.c, startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram, timer/timer.c: New files. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 2 | -0/+55 |
| | | | | * custom/mcf5235.cfg: New file. | ||||
* | 2005-06-16 Daron Chabot <daron@nucleus.usask.ca> | Joel Sherrill | 2005-06-16 | 5 | -3/+5027 |
| | | | | | | * libchip/Makefile.am: Add driver for Tulip clones. * libchip/network/README.tulipclone, libchip/network/if_dc.c, libchip/network/if_dcreg.h: New files. | ||||
* | 2005-06-09 Jacques Seronie Vivien <jacques.seronievivien@astrium.eads.net> | Joel Sherrill | 2005-06-09 | 3 | -2/+13 |
| | | | | | | | PR 790/rtems * sapi/src/extensioncreate.c, sapi/src/extensionident.c: Correct use of name. This was missed when the other ident services in rtems/src where changed. | ||||
* | 2005-06-07 Brett Swimley <brett.swimley@aedbozeman.com> | Joel Sherrill | 2005-06-07 | 3 | -6/+11 |
| | | | | | PR 803/patch * rtems/score/cpu.h, rtems/score/m68k.h: Correct definition of _VBR. | ||||
* | 2005-06-06 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2005-06-06 | 2 | -1/+6 |
| | | | | * Makefile.am: Include lcd.rel. | ||||
* | 2005-06-01 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2005-06-02 | 2 | -8/+15 |
| | | | | * custom/gp32.cfg: Add make-cxx-exe. | ||||
* | 2005-06-01 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2005-06-02 | 7 | -27/+410 |
| | | | | | | * Makefile.am: Add s3c2400/lcd/lcd.c, s3c2400/clock/support.c * s3c2400/clock/clockdrv.c: Update to use get_PCLK() * s3c2400/timer/timer.c: Update to use get_PCLK() | ||||
* | 2005-06-01 Philippe Simons <loki_666@fastmail.fm> | Joel Sherrill | 2005-06-02 | 6 | -45/+91 |
| | | | | | | | * bsp_specs: Add rules for cpp support * include/bsp.h: Add gp32 support fct prototypes * console/conio.c: Moved video buffer to 0x0c7ed000 * startup/bspstart.c: Add some init code, some cleaning... | ||||
* | Regenerate. | Ralf Corsepius | 2005-06-01 | 2 | -0/+13 |
* | 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 1 | -0/+3 |
| | | | | | | * libnetworking/net/if.h: Partial update from FreeBSD. * libnetworking/netinet/if_ether.h: Remove BYTE_PACK. * libnetworking/netinet/ip_var.h: Remove BYTE_PACK. | ||||
* | Partial update from FreeBSD. | Ralf Corsepius | 2005-05-27 | 1 | -2/+3 |
* | Remove BYTE_PACK. | Ralf Corsepius | 2005-05-27 | 2 | -14/+8 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 2 | -1/+5 |
| | | | | * librpc/include/rpc/clnt.h: Partial update from FreeBSD. | ||||
* | 2005-05-27 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-27 | 1 | -1/+7 |
| | | | | | | * custom/mbx860_005b.cfg, custom/mcp750.cfg, custom/mtx603e.cfg, custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg: Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | ||||
* | Remove RTEMS_PPC_EXCEPTION_PROCESSING_MODEL (Obsolete). | Ralf Corsepius | 2005-05-27 | 6 | -7/+0 |
* | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-27 | 6 | -4/+13 |
| | | | | | | * libnetworking/lib/ftpfs.c, librpc/include/rpc/svc.h, librpc/src/rpc/get_myaddress.c, librpc/src/rpc/pmap_getmaps.c, librpc/src/rpc/pmap_getport.c: Remove warnings. | ||||
* | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-26 | 2 | -0/+7 |
| | | | | | | PR 799/bsps * include/bsp.h: Add include of bsp/vectors.h so rdbg.h can be compiled. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 96 | -101/+293 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -0/+6 |
| | | | | | | * librpc/include/rpc/clnt.h, librpc/include/rpc/svc.h, src/rpc/pmap_rmt.c: Use void* instead of caddr_t. Cosmetics from FreeBSD. | ||||
* | Use void* instead of caddr_t. Cosmetics from FreeBSD. | Ralf Corsepius | 2005-05-25 | 3 | -31/+49 |
* | Regenerate. | Ralf Corsepius | 2005-05-25 | 1 | -4/+0 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -2/+7 |
| | | | | | | * librpc/include/rpc/auth_des.h: Remove (Unused, unsupported). * librpc/include/rpc/rpc.h, librpc/Makefile.am: Reflect removing auth_des.h. | ||||
* | Reflect removing auth_des.h. | Ralf Corsepius | 2005-05-25 | 2 | -7/+1 |
* | Remove (Unused, unsupported). | Ralf Corsepius | 2005-05-25 | 1 | -109/+0 |
* | 2005-05-25 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-25 | 1 | -0/+2 |
| | | | | | * include/rpc/rpc_com.h, include/rpc/rpc_msg.h, src/rpc/svc_simple.c: Minor fixes. | ||||
* | Misc. fixes. | Ralf Corsepius | 2005-05-25 | 3 | -37/+31 |
