* eth_comm.cfg, mbx821_001.cfg, mbx860_002.cfg, mbx860_005b.cfg,
mbx8xx.cfg, mpc8260ads.cfg: Per PR260 removed make-target-options.
* custom/mvme136.cfg: Per PR260 removed make-target-options.
* wrapup/Makefile.am: Don't install.
* wrapup/Makefile.am: Use librtems.a.
* wrapup/Makefile.am: Use libsapi.a.
* src/Makefile.am: Add librtems.a.
* src/Makefile.am: Add libsrtems.a.
* Makefile.am: Clean $(PROJECT_RELEASE).
* wrapup/Makefile.am: Use libscore.a.
* src/Makefile.am: Build into libscore.a.
* aclocal/canonicalize-tools.m4: Remove LD.
* automake/lib.am: Remove LD.
* Makefile.am: Put preinstall-stamp into CLEANFILES.
* aclocal/rtems-top.m4: Use with_project_root and MULTIBUILDTOP to
compose PROJECT_TOPdir (Fixes hppa1.1/genoffset problem).
* aclocal/rtems-cpu-subdirs.m4: Removed the or16 port
was just a stub and only the OR32 port is getting worked on.
* .cvsignore, ChangeLog, asm.h, configure.ac, cpu.c, cpu_asm.c,
rtems/score/.cvsignore, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or16.h, rtems/score/types.h: Removed as the or16 port
* src/mqueuecreatesupp.c: #include <stdlib.h> (malloc).
* wrapup/Makefile.am: LIBBLOCK_OBJS = ../libblock/$(ARCH)/libblock.a.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
* configure.ac: Remove src/Makefile.am
* wrapup/Makefile.am: Remove.
* wrapup/.cvsignore: Remove.
* Makefile.am: Remove wrapup SUBDIR.
* configure.ac: Remove wrapup/Makefile.
* setup.def: Updated to gcc3.1/newlib 1.10.0 RPM revision 5 with
the gcc3 patch 20020730a and newlib 1.10.0 patch 20020726.
* custom/vegaplus.cfg: Generate the Mapfile into $(ARCH) so it
will disappear when make clean is performed.
* Makefile.am: Added arm subdirectory.
* intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* .cvsignore: Corrected some errors.
* timeMVME136.t, timedata.t: Replaced XXX's with real info.
* callconf.t: Added some markups for fonts and clarified
some places.
* miscellaneous.t: Added some markups for fonts and clarified
some places.
* configure.ac: Added supplements/arm/Makefile.
* README: Updated.
* README: Updated.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2001-01-17 Joel Sherrill <joel@OARcorp.com>
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* sys/param.h: Removed as a simpler version of this file is
now part of the RTEMS newlib support.
* sys/Makefile.am: Modified to reflect above.
* machine/types.h: Removed as a simpler version of this file is
* machine/Makefile.am, machine/endian.h, nfs/bootp_subr.c,
rtems/rtems_bsdnet_internal.h, sys/Makefile.am, sys/systm.h:
Minor modifications to use the simpler machine/types.h. Mostly
more complete sets of #include's to account for machine/types.h
no longer doing this.
* include/sys/utime.h: Removed as file is now part of the RTEMS
newlib support.
* Makefile.am: Reflect above.
* include/rtems/termiostypes.h: Avoid use of __P.
newlib support.
* spsize/size.c: Don't reference the RTEMS allocated interrupt
stack if the port doesn't configure using it.
* stackchk/check.c: Don't reference the RTEMS allocated interrupt
* startup/Makefile.am: Added -DARM_RDI_MONITOR.
* irq/irq_asm.S: ARM port works well enough to run all sptests,
tmtests, and ttcp. In addition to general cleanup, there
has been considerable optimization to interrupt disable/enable,
endian swapping, and context switching.
* cpu.c, cpu_asm.S, rtems/score/arm.h, rtems/score/cpu.h,
rtems/score/cpu_asm.h, rtems/score/types.h: ARM port works
well enough to run all sptests, tmtests, and ttcp.
In addition to general cleanup, there has been considerable
optimization to interrupt disable/enable, endian swapping,
* .cvsignore: Corrected by tailoring for the ARM.
* .cvsignore: New file.
* BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t,
cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t,
preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi,
wksheets.texi: New files as ARM supplement initial version added.
* cpuModel.S: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* registers.h: Removed.
* Makefile.am: Remove registers.h.
* startup/ldsegs.S: #include <asm.h>.
* include/bsp.h: Remove _IBMPC_chrdy (is not a public function).
Remove printk (Now in bspIo.h).
* autotools/automake-rtems.spec.in: Automake-1.6.3.
* cpukit/.cvsignore: Add mkspec. Remove rtems.spec.
* netinet/in_cksum.c, netinet/in_cksum_arm.c: Added ARM in_cksum
support.
* src/rpc/Makefile.am: Merge src/rpc/PSD.doc/Makefile.am.
* include/Makefile.am: Merge include/rpc/Makefile.am.
Merge include/rpcsvc/Makefile.am.
* include/rpc/Makefile.am: Remove.
* include/rpcsvc/Makefile.am: Remove.
* src/rpc/PSD.doc/Makefile.am: Remove.
* configure.ac: Remove duplicate AC_PROG_RANLIB.
Remove include/rpc/Makefile.
Remove include/rpcsvc/Makefile.
Remove src/rpc/PSD.doc/Makefile.
2002-07-23 Joel Sherrill <joel@OARcorp.com>
* src/rpc/pmap_clnt.c (pmap_set): Changed prototype to match .h.
2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: RTEMS_TOP(../..).
2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
2002-06-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-30 Joel Sherrill <joel@OARcorp.com>
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-22 Joel Sherrill <joel@OARcorp.com>
* src/xdr/xdr_float.c: Added A29K support.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
