* termios01/init.c: Update due to API changes. Fixed integer types.
Make functions static. Added const qualifier.
* libcsupport/src/termios_setinitialbaud.c: Fixed typo.
* libcsupport/include/rtems/termiostypes.h,
libcsupport/src/termios_baud2num.c,
libcsupport/src/termios_baudtable.c,
libcsupport/src/termios_num2baud.c,
libcsupport/src/termios_setinitialbaud.c: Added const qualifier to
baud associations. Fixed integer types.
* sapi/include/confdefs.h: Fixed workspace size estimate of tasks.
* psxconfig01/init.c: Create floating point tasks.
* posix/src/mqueuenametoid.c,
posix/src/semaphorenametoid.c: Removed files.
* posix/src/psxnametoid.c: New file.
* posix/Makefile.am: Reflect changes above.
* posix/include/rtems/posix/config.h: Fixed integer types.
* posix/include/rtems/posix/posixapi.h: Declare _POSIX_Name_to_id().
* posix/include/rtems/posix/mqueue.h,
posix/inline/rtems/posix/mqueue.inl: Changed parameter of
_POSIX_Message_queue_Create_support().
_POSIX_Message_queue_Name_to_id() is now inline.
* posix/include/rtems/posix/semaphore.h,
posix/inline/rtems/posix/semaphore.inl: Changed parameter of
_POSIX_Semaphore_Create_support(). _POSIX_Semaphore_Name_to_id() is
now inline.
* posix/src/mqueuecreatesupp.c, posix/src/semaphorecreatesupp.c: Use
_Workspace_String_duplicate().
* posix/src/mqueuesendsupp.c, posix/src/mqueueopen.c,
posix/src/mqueueunlink.c, posix/src/seminit.c, posix/src/semopen.c,
posix/src/semunlink.c: Update due to API changes.
* make/custom/qoriq.inc: Remove -W* flags.
* math/init.c, mathf/init.c, mathl/init.c: Move configuration section.
* math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate.
* math/domath.in: Generate domath* prototype.
* libchip/i2c/spi-memdrv.c: Make
spi_memdrv_minor2param_ptr, spi_memdrv_wait_ms static.
* libchip/i2c/spi-sd-card.c: Make
sd_card_compute_crc7, sd_card_compute_crc16 static.
* sapi/include/confdefs.h: Fixed workspace size estimate of POSIX keys
and message queues.
* complex/init.c: Move configuration section.
* complex/docomplex.c, complex/docomplexf.c, complex/docomplexl.c:
Regenerate.
* psxmsgq04/init.c: Fixed allocation of second message queue.
* complex/docomplex.in: Generate prototype docomplex* prototype.
* psxtmbarrier01/init.c: Make benchmark_pthread_barrier_init,
benchmark_pthread_barrier_destroy static.
* psxtmkey01/init.c: Make benchmark_pthread_key_create,
benchmark_pthread_key_delete static.
* psxtmrwlock01/init.c: Make benchmark_pthread_rwlock_init,
benchmark_pthread_rwlock_rdlock, benchmark_pthread_rwlock_unlock,
benchmark_pthread_rwlock_tryrdlock,
benchmark_pthread_rwlock_timedrdlock,
benchmark_pthread_rwlock_wrlock,
benchmark_pthread_rwlock_trywrlock,
benchmark_pthread_rwlock_timedwrlock,
benchmark_pthread_rwlock_destroy static.
* psxtmsem01/init.c: Make benchmark_sem_init,
benchmark_sem_destroy, benchmark_sem_open, benchmark_sem_close,
benchmark_sem_unlink, benchmark_sem_open_second,
benchmark_sem_close_second static.
* psxtmthread01/init.c: Make benchmark_pthread_create static.
* score/include/rtems/score/wkspace.h, score/src/wkstringduplicate.c:
Changed parameter of _Workspace_String_duplicate() to avoid strnlen().
* psxconfig01/init.c: Create more objects.
* sp31/task1.c: Make Do_nothing static.
* sprbtree01/init.c: Make test_compare_function, rb_assert static.
* tm30/init.c: Make benchmark_barrier_create,
benchmark_barrier_ident, benchmark_barrier_delete static.
* psx07/init.c: Remove unused var "clock_allowed".
* fileio/init.c: Comment out setup_nvdisk (Unused).
Make shell_nvdisk_trace, shell_nvdisk_erase, shell_bdbuf_trace,
disk_test_set_block_size, disk_test_write_blocks, disk_test_block_sizes,
parse_size_arg, create_ramdisk, create_nvdisk static.
* nsecs/init.c: Make my_ctime, subtract_em static.
* configure.ac: Check for getrusage decl.
* psxgetrusage01/init.c:
Fix header file inclusion order.
Move configuration section up.
Apply HAVE_DECL_GETRUSAGE.
* configure.ac: Check for getrusage.h decl.
* libcsupport/src/getrusage.c:
Apply HAVE_DECL_GETRUSAGE (Missing prototypes).
* compile, depcomp, mdate-sh, texinfo.tex:
Update from automake-1.11.1b.
* Makefile.am: Add support/include/tmtests_empty_function.h.
* support/include/tmtests_empty_function.h: New.
* support/src/tmtests_empty_function.c,
support/src/tmtests_support.c:
Include "tmtests_empty_function.h".
Remove local decls (Missing prototypes).
PR bsps/1989
* shared/start/start.S, shared/startup/linkcmds: Boot stack and heap
space improvements.
PR bsps/1988
* shared/start/start.S: Add _init and _fini to .init and .fini sections
PR bsps/1988
* shared/startup/linkcmds: Relocate .init and .fini sections closer to
.text.
* spwkspace/init.c: Test _Workspace_String_duplicate().
* score/src/wkstringduplicate.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/wkspace.h: Declare
Update to automake-1.11.1b.
* imfs_support/fs_supprot.h: Remove (Unused).
* configure.ac (CFLAGS): Add -Wmissing-prototypes.
* posix/src/fork.c: Include <unistd.h> for "fork" prototype.
Don't include <sys/types.h> (unnecessary).
PR 1985/cpukit
* telnetd/Makefile.am: Remove icmds.c.
* shared/interrupts/vectorexceptions.c: Make
mips_dump_exception_frame, mips_default_exception_code_handler
static.
PR 1986/libcpu
* shared/src/cache_aligned_malloc.c:
Include <rtems/rtems/cache.h>.
