alias simcpu32 that supports the CPU32 simulator in BSVC. At this
point, it is still under development.
in ROM.
is available.
the correct circumstances of DMA buffer size, serial
line interrupts, and ethernet interrupts the termios osend routine would
lock up waiting for the raw output buffer semaphore.
that does the following:
Remove $(SED) and $(CP) from make/custom/*.cfg
Motivation:
* autoconf and automake presuppose sed and cp to be present.
* make/host.cfg.in already contains SED = sed hard-coded into it for
a long time.
* Elimination of make-variables
* Eliminate make/*.cfg files or at least reduce their complexity :)
that switches the sparc from targopts.h to cpuopts.h.
that is a cosmetic patch to ampolish.
Removed obsolete flags from new custom files.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
removes warnings from the network.c file and has slight additions
to the configuration file to support Java.
is no such thing on the C4x.
that removes an unnecessary inclusion of @RTEMS_BSP@.cfg.
that is an improvement in the version handling macro that compensates
for Joel's bug in the release script which broke the VERSION file format.
by Till Straumann <strauman@SLAC.Stanford.EDU>. With this
patch, the motorola_shared BSP should also support the MVME2303.
This update addresses the following:
+ the ISR enable/disable/flash macros now work with old gcc versions.
+ the UI CCR bits are now masked since other example code did so
+ _ISR_Dispatch disables interrupts during call setup
Together these removed the instabilities he was seeing.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
