* src/mqueuenametoid.c, src/semaphorenametoid.c: Added ID to name
lookup service and changed name of id/name translation status code.
This propagated to multiple functions. The user API service added was
rtems_object_id_to_name()
* src/extensionident.c: Added ID to name lookup service and changed
name of id/name translation status code. This propagated to multiple
functions. The user API service added was rtems_object_id_to_name()
* Makefile.am, include/rtems.h, include/rtems/rtems/status.h,
src/dpmemident.c, src/msgqident.c, src/partident.c,
src/ratemonident.c, src/regionident.c, src/semident.c,
src/taskident.c, src/timerident.c: Added ID to name lookup service
and changed name of id/name translation status code. This propagated
* src/rtemsidtoname.c: New file.
* Makefile.am, include/rtems/score/object.h,
include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c:
Added ID to name lookup service and changed name of id/name
translation status code. This propagated to multiple functions. The
* src/objectidtoname.c: New file.
PR 408/filesystem
* psx13/test.c: Added very rudimentary test of sync() service.
PR 408/filesystem
* cpuuse/cpuuse.c: Added sync() service. As part of adding this
service, the new RTEMS service rtems_iterate_over_all_threads() was
also added. This new service makes it easier to iterate over all the
tasks/threads in a system and perform an action on them. This change
is to use the new thread iteration service.
PR 408/filesystem
* score/Makefile.am, score/include/rtems/score/thread.h: Added
sync() service. As part of adding this service, the
new RTEMS service rtems_iterate_over_all_threads() was also added.
* score/src/iterateoverthreads.c: New file.
* ChangeLog: Fixed screwup.
* ChangeLog: Add fileio to list of interactive tests.
* Makefile.am, include/rtems/score/thread.h: Add fileio to list of
interactive tests.
* Makefile.am: Add fileio to list of interactive tests.
* src/sync.c: New file.
PR 455/bsps
* rtems/score/cpu.h: Added missing CPU_swap_u16().
* runtest.in: Add fileio to list of interactive tests.
* tools/runtest: Add fileio to list of interactive tests.
* runtest: Add fileio to list of interactive tests.
PR 92/rtems
* Makefile.am, src/alarm.c, src/psignal.c: Added ualarm() and usleep().
* src/ualarm.c, src/usleep.c: New files.
* fsmount/Makefile.am: Fix path to automake-includes.
* fsmount/.cvsignore: New file.
* fileio/.cvsignore: New file.
PR 451/bsps
* pppd/system.h: Depend on TTY driver being in BSPs not simply i386.
PR 451/bsps
* startup/Makefile.am: Include shared i386 TTY driver in these BSPs.
* Makefile.am: Add bsp.pc.in
* bsp.pc.in: New (pkgconfig support).
* ide-ctrl.t: Merger from 4.6-branch.
* configure.ac: Removed duplicate entry.
PR 453/make_build
* startup/linkcmds: Added .eh_frame
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -D__USE_INIT_FINI__.
Remove *.cpp (Now unused).
PR 369/filesystem
* runtest: Add sample application to show the use of the
DOSFS functions
* fileio/Makefile.am: Remove references to *.scn (Doesn't exist).
* pppd/Makefile.am: Remove references to DOC* (Don't exist).
* Makefile.am: Preinstall $(PROJECT_INCLUDE)/rtems/score.
* configure.ac: Add libmisc/fsmount/Makefile.
* include/rdbg/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* src/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
* lib/Makefile.am: New (Required by 'make dist').
* lib/ChangeLog: Remove.
* lib/.cvsignore: Cleanup.
* configure.ac: Reflect having added lib/Makefile.am.
* configure.ac: Merge-in lib/libcpu/configure.ac.
Merge-in lib/libbsp/configure.ac.
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* include/Makefile.am: Remove (merged into Makefile.am).
* gdbstub/Makefile.am: Remove (merged into Makefile.am).
Reflect having merged ../configure.ac into ../../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* wrapup/Makefile.am (FAMILY_OBJS): Remove *exception_processing.
PR 369/filesystem
* Makefile.am, configure.ac: sample application to show the use of the
DOSFS functions
* fileio/Makefile.am, fileio/fileio.doc, fileio/init.c,
fileio/system.h: New files.
PR 369/filesystem
* Makefile.am, shell/cmds.c, wrapup/Makefile.am: sample application to
show the use of the DOSFS functions
* fsmount/Makefile.am, fsmount/README, fsmount/fsmount.c,
fsmount/fsmount.h: New files.
PR 435/networking
* rtems/rtems_showifstat.c: rtems_showifstat misses printing
the netmask
* bsp_specs: Remove -D__embedded__ -Asystem(embedded)
-DUSE_ENHANCED_INTR_API from cpp.
* configure.ac: Add -DUSE_ENHANCED_INTR_API to bspopts.h.
* bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
PR 443/filesystem
* src/imfs/deviceio.c: deviceio.c mishandles return codes
PR 437/bsps
* irq/irc.c: calls to bspIo/printk must not use '%i' format which is
apparently not supported
* pci/pci.c: calls to bspIo/printk must not use '%i' format which is
