* | Documented the following Event Logging routines: | Wade A Smith | 1998-08-10 | 1 | -48/+172 | |
| | | | | | | log_write, log_open, log_read, log_notify, log_close, log_seek, log_severity_before, log_facilityemptyset, log_facilityfillset, log_facilityaddset, log_facilitydelset, and log_facilityismember | |||||
* | Documented the dump_setpath function. | Wade A Smith | 1998-08-10 | 1 | -4/+22 | |
* | Added documentation for the following Configuration Space Operations: | Wade A Smith | 1998-08-10 | 1 | -46/+342 | |
| | | | | | cfg_mount, cfg_unmount, cfg_mknod, cfg_set, cfg_get, cfg_link, cfg_unlink, cfg_open, cfg_read, cfg_children, cfg_mark, and cfg_close | |||||
* | Reordered some stuff. | Joel Sherrill | 1998-08-08 | 1 | -7/+10 | |
* | changed version to 980808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 | |
* | Corrected spacing. | Joel Sherrill | 1998-08-08 | 1 | -1/+1 | |
* | Changed debug level. | Joel Sherrill | 1998-08-08 | 2 | -36/+96 | |
| | | | | | | | | | | | | | | | | Moved CAM Descriptor types to sonic.h. CAM memory is now malloced to insure it shares the same upper address bits. Removed increment of RX interrupt count on TX interrupt path. Added SONIC_DEBUG_FRAGMENTS and SONIC_DEBUG_CAM conditionals. Fixed bugs in fragment manipulation. First bug was that the pad overwrote the last fragment. The second bug was that the link information overwrote the size of the last fragment. Rewrote initialization of TDA to simplify it. | |||||
* | changed version to 9800808 | Joel Sherrill | 1998-08-08 | 2 | -2/+2 | |
* | Removed SonicRegisters structure since we now use register indices | Joel Sherrill | 1998-08-06 | 1 | -83/+15 | |
| | | | | | | | | and access routines. Added revision constants. Added in_use and EOL field values. | |||||
* | Enabled specific types of debug info. | Joel Sherrill | 1998-08-06 | 1 | -31/+55 | |
| | | | | | | | | | | | | Added pointer to RDA to sonic structure. Added macro names for values used in the in_use field of RDA entries. Rewrote the RX Descriptor Area initialization loop. Added a check to barf if this is a Rev B sonic chip. Enabled check that the CAM was properly loaded. | |||||
* | Changed debug enable macros to support individually enabling different | Joel Sherrill | 1998-08-06 | 1 | -15/+30 | |
| | | | | | | | types of debug information. Removed call to rtems_panic which was based on checking a variable which was no longer being set. | |||||
* | Card Resource Register was a 16-bit register not a 32-bit one. | Joel Sherrill | 1998-08-06 | 5 | -28/+36 | |
| | | | | Used existing constants for bits on the register. | |||||
* | Added support for the Card Resource Register. The new probe routines | Joel Sherrill | 1998-08-06 | 5 | -8/+107 | |
| | | | | | check for the presence of the DUART, SCC, and RTC. The SONIC check needs to be added in the future as the network driver is libchip'ed. | |||||
* | Commented out the code which yields the CPU when the serial controller is | Joel Sherrill | 1998-08-05 | 6 | -0/+12 | |
| | | | | | busy. This type of behavior perturbs the tests and many of them will not pass. | |||||
* | Added constants which made the multiple bit settings more readable | Joel Sherrill | 1998-08-05 | 1 | -0/+25 | |
| | | | | for the Data Configuration Register (DCR). | |||||
* | DCR setting changed to match what the DY-4 Firmware initialized it to. | Joel Sherrill | 1998-08-05 | 1 | -135/+259 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This primarily included setting the state of the programmable outputs and the RX and TX FIFO depths. Moved all of the TX, RX, and RRA data structure initialization to before the hardware initialization. As part of this, the hardware initialization was consolidated. More than likely, some of this movement broke stuff. Used constants added to sonic.h which gave more logical names to some of the register bit settings. Switched to calloc to insure the data areas where initialized to 0. Commented out a panic check in the RX server which may or may not have been right. Increased the size of the CAM initialization area. It is possible that this could be decreased or code added to handle the management of multiple hardware addresses. Added sonic read and write register routines which aid greatly in debugging and provide the core for the eventual movement of this driver to libchip. Added debug code to the read and write register routines which can print the value read from or written to a register. This code also prints the register name which significantly eases reading the log. | |||||
* | Patch from Eric Valette <valette@crf.canon.fr> which brings the i386ex BSP | Joel Sherrill | 1998-08-05 | 27 | -578/+379 | |
| | | | | inline with the new IRQ structure. | |||||
* | changed load address | Joel Sherrill | 1998-08-05 | 1 | -2/+5 | |
* | Automatic CPU type detection code from Eric Valette <valette@crf.canon.fr>. | Joel Sherrill | 1998-08-05 | 17 | -30/+698 | |
| | | | | Enabled on the pc386. | |||||
* | Fixed name of Buffer so this would compile. | Joel Sherrill | 1998-08-05 | 1 | -3/+3 | |
* | Redid Makefiles to properly do a preinstall. There was remnants of the | Joel Sherrill | 1998-08-05 | 11 | -62/+20 | |
| | | | | old way of setting th cpu family and model string names. | |||||
* | Added print of the order in which the directories are preinstalled. | Joel Sherrill | 1998-08-05 | 1 | -1/+9 | |
* | More complete shells generated. | Joel Sherrill | 1998-08-04 | 18 | -277/+1245 | |
* | Switched to read/write register routines and added some basic debug | Joel Sherrill | 1998-08-03 | 2 | -332/+473 | |
| | | | | help. | |||||
* | Added many new chapters | Joel Sherrill | 1998-08-03 | 18 | -15/+3791 | |
* | Under allcoated task stacks. | Joel Sherrill | 1998-08-03 | 2 | -2/+2 | |
* | Changed to be posix users "new" | Joel Sherrill | 1998-08-01 | 1 | -2/+4 | |
* | Added files and directories. | Joel Sherrill | 1998-08-01 | 1 | -1/+9 | |
* | Fixed to add files and directories. | Joel Sherrill | 1998-08-01 | 1 | -7/+13 | |
| | | | | Fixed so this is installed as "POSIX Users New" | |||||
* | Added process and procenv. | Joel Sherrill | 1998-08-01 | 1 | -3/+15 | |
* | Added language variables. | Joel Sherrill | 1998-08-01 | 1 | -1/+14 | |
* | Now generates complete template for chapters. | Joel Sherrill | 1998-08-01 | 1 | -53/+85 | |
* | New files -- automatically gnerated templates. | Joel Sherrill | 1998-08-01 | 2 | -0/+722 | |
* | New file | Joel Sherrill | 1998-08-01 | 1 | -0/+65 | |
* | Removed items which are now automatically generated. | Joel Sherrill | 1998-08-01 | 1 | -41/+1 | |
* | New file. | Joel Sherrill | 1998-08-01 | 1 | -0/+98 | |
* | Removed all node and menu information since this information is now | Joel Sherrill | 1998-08-01 | 9 | -563/+12 | |
| | | | | | | | automatically generated. Removed any attempts to link across chapter boundaries since the manual is incomplete. | |||||
* | Modified so chapters are automatically generated. | Joel Sherrill | 1998-08-01 | 1 | -8/+4 | |
* | New file | Joel Sherrill | 1998-08-01 | 1 | -0/+7 | |
* | Don't automatically generate this one. | Joel Sherrill | 1998-08-01 | 1 | -0/+0 | |
* | Moved to thread.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -1025/+0 | |
* | Moved to signal.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -691/+0 | |
* | Moved to sched.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -228/+0 | |
* | Moved to preface.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -21/+0 | |
* | Moved to mutex.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -642/+0 | |
* | Moved to key.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -179/+0 | |
* | Moved to cond.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -386/+0 | |
* | Moved to clock.t and node information automatically generated | Joel Sherrill | 1998-08-01 | 1 | -264/+0 | |
* | Added automatic generation of files. | Joel Sherrill | 1998-08-01 | 9 | -1/+3478 | |
* | Moved to network demos | Joel Sherrill | 1998-08-01 | 1 | -8/+1 | |
