* cpu_supplement/arm.t: Update.
* cpu_supplement/preface.texi: Typo.
* cpu_supplement/general.t: Expanded abbreviation.
* score/src/wkspace.c: Removed work space area consistency checks.
* libblock/include/rtems/ide_part_table.h: Functions are now
deprecated.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/calloc.c,
libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_initialize.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
rtems/inline/rtems/rtems/region.inl: Update for heap API changes.
2009-09-14 Christian Mauderer <christian.mauderer@embedded-brains.de>
* libcsupport/src/vprintk.c: Fixed warnings. Print nothing in case the
pointer to the string is NULL.
* psxclock/init.c, psxclock/psxclock.scn, psxenosys/init.c,
psxenosys/psxenosys.scn, psxsignal03/Makefile.am, psxsignal03/init.c,
psxsignal04/Makefile.am: Move test cases which needed to be executed
when POSIX is disabled to psxclock so they will be.
* posix/src/nanosleep.c: Disable EINTR case when POSIX is disabled
because it cannot happen.
* score/inline/rtems/score/coremsg.inl: Fix compilation issue when
notifications are not enabled.
* configure.ac: Some POSIX tests exercise functionality which is
enabled when the POSIX threading is disabled. So build this suite all
the time and let the psxtests select the specific tests to build.
* score/include/rtems/score/thread.h, score/src/threadinitialize.c,
score/src/threadstackfree.c: Disable capability for API to let user
provide thread stack when no API configured includes this capability.
* score/include/rtems/score/coresem.h, score/src/coresemseize.c:
Disable body of _CORE_semaphore_Seize() if it is not used because all
APIs using it are disabled.
* score/include/rtems/score/tod.h: Fix typo.
* rtems/include/rtems/rtems/config.h: Add
rtems_configuration_get_maximum_semaphores().
* posix/Makefile.am, posix/src/clockgetres.c: Add clockgetres.c to set
of clock and delayt methods built when POSIX threads are disabled.
Ensure it builds when POSIX is disabled.
* sp43/Makefile.am, sp43/init.c, sp43/sp43.scn, sp43/system.h: Add test
for Id which is in range for the object class but not allocated yet.
* Makefile.am, configure.ac, psx01/init.c, psx01/psx01.scn: Add new
test to exercise clock and delay services enabled when POSIX threads
are disabled. This is split from psx01. POSIX test suite now enabled
when POSIX threads are disabled so only enable tests which are
appropriate.
* psxclock/.cvsignore, psxclock/Makefile.am, psxclock/init.c,
psxclock/psxclock.doc, psxclock/psxclock.scn: New files.
* score/src/coremsgbroadcast.c: Fix typo.
* score/src/coremsgsubmit.c: Remove extra #else.
* score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsginsert.c,
score/src/coremsgseize.c, score/src/coremsgsubmit.c: Add wrappers for
accessing message priority. Since these are empty when priority-based
message queues are disabled, this eliminates some of the
conditionals.
* score/src/coremsgseize.c: Fix typo.
* network/gdb-6.8-psim-hw_ethtap.diff: Added gdb patch
which implements the NIC hardware emulation.
* Makefile.am, bsp.h, network/if_sim.c, network/README:
added driver for NIC emulation.
* psim-top.in, psim-bottom: Added support for options
-d (print device tree and exit), -h (usage info) and
-n (enable NIC support).
* psim-gdb-bottom: Added support for options -s (force sysv IPC),
-h (usage info) and -n (enable NIC support).
Allow user to override GDB variable from environment.
* psim-shared: cat NIC properties into device file if the
user had specified '-n'.
* runtest-top.in: removed unsupported options -o, -d from
usage info.
* score/include/rtems/score/coremsg.h,
score/src/coremsgsubmit.c, score/src/objectnametoidstring.c: Disable
the Core Message Queue features of notification, priority messages,
and blocking sends when no API requires them.
* Makefile.am, preinstall.am, irq/no_pic.c (REMOVED),
irq/irq.h, irq/irq_init.c:
use openpic from 'shared' area instead of no_pic.
* inlude/psim.h:
Added 'extern' declaration for (linker-script defined) RamBase
and RamSize symbols. Let CPP macros expand to these symbols
instead of static constants.
Added register definitions for OpenPIC in the register area.
Added register definitions for ethernet controller in the register
area.
* startup/linkcmds: Increased RamSize to 16M. Increased 'RAM'
memory region to 32M (there is really no disadvantage in making
this large). Added comment explaining the inter-relation between
RamSize, the size of the memory region, the device-tree property
"oea-memory-size" and the DBAT setting.
* tools/psim-shared: Try to determine RamSize from executable
and set 'oea-memory-size' accordingly. May be overridden if 'RAM_SIZE'
envvar is set.
Added openpic to device-tree.
Added ethernet controller to device-tree (commented because a PSIM
patch is currently required to use this device).
* startup/bspstart: Increase DBAT0 mapping to size of 32M.
* shared/openpic/openpic.c: include the more generic <rtems/pci.h>
rather than <bsp/pci.h>.
* irq/openpic_i8259_irq.c: Do not include <bsp/VMEConfig.h>
if the bsp.h defines HAVE_NO_VME so that BSPs w/o VME do not
have to create a dummy VMEConfig.h header.
* score/include/rtems/score/thread.h, score/src/threadhandler.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Disable thread protocol and scheduling capabilities not exercised
when POSIX or ITRON API is disabled.
* score/include/rtems/score/object.h,
score/inline/rtems/score/object.inl,
score/src/objectgetnameasstring.c, score/src/objectidtoname.c,
score/src/objectinitializeinformation.c,
score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c, score/src/thread.c,
score/src/threadcreateidle.c: Disable object string name support when
POSIX is not enabled.
* libmisc/capture/capture.c: Use public API to obtain object name.
* rtems/score/cpu.h: Make heap alignment 4 which is greater than
CPU_ALIGNMENT but minimum for heap.
* shared/misc/m68kidle.c: added "cc" clobber to inline
asm; STOP instruction modifies CCR!
PR 1435/bsps
* Makefile.am: Use shared implementation of bsp_idle_thread().
* startup/bspidle.c: Removed.
PR 1435/bsps
PR 1435/bsps
* shared/startup/bspidle.c: New file.
PR 1435/bsps
* sp46/init.c, sp46/sp46.scn: Fix numbering.
* heapwalk/heapwalk.scn, heapwalk/init.c: Add missing _Heap_Walk test
cases to get back to 100% object coverage.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
