* | Remove "${srcdir}/${RTEMS_TOPdir}/make/custom/$1". | Ralf Corsepius | 2009-10-17 | 1 | -4/+2 |
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 4 | -2/+9 |
| | | | | | | | * make/custom/tqm8xx.inc: New (Renamed from tqm8xx.cfg). * make/custom/tqm8xx.cfg: Removed. * make/custom/pghplus.cfg, make/custom/tqm8xx_stk8xx.cfg: Include make/custom/tqm8xx.inc. | ||||
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 9 | -7/+17 |
| | | | | | | | | | | * make/custom/mbx8xx.inc: New (Renamed from mbx8xx.cfg). * make/custom/mbx8xx.cfg: Removed. * make/custom/mbx821_001.cfg, make/custom/mbx821_002b.cfg, make/custom/mbx821_002.cfg, make/custom/mbx860_001b.cfg, make/custom/mbx860_002.cfg, make/custom/mbx860_005b.cfg, make/custom/mbx860_1b.cfg: Include make/custom/mbx8xx.inc. | ||||
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 5 | -3/+11 |
| | | | | | | | | * make/custom/gen83xx.inc: New (Renamed from gen83xx.cfg). * make/custom/gen83xx.cfg: Removed. * make/custom/hsc_cm01.cfg, make/custom/mpc8313erdb.cfg, make/custom/mpc8349eamds.cfg: Include make/custom/gen83xx.inc. | ||||
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 6 | -4/+12 |
| | | | | | | | | * make/custom/gen5200.inc: New (Renamed from gen5200.cfg). * make/custom/gen5200.cfg: Removed. * make/custom/brs5l.cfg, make/custom/icecube.cfg, make/custom/pm520_cr825.cfg, make/custom/pm520_ze30.cfg: Include make/custom/gen5200.inc. | ||||
| | | | | | | | * make/custom/genmcf548x.inc: New (Renamed from genmcf548x.cfg). * make/custom/genmcf548x.cfg: Removed. * make/custom/COBRA5475.cfg, make/custom/m5484FireEngine.cfg: Include make/custom/genmcf548x.inc. | ||||
* | 2009-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 6 | -4/+13 |
| | | | | | | | | | * make/custom/lpc24xx.inc: New (Renamed from lpc24xx.cfg). * make/custom/lpc24xx.cfg: Removed. * make/custom/lpc24xx_ea.cfg, lpc24xx_ncs_ram.cfg, make/custom/lpc24xx_ncs_rom_ext.cfg, make/custom/lpc24xx_ncs_rom_int.cfg: Include make/custom/lpc24xx.inc. | ||||
* | 2009-10-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-17 | 2 | -16/+11 |
| | | | | | * configure.ac: Pick up make/custom/*. * aclocal/check-custom-bsp.m4: Adapt to changes to configure.ac. | ||||
* | binutils-2.20. | Ralf Corsepius | 2009-10-17 | 39 | -78/+78 |
* | 2009-10-17 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-10-16 | 3 | -6/+27 |
| | | | | | | | * shared/irq/idt.c: Check is the irq handlers are present before calling. * shared/comm/i386-stub-glue.c: Revert the change of 2009-05-06 as the handlers need to be present. Fixed the warnings. | ||||
* | 2009-10-16 Jennifer Averett <jennifer@OARcorp.com> | Joel Sherrill | 2009-10-16 | 3 | -2/+11 |
| | | | | | | | * configure.ac: Default to having PSC8 mezzanine so code builds all the time. * startup/bspstart.c: Calibrated clock using an VMEBus controlled discrete pulsed at a 20ms rate. | ||||
* | 2009-10-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 2009-10-16 | 2 | -6/+12 |
| | | | | | * mpc6xx/mmu/bat.c: Resolved bug: It is not an overlap if the batindex being set is the batindex of the overlap. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 4 | -7/+14 |
| | | | | * startup/bspstart.c: Remove nested externs. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -4/+9 |
| | | | | * shared/startup/zerobss.c: Remove nested externs. | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+9 |
| | | | | | * wrapup/Makefile.am: Remove AM_CONDITIONAL HAS_LIBBSP. * configure.ac: Remove AM_CONDITIONAL HAS_LIBBSP. | ||||
* | Remove AM_CONDITIONAL HAS_LIBBSP. | Ralf Corsepius | 2009-10-16 | 2 | -6/+0 |
* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -2/+0 |
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 |
| | | | | * configure.ac: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+6 |
| | | | | | | * aclocal/enable-bare.m4: Remove (Abandoned). * bsp.cfg.in: Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | Remove RTEMS_ENABLE_BARE. | Ralf Corsepius | 2009-10-16 | 1 | -1/+0 |
* | Remove BARE_CPU_MODEL, BARE_CPU_CFLAGS. | Ralf Corsepius | 2009-10-16 | 1 | -4/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -19/+0 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+5 |
| | | | | | * custom/bare.cfg: Remove (Abandoned). * Makefile.am: Remove custom/bare.cfg. | ||||
* | Remove custom/bare.cfg. | Ralf Corsepius | 2009-10-16 | 1 | -2/+0 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -38/+0 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -7/+5 |
| | | | | * aclocal/bsp-alias.m4: Remove bare BSP (Abandoned). | ||||
* | Remove special case lib/libbsp/bare (Abandoned). | Ralf Corsepius | 2009-10-16 | 1 | -8/+2 |
* | Remove (Abandoned). | Ralf Corsepius | 2009-10-16 | 11 | -739/+0 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -4/+4 |
| | | | | * startup/bspstart.c: Remove __RTEMS_APPLICATION__ | ||||
* | added COBRA5475 BSP | Thomas Doerfler | 2009-10-16 | 2 | -1/+10 |
* | added support for COBRA5475 board | Thomas Doerfler | 2009-10-16 | 12 | -19/+348 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+6 |
| | | | | * startup/bspstart.c: Add missing prototypes. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 3 | -3/+8 |
| | | | | | * shared/motorola/motorola.c, shared/vme/vme_universe.c: Add missing prototypes. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+5 |
| | | | | * startup/linkcmds: Add .sbss.*. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -13/+17 |
| | | | | | * startup/linkcmds: Add sbss section handling. Misc. sync with binutils's ld-scripts. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+5 |
| | | | | * startup/linkcmds: Fix up .sbss .sbss.* section handling. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+7 |
| | | | | * startup/linkcmds: Add __sbss_start, __sbss_end etc. | ||||
* | restructuring of ramdisk code | Thomas Doerfler | 2009-10-16 | 7 | -282/+410 |
* | Update for block device API change. | Thomas Doerfler | 2009-10-16 | 2 | -2/+6 |
| | | | | * make/custom/ss555.cfg: Remove -D$(RTEMS_BSP_FAMILY) (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -1/+2 |
| | | | | * Makefile.am: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -2/+1 |
| | | | | * configure.ac: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 4 | -6/+8 |
| | | | | * aclocal/canonical-target-name.m4: Remove RTEMS_HOST (unused). | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -0/+4 |
| | | | | * make/custom/gen83xx.cfg: Remove -W -Wno-unused. | ||||
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 |
* | Cosmetics. | Ralf Corsepius | 2009-10-16 | 1 | -2/+2 |
* | 2009-10-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-16 | 2 | -45/+13 |
| | | | | | * aclocal/bsp-alias.m4: Pickup bsps from c/src/lib/libbsp/<cpu>/<bsp_family>/make/custom*.cfg. | ||||
* | Fix typo. | Ralf Corsepius | 2009-10-16 | 1 | -1/+1 |
* | Re-cut the patch. The previous version was unclean. | Ralf Corsepius | 2009-10-16 | 1 | -24224/+56 |
* | New. | Ralf Corsepius | 2009-10-15 | 1 | -0/+28448 |
