* | Patch from Eric Valette <valette@crf.canon.fr> | Joel Sherrill | 2000-07-06 | 1 | -11/+18 | |
* | Patch rtems-rc-20000704-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-06 | 1 | -1/+1 | |
| | | | | that makes --disable-multilib the default. | |||||
* | Patch rtems-rc-20000705-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-06 | 23 | -20/+68 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is a somewhat experimental, multilib-related patch: Changes: * Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP in configure.ins below exec/. At the moment, RTEMS_ENV_RTEMSCPU is more or less an optical change to emphasize that these subdirectories shall not depend on RTEMS_BSP than a real behavioral change. * Add AC_DEFINE_* to several aclocal/*.m4 macros to prepare autoheader/autoconf generated targopts.h and similiar configuration headers. * c/src/configure.in: remove exec from cfg_subdirs if multilibs are enabled (c/src is build per bsp, exec shall be build per cpu in c/ or from the toplevel in future, when multilibs are enabled.) Notes: * This patch should not have any impact on the current building scheme. * --enable-multilib still does not work. * running bootstrap from the toplevel directory is required. CVS: ---------------------------------------------------------------------- CVS: Enter Log. Lines beginning with `CVS:' are removed automatically CVS: CVS: Committing in . CVS: CVS: Modified Files: CVS: c/src/tests/libtests/termios/init.c CVS: ---------------------------------------------------------------------- | |||||
* | Patch rtems-rc-20000705-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-06 | 1 | -1/+1 | |
| | | | | that adds multigen to the list of noinst_SCRIPTS. | |||||
* | Patch rtems-rc-20000705-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-07-06 | 1 | -11/+19 | |
* | Added baseline for h8 simulator BSP to support the simulator in gdb 5.0 | Joel Sherrill | 2000-07-06 | 22 | -0/+757 | |
* | Added missing #endif's. | Joel Sherrill | 2000-07-06 | 4 | -6/+0 | |
* | Corrected call to _CORE_mutex_Seize_interrupt_blocking. | Joel Sherrill | 2000-07-06 | 2 | -4/+10 | |
* | Modfied to execute faster and have fewer instructions. | Joel Sherrill | 2000-07-06 | 2 | -76/+76 | |
* | Switched to using isr disable version of _Objects_Get. When the | Joel Sherrill | 2000-07-06 | 2 | -26/+30 | |
| | | | | | semaphore/mutex can be obtained immediately, this cuts execution time by 50%. | |||||
* | Added _Semaphore_Get_interrupt_disable. | Joel Sherrill | 2000-07-06 | 2 | -0/+20 | |
* | Cleaned up to avoid disruptive use of inline conditionals. | Joel Sherrill | 2000-07-06 | 2 | -36/+32 | |
* | Switched to using _POSIX_Mutex_Get_interrupt_disable to improve performance. | Joel Sherrill | 2000-07-06 | 2 | -6/+8 | |
* | Added support for converting a mutex id to a pointer and returning | Joel Sherrill | 2000-07-06 | 2 | -42/+78 | |
| | | | | with interrupts disabled. | |||||
* | Reimplemented _Core_MUTEX_Seize to return with interrupts disabled | Joel Sherrill | 2000-07-06 | 4 | -14/+238 | |
| | | | | if the mutex is successfully obtained. | |||||
* | Added _CORE_semaphore_Seize_isr_disable. | Joel Sherrill | 2000-07-06 | 2 | -0/+112 | |
* | Added _Objects_Get_isr_disable prototype and added numerous comments. | Joel Sherrill | 2000-07-06 | 2 | -14/+36 | |
* | Removed unnecessary parentheses. | Joel Sherrill | 2000-07-06 | 2 | -8/+8 | |
* | Added objjectgetbyisr.c | Joel Sherrill | 2000-07-06 | 2 | -4/+6 | |
* | The code that attempts to obtain a mutex has now been inlined. The | Joel Sherrill | 2000-07-06 | 2 | -166/+14 | |
| | | | | code remaining here now only blocks. | |||||
* | Directly index local table to avoid error check. | Joel Sherrill | 2000-07-06 | 6 | -24/+20 | |
* | New file. Convert ID to pointer and return with interrupts -- not | Joel Sherrill | 2000-07-06 | 2 | -0/+166 | |
| | | | | dispatching -- disabled. | |||||
* | Format of return line changed. | Joel Sherrill | 2000-07-06 | 2 | -6/+6 | |
* | Patch rtems-rc-20000626-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-07-06 | 3 | -11/+11 | |
| | | | | | | | | | | | | | | | | | | | | | | Comments follow: Building linux/posix fails due to including lib/include/sys/cdefs.h instead of linux's sys/cdefs.h. AFAIS, this sys/cdefs.h is specific to newlib and should probably not be used on any unix host. Therefore, I changed the relevant Makefile.am/configure.in to condionally install sys/cdefs.h only if newlib is present. This triggered another bug inside of the newlib-check for one of RTEMS target's (Unfortunately I can't remember which - mips/i960 ? ... one of the more exotic ...), for which int func() isn't identical to void func(). Note: This patch needs to be tested under Cygwin and Solaris. I am particularily unsure about Cygwin/posix, as it applies a different version newlib which must not trigger RTEMS newlib check (it is supposed to fail) and if it may need RTEMS's sys/cdefs.h. | |||||
* | Interrupt stack is allocated by _ISR_Handler_initialization | Joel Sherrill | 2000-07-03 | 1 | -1/+1 | |
| | | | | not that of _ISR_Manager_initialization. | |||||
* | Interrupt stack is allocated in _ISR_Handler_initialization not | Joel Sherrill | 2000-07-03 | 22 | -22/+22 | |
| | | | | _Interrupt_Manager_initialization. | |||||
* | Added blocked_count field to allow for optimizations. | Joel Sherrill | 2000-07-03 | 4 | -4/+8 | |
* | Changed extra_system_initialization_stack to extra_mpci_receive_server_stack | Joel Sherrill | 2000-07-03 | 2 | -2/+2 | |
| | | | | to be consistent with other ports. | |||||
* | Patch rtems-rc-20000702-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-07-03 | 2 | -14/+30 | |
| | | | | | that is a hack to workaround a switch generation compiler bug for the SH2 and cleaned up some warnings. | |||||
* | Fixed stat_ino should be st_ino. | Joel Sherrill | 2000-07-02 | 4 | -4/+4 | |
* | Added fchdir(). | Joel Sherrill | 2000-06-30 | 1 | -0/+63 | |
* | Patch from Chris Johns <cjohns@cybertec.com.au> so the web server | Joel Sherrill | 2000-06-30 | 4 | -6/+24 | |
| | | | | shuts down on error -- not exitting the system. | |||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> so the directory | Joel Sherrill | 2000-06-30 | 4 | -4/+4 | |
| | | | | read function in the IMFS properly returns the inode number. | |||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> to add support for | Joel Sherrill | 2000-06-30 | 8 | -52/+68 | |
| | | | | | stat()'ing a symbolic link. This is needed to support the port of the BSD commands like ls to RTEMS. | |||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir() | Joel Sherrill | 2000-06-30 | 8 | -2/+218 | |
| | | | | functionality to libc and update TODO. | |||||
* | This is the initial addition of the port of RTEMS to the | Joel Sherrill | 2000-06-29 | 30 | -2/+4016 | |
| | | | | | | | | | | | | | Hitachi H8 family. This port was done by Philip Quaife <philip@qs.co.nz> of Q Solutions and sponsored by Comnet Technologies Ltd. The port was done based on RTEMS 3.5.1 to a Hitach H8300H. The port was updated to RTEMS 4.5 style Makefiles/configure by Joel Sherrill <joel@OARcorp.com>. While doing this Joel added support for the h8300-rtems to binutils, gcc, newlib, and gdb. NOTE: Philip submitted a BSP for a Hitachi evaluation board which is being merged as a separate entity. | |||||
* | Using RPM names for versions now. | Joel Sherrill | 2000-06-29 | 1 | -6/+6 | |
* | Added H8 as IEEE whether this is true or not. | Joel Sherrill | 2000-06-29 | 3 | -0/+3 | |
* | Disabled #ident since the h8300-rtems binutils do not like the | Joel Sherrill | 2000-06-29 | 3 | -3/+3 | |
| | | | | generated assembly from it. | |||||
* | Corrected prototype for xdrrec_endofrecord to match C body. | Joel Sherrill | 2000-06-29 | 3 | -3/+3 | |
* | Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable code | Joel Sherrill | 2000-06-29 | 4 | -0/+24 | |
| | | | | | | | | that breaks when the target has 16 bit address space. One of the H8 multilibs is a 16-bit address space CPU. When a real attempt is made to support this CPU model, the code that assumes an address is 32 bits will have to change. This constant is probably not flagging all impacted code. | |||||
* | Corrected. | Joel Sherrill | 2000-06-29 | 1 | -7/+3 | |
* | New file. | Joel Sherrill | 2000-06-29 | 3 | -0/+85 | |
* | Switch to gcc patch 20000629 and revision level 8. This patch | Joel Sherrill | 2000-06-29 | 1 | -2/+2 | |
| | | | | | | fixes: + the h8300-rtems and hppa1.1-rtems configure.in stanzas + config/rs6000/rtems.h start and end file specs | |||||
* | h8300-rtems now uses the correct command to generate the specs file. | Joel Sherrill | 2000-06-29 | 1 | -1/+1 | |
* | Added initial h8300 support. | Joel Sherrill | 2000-06-29 | 5 | -8/+26 | |
* | gdb 5.0 does not install readline so don't try to grab the info files. | Joel Sherrill | 2000-06-29 | 1 | -1/+2 | |
* | Patch from Eric Valette to do some cleanup. | Joel Sherrill | 2000-06-29 | 3 | -9/+16 | |
* | Patch from Chris Johns <cjohns@cybertec.com.au> to make sure the | Joel Sherrill | 2000-06-29 | 3 | -3/+6 | |
| | | | | ttyHead back link is set. | |||||
* | Patch from Eric Valette <valette@crf.canon.fr> to make librdbg work | Joel Sherrill | 2000-06-29 | 1 | -8/+10 | |
| | | | | with the new RPC code. |
