* | no_cpu/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -45/+5 |
| | | | | Updates #3327. | ||||
* | or1k/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -55/+4 |
* | m32c/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -51/+4 |
* | moxie/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -58/+4 |
* | sh/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -58/+8 |
* | misc sh: Remove includes of rtems/score/types.h | Joel Sherrill | 2018-03-12 | 7 | -10/+0 |
* | nios2/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -48/+4 |
* | epiphany/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -69/+4 |
* | lm32/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -48/+4 |
* | i386/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 4 | -49/+4 |
* | mips/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -60/+4 |
* | bfin/include/rtems/score/types.h: Eliminate this file | Joel Sherrill | 2018-03-12 | 3 | -51/+4 |
* | shell: Fix rtems_shell_init_env() | Sebastian Huber | 2018-03-12 | 1 | -1/+1 |
| | | | | Do not discard a user provided task name in rtems_shell_init_env(). | ||||
* | libblock: C++ compatibility | Sebastian Huber | 2018-03-12 | 2 | -0/+16 |
* | config: Use new scheduler configuration defines | Sebastian Huber | 2018-03-12 | 20 | -326/+326 |
| | | | | Update #3325. | ||||
* | config: Simplify clustered scheduler configuration | Sebastian Huber | 2018-03-12 | 2 | -86/+173 |
| | | | | | | | | | Do not use names derived from scheduler implementation details. Instead use names derived from the scheduler configuration or documentation. Provide defines for backward compatibility. Update #3325. | ||||
* | bootstrap: Use printf instead of echo -e for POSIX shells | Amaan Cheval | 2018-03-09 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | On POSIX compliant shells, echo does not have the -e option. This causes the "-e" to be echoed as well, causing potential buggy build processes. Example shell session: -> % sh $ echo -e "foo bar" -e foo bar $ According to POSIX, "\$" should be fine regardless due to the use of double-quotes[1]. However, since printf is recommended over echo anyway, we replace "echo -e" with printf where required. [1] http://pubs.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_02_03 | ||||
* | network: Optionally install network headers | Sebastian Huber | 2018-03-09 | 24 | -28/+26 |
| | | | | | | Install the network headers only if --enable-networking is specified. Update #3254. | ||||
* | cpukit/include/mqueue.h: Delete unneeded includes | Joel Sherrill | 2018-03-08 | 1 | -3/+0 |
* | score/cpu/powerpc/include/rtems/score/powerpc.h: Fix typo | Joel Sherrill | 2018-03-08 | 1 | -1/+1 |
* | powerpc/include/rtems/score/types.h: Remove unused ppc_isr | Joel Sherrill | 2018-03-08 | 1 | -2/+0 |
* | sptests/sp19: Fix test output methods | Sebastian Huber | 2018-03-08 | 2 | -2/+14 |
| | | | | Do not use fprintf() in non-fp tasks. | ||||
* | config: Remove RTEMS prefix from internal defines | Sebastian Huber | 2018-03-08 | 1 | -42/+42 |
* | bsps: More verbose bsp_fatal_extension() | Sebastian Huber | 2018-03-07 | 1 | -0/+20 |
| | | | | Close #3318. | ||||
* | capture: Fix get priority methods | Sebastian Huber | 2018-03-07 | 1 | -2/+2 |
* | libtests/capture01: Fix configuration | Sebastian Huber | 2018-03-07 | 1 | -0/+1 |
* | bsp/genmcf548x: Fix printk() support | Sebastian Huber | 2018-03-07 | 1 | -4/+15 |
* | bsps/m68k: Fix entry point in linkcmds.base | Sebastian Huber | 2018-03-07 | 1 | -1/+1 |
| | | | | Updates #3520. | ||||
* | smptests: Fix obsolete FIXME comments/code | Sebastian Huber | 2018-03-07 | 2 | -4/+2 |
* | Add a simple task console driver | Sebastian Huber | 2018-03-06 | 11 | -51/+319 |
| | | | | Close #3320. | ||||
* | bsps/sparc: Fix global construction/destruction | Thanassis Tsiodras | 2018-03-06 | 1 | -2/+4 |
| | | | | | | | | | | | | | | | | | | | | | The KEEP (*(SORT(.ctors.*))) KEEP (*(.ctors)) cannot be simplified to KEEP (*(SORT(.ctors*))) since .ctors < .ctors.* in lexicographical order. See spglobalcon02 test case. Update #3319. | ||||
* | spglobalcon02: New test | Sebastian Huber | 2018-03-06 | 6 | -0/+152 |
* | ada/sp04: Fix test failure due to compiler opti | Sebastian Huber | 2018-02-22 | 1 | -0/+1 |
| | | | | | The SPTEST.RUN_COUNT must be volatile since it is changed outside of the procedure scope by the thread switch extension. | ||||
* | termios: Fix use of uninitialized variable | Sebastian Huber | 2018-02-22 | 1 | -4/+4 |
| | | | | Update #2840. | ||||
* | powerpc/shared/startup/linkcmds.base: Add wildcards on some sections | Joel Sherrill | 2018-02-19 | 1 | -3/+3 |
| | | | | Closes #3307. | ||||
* | confdefs.h: Minor rework to avoid warnings when CONFIGURE_HAS_OWN_INIT_TABLE | Joel Sherrill | 2018-02-19 | 1 | -13/+16 |
| | | | | | | CONFIGURE_HAS_OWN_INIT_TABLE was used both with and without defining CONFIGURE_RTEMS_INIT_TASKS_TABLE. This rework allows it to work both ways without warnings. | ||||
* | unhex.c: Remove unnecessary extern of errno | Joel Sherrill | 2018-02-19 | 1 | -2/+0 |
| | | | | Closes #2610. | ||||
* | dev/sc16is752: Check return values. | Christian Mauderer | 2018-02-12 | 1 | -4/+6 |
| | | | | | Escalate a failed installation of the interrupts to the next higher level. | ||||
* | dev/sc16is752: Add GPIO access via ioctl. | Christian Mauderer | 2018-02-12 | 3 | -0/+67 |
* | bsp/atsam: Fix cache / DMA handling in SPI. | Christian Mauderer | 2018-02-12 | 6 | -44/+287 |
| | | | | | This patch fixes the cache handling for the atsam SPI driver. Note that this solution might doesn't have the best performance for small packets. | ||||
* | bsp/atsam: Allow to use a decoder for SPI CS. | Christian Mauderer | 2018-02-12 | 3 | -26/+54 |
| | | | | | The SPI controller supports a decoder connected to the chip select lines. This patch allows to use this mode. | ||||
* | bsp/atsam: Add option to disable 32kHz XTAL. | Christian Mauderer | 2018-02-12 | 3 | -0/+14 |
* | fsclose01: Fix task mode, use attribute | Sebastian Huber | 2018-02-09 | 1 | -1/+2 |
| | | | | Update #1971. | ||||
* | fsclose01: Use floating-point task | Sebastian Huber | 2018-02-09 | 1 | -1/+1 |
| | | | | | | The tmpfile() uses sprintf(). Update #1971. | ||||
* | tests: Support %g print format specifier | Sebastian Huber | 2018-02-09 | 2 | -0/+2 |
* | Use _Thread_Dispatch_direct() | Sebastian Huber | 2018-02-08 | 7 | -9/+9 |
| | | | | | | | Use _Thread_Dispatch_direct() for operations that block the executing thread. This ensures that we get a fatal error (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) if we try to block in an invalid context, e.g. during system start or an interrupt handler. | ||||
* | rtems: Use _Per_CPU_Get_executing() | Sebastian Huber | 2018-02-08 | 2 | -2/+2 |
* | fdt: Use self-contained mutex | Sebastian Huber | 2018-02-08 | 1 | -119/+29 |
| | | | | Update #2843. | ||||
* | bsps/powerpc: Fix redefinitions | Sebastian Huber | 2018-02-07 | 2 | -61/+1 |
* | bsps/sparc64: Fix redefinitions | Sebastian Huber | 2018-02-07 | 1 | -5/+2 |
