* aclocal/enable-bare.m4, aclocal/enable-cxx.m4,
aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4,
aclocal/enable-networking.m4, aclocal/enable-posix.m4,
aclocal/enable-tests.m4, aclocal/multilib.m4,
aclocal/rtems-test-no-pause.m4: Autoupdate to autoconf-2.59.
* configure.ac: Add 2nd arg to RTEMS_TOP.
Unconditionally configure MP-directories.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Add DIST_SUBDIRS comprising MP-subdirs.
* samples/Makefile.am: Add DIST_SUBDIRS comprising MP-subdirs.
* autotools/automake-rtems.spec.in: Upgrade to 1.8.3.
* itron/include/itronsys/mbox.h, itron/include/itronsys/types.h,
itron/include/rtems/itron/eventflags.h,
itron/include/rtems/itron/fmempool.h,
itron/include/rtems/itron/mbox.h,
itron/include/rtems/itron/msgbuffer.h,
itron/include/rtems/itron/port.h,
itron/include/rtems/itron/semaphore.h,
itron/include/rtems/itron/task.h,
itron/include/rtems/itron/vmempool.h,
itron/inline/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/semaphore.inl, itron/src/eventflags.c,
itron/src/fmempool.c, itron/src/itronsem.c, itron/src/mbox.c,
itron/src/msgbuffer.c, itron/src/port.c, itron/src/snd_mbx.c,
itron/src/task.c, itron/src/trcv_mbx.c, itron/src/vmempool.c:
Convert to using c99 fixed size types.
* posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/intr.h, posix/include/rtems/posix/key.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/timer.h, posix/src/cond.c,
posix/src/intr.c, posix/src/key.c, posix/src/keycreate.c,
posix/src/keydelete.c, posix/src/keygetspecific.c,
posix/src/keyrundestructors.c, posix/src/keysetspecific.c,
posix/src/killinfo.c, posix/src/mqueue.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesendsupp.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutex.c,
posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c, posix/src/psignal.c,
posix/src/pthread.c, posix/src/ptimer1.c, posix/src/semaphore.c,
posix/src/sysconf.c: Convert to using c99 fixed size types.
* score/include/rtems/system.h: include <stdint.h>.
PR/589 rtems
* libchip/network/pci.h: Remove (Moved to cpukit).
PR/589 rtems
* include/rtems/pci.h: New (Moved from c/src/libchip/network/pci.h).
* libcsupport/src/malloc.c: Remove lvalue casts.
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
* libcsupport/include/chain.h, libcsupport/include/clockdrv.h,
libcsupport/include/ringbuf.h, libcsupport/include/spurious.h,
libcsupport/include/timerdrv.h, libcsupport/include/vmeintr.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/libio.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/zilog/z8036.h, libcsupport/include/zilog/z8530.h,
libcsupport/include/zilog/z8536.h, libcsupport/src/__gettod.c,
libcsupport/src/assoc.c, libcsupport/src/assocnamebad.c,
libcsupport/src/error.c, libcsupport/src/libio.c,
libcsupport/src/libio_sockets.c, libcsupport/src/malloc.c,
libcsupport/src/no_libc.c, libcsupport/src/termios.c,
libcsupport/src/termiosreserveresources.c: Convert to using c99
fixed-size types.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h,
libfs/src/dosfs/fat_fat_operations.c,
libfs/src/dosfs/fat_fat_operations.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_misc.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fchmod.c, libfs/src/imfs/linearfile.c,
libfs/src/imfs/memfile.c: Convert to using c99 fixed-size types.
* gcc3newlib/gccnewlib.add: Disable gnats.
Further preparations for gcc-3.4.0
* gcc3newlib/base-gcc.add, gcc3newlib/target-gnat.add,
gcc3newlib/base-gcj.add, gcc3newlib/target-gcj.add:
Reflect changes to gcc3newlib/gccnewlib.add.
* gcc3newlib/base-gcc.add, gcc3newlib/target-g77.add,
gcc3newlib/target-objc.add: Preps for gcc-3.4.0.
* gcc3newlib/target-gcc.add, gcc3newlib/target-c++.add:
* gcc3newlib/gccnewlib.add: Preps. for gcc-3.4.0.
Add %gcclib, %gccexec.
* binutils/base-binutils.add: Preparations for binutils-2.15.
support.
Minor formating clean up.
Add documentation to the header file.
* README: Add "mpc5xx (mpc565)", because Wilfried B. mentioned the
mpc5xx being used on mpc565.
* configure.ac: SIZE, NM, OBJCOPY.
* libchip/network/dec21140.c: Use __PPC__ instead of __PPC.
Cosmetics.
* aclocal/canonicalize-tools.m4: Revert Joel's 2004-03-04's patch.
There are no application level Makefiles in here.
PR 587/bsps
* shared/include/cpuIdent.h, shared/include/cpuIdent.c: Add defines
for MPC_5XX.
* Makefile.am, configure.ac: Reflect having added mpc5xx.
* mpc5xx/.cvsignore, mpc5xx/Makefile.am: New.
* mpc5xx/exceptions/asm_utils.S, mpc5xx/exceptions/raw_exception.c,
mpc5xx/exceptions/raw_exception.h, mpc5xx/ictrl/ictrl.c,
mpc5xx/ictrl/ictrl.h, mpc5xx/timer/timer.c: New (Submission from
Wilfried Busalski <w.busalski@lancier-monitoring.de>).
* libnetworking/net/radix.c: Remove warning.
* custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x
support.
* libmisc/shell/cmds.c: Remove warning.
* aclocal/canonicalize-tools.m4: Add SIZE, NM, and OBJCOPY so
they can be used in application level makefiles.
* sp07/buffered_io.c: Remove warning.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate
warnings. Explicitly defeat __STRICT_ANSI__ since both
legitimately use routines beyond ANSI.
* libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* libchipnetwork/open_eth.c: Remove warnings by conditionally
compiling this file only only those CPU families with supported
exception models.
* mpc6xx/mmu/pte121.c: Add missing ifdef DEBUG to remove warning for
unused static routine.
* bootloader/pci.c: Remove warnings by adding include <string.h>.
* irq/irq.c: Clean up includes to remove warnings.
* pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const
on struct _int_map.
* network/network.c: Remove warnings for unused routines left from
original code.
* score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
Add cast to avoid type punning warning in gcc 3.3.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
