* | posix: Implement self-contained POSIX barriers | Sebastian Huber | 2017-10-05 | 25 | -381/+245 |
| | | | | | | | | POSIX barriers are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3114. | ||||
* | posix: Implement self-contained POSIX semaphores | Sebastian Huber | 2017-10-05 | 31 | -559/+639 |
| | | | | | | | | | | | | | | For semaphore object pointer and object validation see POSIX_SEMAPHORE_VALIDATE_OBJECT(). Destruction or close of a busy semaphore returns an error status. The object is not flushed. POSIX semaphores are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3116. | ||||
* | posix: Optimize pthread_once_t | Sebastian Huber | 2017-10-05 | 4 | -7/+4 |
| | | | | | | Reduce size of pthread_once_t and make it zero-initialized. Update #3142. | ||||
* | Enforce compatible Newlib version | Sebastian Huber | 2017-10-05 | 1 | -0/+1 |
| | | | | | | | | | | | | | This Newlib check ensures that we have a 64-bit time_t and self-contained POSIX synchronization objects. Update #2514. Update #3111. Update #3112. Update #3113. Update #3114. Update #3115. Update #3116. | ||||
* | score: Make status codes unconditional | Sebastian Huber | 2017-10-05 | 1 | -9/+2 |
| | | | | | | | | The internal status codes encode a Classic rtems_status_code and error codes used by the POSIX and C11/C++11 APIs. In case the POSIX API is disabled, the C11/C++11 support must still work. Close #3167. | ||||
* | posix: Fix aio_cancel() | Sebastian Huber | 2017-10-04 | 1 | -1/+1 |
| | | | | Update #3164. | ||||
* | bsp/imx: Add I2C bus driver | Sebastian Huber | 2017-10-02 | 3 | -0/+451 |
| | | | | Update #3090. | ||||
* | bsp/imx: Fix I2C register header | Sebastian Huber | 2017-10-02 | 1 | -27/+31 |
* | bsp/imx: Add imx_get_reg_of_node() | Sebastian Huber | 2017-10-02 | 3 | -9/+16 |
* | bsp/imx: Add imx_get_irq_of_node() | Sebastian Huber | 2017-10-02 | 4 | -16/+30 |
* | i2c: Add temperature sensor LM75A driver | Sebastian Huber | 2017-10-02 | 4 | -0/+329 |
| | | | | Close #3163. | ||||
* | i2c: Fix EEPROM driver program timeout handling | Sebastian Huber | 2017-10-02 | 1 | -4/+13 |
| | | | | | | | | The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it to calculate the program timeout in ticks. Check program done condition after the timeout check to account for pre-emptions. Update #3162. | ||||
* | i2c: Send MSB of address first for EEPROMs | Sebastian Huber | 2017-10-02 | 1 | -12/+21 |
| | | | | Update #3161. | ||||
* | libpci: fix pci device allocation | Daniel Hellstrom | 2017-09-29 | 5 | -37/+32 |
| | | | | | | | | | | The refactoring of pci_dev_create() was incorrect since the code relied on different defines before including pci/cfg.h. This reverts back to the original code having two pci_dev_create() one in auto and one in read library. confdefs.h selectes between the two libraries so both there is no link conflict. Updates #3029 | ||||
* | bsp/bf537Stamp: Fix warning | Sebastian Huber | 2017-09-29 | 1 | -1/+1 |
* | shell: Fix missing prototype warning | Sebastian Huber | 2017-09-28 | 1 | -0/+1 |
* | bsps: Fix integer to/from pointer warnings | Sebastian Huber | 2017-09-28 | 3 | -7/+7 |
| | | | | Update #3082. | ||||
* | bsp/gen5200: Fix warning | Sebastian Huber | 2017-09-28 | 1 | -2/+0 |
| | | | | Update #3122. | ||||
* | bsps/powerpc: Fix print format warnings | Sebastian Huber | 2017-09-28 | 4 | -77/+77 |
* | network: Add missing forward declaration | Sebastian Huber | 2017-09-28 | 1 | -0/+1 |
* | posix: Remove superfluous includes | Sebastian Huber | 2017-09-27 | 8 | -57/+18 |
* | score: Simplify red-black tree debug support | Sebastian Huber | 2017-09-27 | 4 | -16/+17 |
| | | | | | | | | Make the RBTree_Node layout independent of RTEMS_DEBUG (and all other build configuration options). This allows the use of this structure in Newlib. Update #3112. | ||||
* | posix: Remove superfluous includes | Sebastian Huber | 2017-09-27 | 2 | -14/+8 |
* | score: Rename to _Scheduler_Control | Sebastian Huber | 2017-09-27 | 7 | -15/+15 |
| | | | | | | | Rename struct Scheduler_Control to _Scheduler_Control to allow its use in standard header files, e.g. <pthread.h>. Update #3112. | ||||
* | bsp/imx: Add nocache section | Sebastian Huber | 2017-09-27 | 3 | -4/+10 |
* | bsp/imx: Provide a default console | Sebastian Huber | 2017-09-26 | 1 | -1/+1 |
* | bsp/imx: Add register headers | Sebastian Huber | 2017-09-26 | 4 | -0/+171 |
* | posix shm: Add oflag to Shm_Control | Joel Sherrill | 2017-09-22 | 2 | -0/+2 |
* | bsps: Generalize bsp_fdt_map_intr() | Sebastian Huber | 2017-09-22 | 5 | -9/+12 |
| | | | | | | | Pass all interrupt cells to bsp_fdt_map_intr() since some platforms use an array to describe an interrupt. Update #3090. | ||||
* | bsp/imx: Add SMP support | Sebastian Huber | 2017-09-22 | 3 | -16/+32 |
* | bsp/imx: Add register headers | Sebastian Huber | 2017-09-22 | 4 | -0/+276 |
* | bsps/arm: Copy FDT only on boot processor | Sebastian Huber | 2017-09-22 | 1 | -7/+14 |
* | score: Include missing header file | Sebastian Huber | 2017-09-22 | 1 | -0/+2 |
| | | | | Update #3059. | ||||
* | posix: Allow PTHREAD_PROCESS_SHARED for rwlocks | Sebastian Huber | 2017-09-22 | 2 | -23/+45 |
| | | | | Close #3153. | ||||
* | psxrdwrv/test.c: Clear iovec to ensure consistent results | Joel Sherrill | 2017-09-21 | 1 | -0/+3 |
| | | | | closes #3148. | ||||
* | bsps/powerpc: Fix robust thread dispatch | Sebastian Huber | 2017-09-21 | 1 | -6/+21 |
| | | | | | | | Implement thread dispatch code in ppc_exc_wrapup() similar to ppc_exc_interrupt(). Update #2811. | ||||
* | bsp/t32mppc: PPC_EXC_CONFIG_USE_FIXED_HANDLER | Sebastian Huber | 2017-09-21 | 1 | -9/+9 |
| | | | | | | Fix link-time error. Update #3085. | ||||
* | bsp/qemuppc: Fix for RTEMS_DEBUG | Sebastian Huber | 2017-09-20 | 1 | -2/+2 |
* | bsp/psim: Fix for RTEMS_DEBUG | Sebastian Huber | 2017-09-20 | 1 | -2/+2 |
* | bsp/mpc8260ads: Fix for RTEMS_DEBUG | Sebastian Huber | 2017-09-20 | 1 | -1/+1 |
* | bsps/powerpc: Fix PPC_EXC_CONFIG_USE_FIXED_HANDLER | Sebastian Huber | 2017-09-20 | 3 | -5/+7 |
| | | | | | | Fix link-time error on BSPs not using PPC_EXC_CONFIG_USE_FIXED_HANDLER. Update #3085. | ||||
* | bsp/qoriq: Update README | Sebastian Huber | 2017-09-19 | 1 | -0/+11 |
| | | | | Close #3085. | ||||
* | bsp/qoriq: Add hypervisor guest SMP support | Sebastian Huber | 2017-09-19 | 3 | -7/+55 |
* | bsp/qoriq: MMU configuration as hypervisor guest | Sebastian Huber | 2017-09-19 | 2 | -10/+5 |
| | | | | | | | Re-enable MMU configuration as hypervisor guest. Make sure the QORIQ_TLB1_ENTRY_COUNT is set according to the hypervisor configuration. Update #3085. | ||||
* | bsp/qoriq: Avoid IVOR38..42 access as hv guest | Sebastian Huber | 2017-09-19 | 1 | -0/+2 |
* | bsp/qoriq: Avoid MAS8 access as hypervisor guest | Sebastian Huber | 2017-09-19 | 1 | -3/+3 |
* | bsp/qoriq: Reduce static memory demands | Sebastian Huber | 2017-09-19 | 1 | -1/+1 |
* | bsp/qoriq: Add decrementer clock driver | Sebastian Huber | 2017-09-19 | 5 | -8/+69 |
* | bsp/qoriq: Add early debug output initialization | Sebastian Huber | 2017-09-19 | 1 | -3/+18 |
| | | | | Update #3085. |
