* spfifo01/init.c, spfifo01/spfifo01.doc, spfifo02/init.c,
spfifo02/spfifo02.doc, spfifo03/init.c, spfifo03/spfifo03.doc,
spfifo04/init.c, spfifo04/spfifo04.doc: Modified copyright.
* libcsupport/src/unmount.c: Removed obsolete declarations. Fixed
invalid memory free.
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Removed
rtems_ftpfs_mount().
* libcsupport/src/mount-mktgt.c: New file.
* libcsupport/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Declare
mount_and_make_target_path().
* libnetworking/rtems/ftpfs.h, libnetworking/lib/ftpfs.c: Added
rtems_ftpfs_mount() again. Documentation.
* libcsupport/include/rtems/libio.h, sapi/include/confdefs.h: Added
and use defines for file system types.
* libcsupport/src/mount.c: Fixed NULL pointer access.
* Makefile.am, configure.ac: Remove support for shttpd.
* aclocal/enable-shttpd.m4: Remove.
* Makefile.am, configure.ac: Remove support for httpd (GoAhead).
* aclocal/enable-httpd.m4: Remove.
* libcsupport/include/rtems/libio.h: Documentation.
* libfs/src/imfs/imfs_creat.c: Reject creation of FIFOs if support is
disabled.
* sp16/task1.c: Update for heap extend changes.
* spfifo01/init.c, spfifo01/spfifo01.scn: Update for IMFS API changes.
* spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am: Merged fifo main and test files into the
standard init file. Fixed copyright information.
* spfifo01/init.c, spfifo02/init.c, spfifo03/init.c, spfifo04/init.c:
New files.
* spfifo01/main.c, spfifo01/test.c, spfifo02/main.c, spfifo02/test.c,
spfifo03/main.c, spfifo03/test.c, spfifo04/main.c, spfifo04/test.c:
Removed.
* spmkdir/.cvsignore, spmkdir/Makefile.am, spmkdir/init.c,
spmkdir/spmkdir.doc, spmkdir/spmkdir.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
* spfifo01/.cvsignore, spfifo02/.cvsignore, spfifo03/.cvsignore,
spfifo04/.cvsignore: New files.
* psxfile01/test.c: Update for IMFS API changes.
PR 1524/filesystem
* libcsupport/src/rtems_mkdir.c: New file.
* libcsupport/src/Makefile.am: Reflect change above.
* libcsupport/include/rtems/libio.h: Added rtems_mkdir().
* libmisc/fsmount/fsmount.h, libmisc/fsmount/fsmount.c,
libblock/src/bdpart-mount.c, libnetworking/rtems/mkrootfs.h,
libnetworking/rtems/mkrootfs.c, libfs/src/pipe/pipe.c: Use
rtems_mkdir(). Removed rtems_fsmount_create_mount_point() and
rtems_rootfs_mkdir().
PR 1524/filesystem
* libfs/src/imfs/fifoimfs_init.c: New file.
* libfs/Makefile.am: Reflect change above.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/miniimfs_init.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: Pipe support is now
link-time optional.
* sapi/include/confdefs.h: Reflect changes above.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_rmnod.c: Added and use
IMFS_create_orphan() and IMFS_check_node_remove().
* libfs/src/imfs/deviceio.c, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fifo.c: Use IMFS_create_orphan() and
* libfs/src/imfs/imfs_handlers_memfile.c, libfs/src/imfs/memfile.c:
Use IMFS_rmnod() and IMFS_check_node_remove() instead of
memfile_rmnod() and memfile_check_rmnod().
* libfs/src/devfs/devclose.c, libfs/src/devfs/devopen.c,
libfs/src/imfs/deviceerrno.c, libfs/src/imfs/deviceio.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c: Changed rtems_deviceio_errno() to
cope with a status code of RTEMS_SUCCESSFUL. Removed dependency on
association framework.
* spfifo01/main.c: New file.
