* README.configure: Corrected the name of the MRM332 BSP.
Strengthened the distinction between what the target
and the BSP each select. Added more targets to list.
* TESTED: Corrected the name of the MRM332 BSP.
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
* custom/mrm332.cfg: New file.
* TESTED: Updated the list of BSPs.
* TOOLS_TARGETS: Updated the list of tools and object formats.
* README.configure: Updated the list of BSPs.
* src/imfs/imfs_initsupp.c: Create the root node with the
desired permissions. Nodes should be created with the right
permissions because chmod() is not supported by the miniIMFS
so changing after creation is not possible.
* libc/base_fs.c: Deleted chmod() now that IMFS creates the
root node with the desired permissions. chmod() is also not
supported by the miniIMFS so this is not allowable.
* Added once version of psxchroot01 test for user review.
* psxchroot01: New directory.
* psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c,
psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files.
* configure.in, Makefile.am: Modified to reflect above.
* include/rtems/libio_.h: Added login name, uid, gid, euid, and egid
so they can be part of the private environment.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* libc/ttyname.c (ttyname_r): Removed duplicate call to closedir().
* libc/getpwent.c: Create a more robust /etc/passwd and /etc/group.
* libc/base_fs.c: Change permissions of files and directories. Now uses
octal constants.
* src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c,
src/getuid.c: Now save their values in private user environment.
* start/start.S: Increased BAT0 mapping of RAM from 64 meg to
256 meg to allow operation on boards with larger RAM sizes.
* vectors/vectors_init.c: Modified to call 'generic' powerpc
vector function (mpc60x_vector_is_valid) instead of MPC750
specific function to allow operation on boards with CPUs other
than the MPC750.
* mpc6xx/timer/timer.c: Added include of bsp.h and removed
external declaration of BSP_Convert_decrementer() to
correct unresolved reference to this routine.
* mpc8xx/console-generic/console-generic.c: Bug found by Yacine
<elkolli@crf.canon.fr> where the initialization or irq data structure
was incomplete in case a SMC channel was used first and later a SCC one.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
* start/Makefile.am: Dito.
* network/Makefile.am: Dito.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* configure.in: remove shared/io/Makefile.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
* configure.in: Add bspopts.h, AC_DEFINE CONSOLE_USE_INTERRUPTS,
CONSOLE_USE_POLLED, HAS_RTC.
* include/.cvsignore: Add bspopts.h*, stamp-h*, coverhd.h, tod.h.
* include/Makefile.am: Use *_HEADERS instead of *H_FILES, New
treatment of tod.h, coverhd.h.
* include/bsp.h: Add include bspopts.h.
* custom/dmv177.cfg: Remove CONSOLE_USE_INTERRUPTS,
* canonical-target-name.m4: Fix m4-quoting for autoconf-2.49f.
* aclocal/config-subdirs.m: Fix m4-quoting for autoconf-2.49f,
Add support for DOS-drive-letters.
* configure.in: Remove AC_EXEEXT, treat .exe manually.
* gccnewlib/base-gcc.add: Remove cpp.
* gccnewlib/gccnewlib.add: mv cpp $target_alias-cpp, update
copyright.
* mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/vectorisrs.c, tx39/vectorisrs/vectorisrs.c,
tx39/include/tx3904.h: All exceptions were given low numbers and thus
can be now be installed and processed in a uniform manner just like interrupts.
Variances between various MIPS ISA levels are not accounted for at this time.
* mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/maxvectors.c,
r46xx/vectorisrs/Makefile.am, r46xx/vectorisrs/maxvectors.c,
tx39/vectorisrs/Makefile.am, tx39/vectorisrs/maxvectors.c,
shared/interrupts/maxvectors.c, shared/interrupts/Makefile.am: Split the
shared maxvectors.c into a variety of CPU model specific versions to simplify
the build process and reduce depdencies. Deleted shared/interrupts/maxvectors.c
and created various CPU model versions.
* rtems/score/mips.h: Added constants for MIPS exception numbers.
All exceptions should be given low numbers and thus can be installed
and processed in a uniform manner. Variances between various MIPS
ISA levels were not accounted for.
* clock/clock.S: Move placement of nop.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* start/regs.S, start/start.S: Now works on Mongoose-V. Missed
in previous patch.
* cpu_asm.S: Now works on Mongoose-V. Missed in previous patch.
* mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
shared/interrupts/maxvectors.c: Now works. Significant rework
of exceptions and interrupt vectoring to clean things up.
* shared/interrupts/vectorexceptions.c: Removed.
* shared/interrupts/Makefile.am: Reflects above.
* clock/clockdrv.c, console/conscfg.c: Corrected.
* include/bsp.h: Support for tm27 and addition of CPU_CLOCK_RATE.
* startup/bspstart.c: Properly set initial status register and
pending interrupts.
* timer/timer.c: Works now.
* rtems/score/cpu.h: Add the interrupt stack structure and enhance
the context initialization to account for floating point tasks.
* rtems/score/mips.h: Added the routines mips_set_cause(),
mips_get_fcr31(), and mips_set_fcr31().
* custom/gensh1.cfg: Remove HZ, BSP_CPPFLAGS.
* custom/gensh2.cfg: Dito.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt
bspopts.h handling to other sh-BSPs.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* startup/bspstart.c: Reworked, based on the amos BSP.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
add bspopts.h.
* configure.in: Remove RTEMS_PROG_CC_FOR_TARGET,
RTEMS_PROG_CXX_FOR_TARGET, RTEMS_CANONICALIZE_TOOLS.
* tools/runtest: Add functionality to avoid letting simulator
run too long.
* libc/write.c: Change type of rc to match return type from
underlying function per report from Eric Norum.
* libc/Makefile.am: Remove -D__STRICT_ANSI__.
* scitab/.cvsignore: Add.
* configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader
bspopt.h.
* include/bsp.h: Complete rewrite based on the AMOS-BSP.
* README: Update.
* bsp_specs: copy from gensh1
* include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h,
cpuopts.h.in, cpuopts-tmp.h.
