* | | Fixed calls to Message_Queue_Create to include maximum message size | Joel Sherrill | 1997-06-03 | 9 | -5/+14 | |
| | | | | | | | | parameter. | |||||
* | | Changed to variable length messages. | Joel Sherrill | 1997-06-03 | 17 | -66/+219 | |
* | | Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 1997-06-03 | 11 | -11/+11 | |
* | | Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | Fixed all references to Semaphore_Create to have the correct | Joel Sherrill | 1997-06-03 | 7 | -5/+12 | |
| | | | | | | | | argument sequence. | |||||
* | | New file. | Joel Sherrill | 1997-06-03 | 28 | -0/+1045 | |
* | | new file | Joel Sherrill | 1997-06-03 | 28 | -0/+1596 | |
* | | Removed Configuration Table information. | Joel Sherrill | 1997-06-03 | 30 | -1170/+0 | |
* | | Corrected call to Semaphore_Create to have the proper calling sequence | Joel Sherrill | 1997-06-03 | 1 | -0/+2 | |
* | | Removed Configuration Table information | Joel Sherrill | 1997-06-03 | 1 | -38/+0 | |
* | | new file | Joel Sherrill | 1997-06-03 | 2 | -0/+94 | |
* | | Removed unnecessary dependency on RTEMS_Test_Support which existed | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
| | | | | | | | | in the RTEMS Ada implementation but does not exist in this binding. | |||||
* | | new file | Joel Sherrill | 1997-06-03 | 6 | -0/+209 | |
* | | removed reference to the Stub Device Driver | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
* | | Changed mode and priority of initialization task. | Joel Sherrill | 1997-06-03 | 2 | -5/+2 | |
* | | Changed attribute of Initialization Task to Floating_Point | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | new files | Joel Sherrill | 1997-06-03 | 2 | -0/+56 | |
* | | new file | Joel Sherrill | 1997-06-03 | 3 | -0/+326 | |
* | | new file | Joel Sherrill | 1997-06-03 | 14 | -0/+504 | |
* | | Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. | Joel Sherrill | 1997-06-03 | 1 | -1/+1 | |
* | | new files | Joel Sherrill | 1997-06-03 | 2 | -0/+82 | |
* | | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 4 | -16/+72 | |
| | | | | | | | | making sure every True/False reference was fully qualified. | |||||
* | | Switched to proper types for booleans and increased the stack space | Joel Sherrill | 1997-06-03 | 2 | -5/+6 | |
| | | | | | | | | for the tasks in this test. | |||||
* | | Added RTEMS boolean constants. | Joel Sherrill | 1997-06-03 | 2 | -0/+6 | |
* | | Modifed to make the test run to completion. Primarily provided | Joel Sherrill | 1997-06-03 | 2 | -32/+96 | |
| | | | | | | | | | | | | the Buffer type and support routines although some work was required to account for the directives which required message size information. | |||||
* | | Commented out exception handling code since these routines are not | Joel Sherrill | 1997-06-03 | 1 | -9/+9 | |
| | | | | | | | | | | called from Ada tasks. It is questionable whether the exception handling would work correctly. | |||||
* | | removed with of unchecked_conversion | Joel Sherrill | 1997-06-03 | 1 | -1/+0 | |
* | | sptest.adb: update Semaphore_Create calling sequence | Joel Sherrill | 1997-06-03 | 2 | -1/+8 | |
| | | | | | | | | sp12.adb: doubled the initialization task stack size | |||||
* | | Added Pending_Events and lined up other event constants | Joel Sherrill | 1997-06-03 | 2 | -66/+68 | |
* | | Fixed problems which prevented the test from compiling and running to | Joel Sherrill | 1997-06-03 | 3 | -85/+157 | |
| | | | | | | | | completion. | |||||
* | | added more constants and fixed numer | Joel Sherrill | 1997-06-03 | 4 | -48/+128 | |
* | | changed reference for Configuration Table from BSP to RTEMS. | Joel Sherrill | 1997-06-03 | 1 | -2/+1 | |
* | | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 1997-06-03 | 4 | -10/+148 | |
* | | *** empty log message *** | Joel Sherrill | 1997-06-03 | 19 | -18/+13 | |
* | | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 1997-06-03 | 4 | -32/+12 | |
| | | | | | | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | |||||
* | | updated to run | Joel Sherrill | 1997-06-03 | 2 | -15/+42 | |
* | | New style main procedure which creates the test's RTEMS initialization task | Joel Sherrill | 1997-06-03 | 28 | -27/+687 | |
| | | | | | | | | | | | | as an RTEMS task. This avoid problems resulting from differences in the tasking mode/priority of Ada tasks from the typical way an RTEMS initialization task is created. | |||||
* | | added subtract of 1 to Task_Number to account for the creation | Joel Sherrill | 1997-06-02 | 1 | -1/+1 | |
| | | | | | | | | of the initialization task | |||||
* | | *** empty log message *** | Joel Sherrill | 1997-06-02 | 1 | -1/+0 | |
* | | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1997-06-02 | 2 | -16/+46 | |
* | | new file | Joel Sherrill | 1997-06-02 | 1 | -0/+33 | |
* | | readded body for "main" procedures | Joel Sherrill | 1997-06-02 | 47 | -23/+744 | |
* | | removed configuration table definition in Ada | Joel Sherrill | 1997-06-02 | 23 | -1290/+0 | |
* | | new file - automatically generated by a script | Joel Sherrill | 1997-06-02 | 55 | -0/+0 | |
* | | Changed license and copyright notice. | Joel Sherrill | 1997-06-02 | 5 | -52/+25 | |
| | | | | | | | | Added "development" style CVS Id | |||||
* | | New file -- works in conjunction with support/init.c. | Joel Sherrill | 1997-06-02 | 1 | -0/+33 | |
* | | Removed Ada Configuration Table definition. | Joel Sherrill | 1997-06-02 | 1 | -55/+0 | |
* | | added screen files from 3.2.1 | Joel Sherrill | 1997-06-02 | 56 | -0/+1399 | |
* | | added new files from test area. | Joel Sherrill | 1997-06-02 | 9 | -0/+7264 | |
| | | | | | | | | This code has successfully been used to run sp01. | |||||
* | | modified copyright notice to be the same as RTEMS 4.0.0. | Joel Sherrill | 1997-06-02 | 176 | -1056/+1056 | |
| | | | | | | | | changed the CVS ID string to be a "development" version. |
