* started/buildc.t, started/buildrt.t, started/nt.t, started/require.t,
started/sample.t: Review and improve.
* network/network.c: Update for API changes.
* include/u-boot.h: Removed file.
* include/u-boot-config.h, include/tsec-config.h: New files.
* include/bsp.h, start/start.S, startup/bspstart.c: Use new U-Boot
support.
* Makefile.am, preinstall.am: Reflect changes above.
* Makefile.am, preinstall.am, mpc83xx/include/mpc83xx.h,
mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Make it possible to
use the TSEC driver for other systems.
* mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c,
mpc83xx/network/tsec.h: Make it possible to use the TSEC driver for
other systems.
* include/u-boot-config.h: New file.
support.
* shared/uboot_dump_bdinfo.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot-board-info.h: New file.
* shared/include/u-boot.h: Removed file.
* shared/bspgetworkarea.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot.h, shared/src/bsp-uboot-board-info.c: New
files.
* Makefile.am, preinstall.am, startup/start.S: Use standard zero
function.
* startup/linkcmds.base: Reserve enough space for the exception
minimum prologues. Changed start section name.
* startup/bspstart.c: Removed superfluous cache initialization.
* configure.ac: Fixed option default values.
* shared/include/start.h, shared/src/bsp-start-zero.S: New files.
* new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_initialize.c: Fixed IVOR handling for
e200z0 and e200z1.
* mpc55xx/include/mpc55xx.h, mpc55xx/misc/copy.S: Removed zero
functions.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h: Added support
for e500v2. Removed IVPR/IVOR/HWIVOR features since they are included
in Book E.
* new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_categories.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
new-exceptions/bspsupport/ppc_exc_prologue.c: Added support for
e500v2. Added exception vector defines for Book E types. Removed
e200 exception vector defines. Added e500 exception vector defines.
Unified IVOR calculation for e200 and e500 (e200z1 has hard wired
IVOR values).
minimum prologues.
* libfs/src/dosfs/msdos_conv.c: Fixed convertion of half seconds to
seconds.
* libfs/src/dosfs/msdos_misc.c: Create short file names acceptable for
Windows.
* libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_misc.c,
libfs/src/dosfs/msdos_create.c: Create valid create and modfied date
and time.
* mpc83xx/i2c/mpc83xx_i2cdrv.c: Fixed interrupt flag clearing for
MPC55XX family.
* configure.ac: Added I2C options. Fixed eMIOS prescaler. Use
standard linker command file support.
* include/bsp.h: Declare I2C initialization function.
* i2c/i2c_init.c: Implementation.
* make/custom/gwlcfm.cfg, make/custom/mpc5566evb.cfg,
make/custom/mpc55xx.inc: Use standard linker command file support.
* startup/bspstart.c: More board specific settings.
* new-exceptions/bspsupport/ppc_exc.S: Comment.
* new-exceptions/bspsupport/ppc_exc_address.c: Fixed address
calculation for e200z1 core.
Add RTEMS Scheduler Simulator.
* configure.ac: Add tools/schedsim.
Jennifer Averett <jennifer.averett@oarcorp.com>
* sapi/include/confdefs.h: This adds some simple conditional
logic to disable portions of the configuration that are NOT supported
when configuring an RTEMS instance for use with a Scheduler Simulator
instance.
Add RTEMS Scheduler Simulator. This is the top level of the tree.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
* .cvsignore: New file.
Add RTEMS Scheduler Simulator. This is the RTEMS "port" to and
adapter code to run on GNU/Linux with a fake context switch.
* ChangeLog, Makefile.am, interr.c, rtems_init.c, rtems_sched.h,
wkspace.c, sched_cpu/cpu.c, sched_cpu/cpu_asm.c,
sched_cpu/rtems/asm.h, sched_cpu/rtems/stringto.h,
sched_cpu/rtems/score/cpu.h, sched_cpu/rtems/score/cpu_asm.h,
sched_cpu/rtems/score/cpuopts.h, sched_cpu/rtems/score/no_cpu.h,
sched_cpu/rtems/score/types.h: New files.
Add RTEMS Scheduler Simulator. This is the shell scripting portion.
* .cvsignore, ChangeLog, Makefile.am, schedsim_priority/.cvsignore,
schedsim_priority/Makefile.am, schedsim_priority/config.c,
schedsim_priority/printheir_executing.c,
schedsim_priority/schedsim.cc,
schedsim_priority/wrap_thread_dispatch.c, scripts/script01,
scripts/script02, scripts/script03, scripts/script04,
scripts/script05, scripts/script06, shared/.cvsignore,
shared/Makefile.am, shared/commands.c, shared/getopt.c,
shared/lookup_semaphore.c, shared/lookup_task.c,
shared/main_clocktick.c, shared/main_echo.c, shared/main_executing.c,
shared/main_heir.c, shared/main_help.c, shared/main_rtemsinit.c,
shared/main_semcreate.c, shared/main_semdelete.c,
shared/main_semflush.c, shared/main_semobtain.c,
shared/main_semrelease.c, shared/main_taskcreate.c,
shared/main_taskdelete.c, shared/main_taskmode.c,
shared/main_taskpriority.c, shared/main_taskresume.c,
shared/main_tasksuspend.c, shared/main_taskwakeafter.c,
shared/schedsim_shell.h, shared/shell_cmdset.c,
shared/shell_makeargs.c, shared/include/shell.h,
shared/include/newlib/_ansi.h, shared/include/newlib/getopt.h: New
files.
* math/Makefile.am, math/init.c: Init task has to be floating point and
there is no point in using optional manager stubs since libio needs
semaphores.
* develenv/direct.t: Remove Getting Started with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti,
started_ada/started_ada.texi, started_ada/tversions.texi,
started_ada/version.texi: Removed.
* SUPPORT: Update address.
* libmisc/cpuuse/cpuusagereport.c: We have to take the time since the
last context switch before the uptime.
* score/src/watchdognanoseconds.c: New file.
* score/Makefile.am: Reflect change above.
* score/include/rtems/score/watchdog.h, score/src/coretodget.c,
score/src/coretodgetuptime.c: Do not allow NULL as nanoseconds since
last tick handler pointer.
* shared/lpc/include/lpc-i2s.h: Documentation. Fixed defines.
* shared/lpc/include/lpc-timer.h: Documentation.
* shared/lpc/network/lpc-ethernet.c: Added support for 10MBit/s links.
* configure.ac, include/bspopts.h.in: More options.
* include/lpc32xx.h: Added watchdog definitions.
* include/mmu.h, misc/mmu.c: Added const qualifier.
* startup/bspreset.c: Use watchdog reset.
* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
BINUTILS_RPMREL = 0.20101211.0.
GCC_RPMREL = 0.20101211.0.
Remove fedora 12.
* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* libnetworking/loop.h, libnetworking/net/if_loop.c,
libnetworking/rtems/rtems_glue.c, libmisc/dummy/dummy-networking.c:
Initialize loop back interface during normal initialization via
* make/custom/rtl22xx_t.cfg: Now compiles.
