* | changed version to 19991117 | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Removed reference to Jennifer. | Joel Sherrill | 1999-11-17 | 1 | -2/+1 |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 2933 | -5856/+2939 |
* | Removed as part of patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius | Joel Sherrill | 1999-11-17 | 1 | -73/+0 |
| | | | | <corsepiu@faw.uni-ulm.de>. | ||||
* | Now allows override of base address via -Ttext command to linker. | Joel Sherrill | 1999-11-17 | 1 | -39/+47 |
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 6 | -8/+10 |
* | + Updated copyright information. | Jennifer Averett | 1999-11-17 | 266 | -104/+694 |
* | New date. | Joel Sherrill | 1999-11-17 | 2 | -5/+5 |
* | New file documenting the on board monitor (PPCBUG) configuration used | Joel Sherrill | 1999-11-17 | 2 | -0/+156 |
| | | | | | to be able to boot the archives located in powerpc-rtems/c/mcp750/bin. This information was provided by Eric Valette <valette@crf.canon.fr> | ||||
* | Patch rtems-rc-19991105-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-11-17 | 3 | -7/+25 |
| | | | | | | | His comments follow: This is a minor enhancement to shgen, which should not have any side-effects. | ||||
* | Conditionally take out the offensive pragma pack when on RTEMS in addition | Joel Sherrill | 1999-11-17 | 2 | -4/+4 |
| | | | | to UnixWare (UW). | ||||
* | New shell of a test for ITRON Mailbox Manager. | Joel Sherrill | 1999-11-17 | 12 | -2/+224 |
* | Updated Mailbox Manager submitted and split into multiple files. | Joel Sherrill | 1999-11-17 | 22 | -688/+940 |
* | Corrected spacing. | Joel Sherrill | 1999-11-17 | 1 | -8/+12 |
* | Correctd name of document produced for consistency. | Joel Sherrill | 1999-11-17 | 1 | -1/+1 |
* | Updated to reflect Mailbox Manager submission. | Joel Sherrill | 1999-11-17 | 1 | -3/+1 |
* | Update from Andrew D. McDowell <amcdowel@cs.uah.edu> with modifications | Joel Sherrill | 1999-11-17 | 2 | -14/+514 |
| | | | | | by Joel and Jennifer based on experience merging the other managers and cleaning them up. No test code is available at this point. | ||||
* | Fixed screen. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 |
* | Added TERMINAL_IDENTIFICATION pieces. | Joel Sherrill | 1999-11-16 | 1 | -3/+4 |
* | Fixed alignment problem on _endtext. | Joel Sherrill | 1999-11-16 | 1 | -0/+1 |
* | Moved task_variable pointer to basic shared part of TCB instead of | Joel Sherrill | 1999-11-16 | 10 | -76/+52 |
| | | | | | | | RTEMS API extension to avoid problems when the extension is freed. Eventually the task variable switch extension should become part of the core context switch and the Ada tcb self implemented in terms of it. | ||||
* | Added proper nesting level for dispatch disable check. | Joel Sherrill | 1999-11-16 | 6 | -6/+6 |
* | Added code so if dispatching level is specified to be -1, then no | Joel Sherrill | 1999-11-16 | 2 | -2/+2 |
| | | | | | check is performed. This is needed in some timer service routines since they are called from multiple disable levels. | ||||
* | Corrected nesting level on dispatching verification. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 |
* | Corrected disable dispatch nesting count checks. | Joel Sherrill | 1999-11-16 | 2 | -14/+14 |
* | Added check to return passed if task is not suspended. | Jennifer Averett | 1999-11-16 | 4 | -2/+14 |
* | Added code to catch the error of suspend count exceding the counter value. | Jennifer Averett | 1999-11-16 | 2 | -0/+8 |
* | Fixed bug. | Jennifer Averett | 1999-11-16 | 3 | -9/+9 |
* | Added handler for fsync. For the memfile it is the same as the data sync. | Jennifer Averett | 1999-11-16 | 4 | -4/+4 |
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 12 | -175/+185 |
* | Changed name of document generated. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Added ITRON 3.0 API User's Guide. | Joel Sherrill | 1999-11-16 | 2 | -2/+12 |
* | Fixed typo. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Corrected status. | Joel Sherrill | 1999-11-16 | 1 | -2/+2 |
* | Fixed typo. | Joel Sherrill | 1999-11-16 | 2 | -2/+2 |
* | Inserted output from the erc32 run into the output file. | Jennifer Averett | 1999-11-16 | 2 | -6/+142 |
* | Use miniIMFS like hello from samples. | Joel Sherrill | 1999-11-16 | 2 | -0/+4 |
* | Increased stack space because message buffers are on the stack. | Joel Sherrill | 1999-11-16 | 2 | -0/+2 |
* | Removed leading space from output. | Jennifer Averett | 1999-11-16 | 4 | -8/+8 |
* | Added comment indicating that dup is known to be broken. | Jennifer Averett | 1999-11-16 | 2 | -2/+2 |
* | Added data to the log file so it matches the real output. | Jennifer Averett | 1999-11-16 | 2 | -6/+122 |
* | Added comment to log file indicating that task order is not | Jennifer Averett | 1999-11-16 | 2 | -2/+6 |
| | | | | critical. | ||||
* | Added test case of rsm_tsk and frsm_tsk on a task not suspended. | Jennifer Averett | 1999-11-16 | 4 | -6/+28 |
| | | | | This should result in nothing happening, but an E_OK result. | ||||
* | Fixed spacing. | Joel Sherrill | 1999-11-16 | 2 | -48/+48 |
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+14 |
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 308 | -372/+384 |
* | Added copyright. | Joel Sherrill | 1999-11-16 | 14 | -12/+62 |
* | Changed release date. | Joel Sherrill | 1999-11-16 | 2 | -6/+6 |
* | Added status chapter. | Joel Sherrill | 1999-11-16 | 3 | -2/+73 |
