* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wrapup/Makefile.am: Fix path to libxdr and librpc (Another typo in
from the 2002-12-12 patch).
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* wrapup/Makefile.am: Fix typo in yesterday's patch.
Makefile.am: Don't create $ARCH.
* wrapup/Makefile.am: Don't create $ARCH.
Use install-data-local to install librtemscpu.a
* bsp.mak: Use ac_cv_env instead of ac_cv for cached vars.
* automake/compile.am: Remove creating $(ARCH) in compilation rules.
* wrapup/Makefile.am: Use install-data-local to install librtemsbsp.a.
Let all-local: depend on $(LIB).
* Makefile.am: Merge-in kern/Makefile.am, net/Makefile.am,
netinet/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
rtems/Makefile.am.
* kern/Makefile.am: Remove.
* net/Makefile.am: Remove.
* netinet/Makefile.am: Remove.
* nfs/Makefile.am: Remove.
* rtems/Makefile.am: Remove.
* configure.ac: Ditto.
* Makefile.am: Don't create $ARCH as side-effect of compilation.
Re-order all-local.
* src/imfs/Makefile.am: Eliminate C_O_FILES.
* src/dosfs/Makefile.am: Ditto.
* Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
* configure.ac: Require autoconf-2.57+automake-1.7.2.
* capture/Makefile.am: Eliminate C_O_FILES.
* cpuuse/Makefile.am: Ditto.
* devnull/Makefile.am: Ditto.
* dummy/Makefile.am: Ditto.
* dumpbuf/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* serdbg/Makefile.am: Ditto.
* shell/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* untar/Makefile.am: Ditto.
* mw-fb/Makefile.am: Eliminate C_O_FILES.
Eliminate SRCS.
* Makefile.am: Apply install-data-local to install *.rels.
* configure.ac: Require autoconf >= 2.57 and automake-1.7.2.
* .cvsignore: Moved to rtems/cpukit/libmisc.
* ChangeLog: Moved to rtems/cpukit/libmisc.
* Makefile.am: Moved to rtems/cpukit/libmisc.
* README: Moved to rtems/cpukit/libmisc.
* configure.ac: Moved to rtems/cpukit/libmisc.
* capture/Makefile.am: Moved to rtems/cpukit/libmisc.
* capture/README: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.c: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.h: Moved to rtems/cpukit/libmisc.
* capture/capture.c: Moved to rtems/cpukit/libmisc.
* capture/capture.h: Moved to rtems/cpukit/libmisc.
* cpuuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* cpuuse/README: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.c: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.h: Moved to rtems/cpukit/libmisc.
* devnull/.cvsignore: Moved to rtems/cpukit/libmisc.
* devnull/Makefile.am: Moved to rtems/cpukit/libmisc.
* devnull/devnull.c: Moved to rtems/cpukit/libmisc.
* devnull/devnull.h: Moved to rtems/cpukit/libmisc.
* dummy/.cvsignore: Moved to rtems/cpukit/libmisc.
* dummy/Makefile.am: Moved to rtems/cpukit/libmisc.
* dummy/README: Moved to rtems/cpukit/libmisc.
* dummy/dummy.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/.cvsignore: Moved to rtems/cpukit/libmisc.
* dumpbuf/Makefile.am: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.h: Moved to rtems/cpukit/libmisc.
* monitor/.cvsignore: Moved to rtems/cpukit/libmisc.
* monitor/Makefile.am: Moved to rtems/cpukit/libmisc.
* monitor/README: Moved to rtems/cpukit/libmisc.
* monitor/mon-command.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-config.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-dname.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-driver.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-extension.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-itask.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-manager.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-monitor.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-mpci.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-object.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-prmisc.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-queue.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-server.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-symbols.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-task.c: Moved to rtems/cpukit/libmisc.
* monitor/monitor.h: Moved to rtems/cpukit/libmisc.
* monitor/symbols.h: Moved to rtems/cpukit/libmisc.
* mw-fb/.cvsignore: Moved to rtems/cpukit/libmisc.
* mw-fb/Makefile.am: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.h: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.h: Moved to rtems/cpukit/libmisc.
* rtmonuse/.cvsignore: Moved to rtems/cpukit/libmisc.
* rtmonuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.c: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.h: Moved to rtems/cpukit/libmisc.
* serdbg/.cvsignore: Moved to rtems/cpukit/libmisc.
* serdbg/Makefile.am: Moved to rtems/cpukit/libmisc.
* serdbg/README: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.c: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgcnf.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgio.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.h: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk_cnf.h: Moved to rtems/cpukit/libmisc.
* shell/.cvsignore: Moved to rtems/cpukit/libmisc.
* shell/Makefile.am: Moved to rtems/cpukit/libmisc.
* shell/README: Moved to rtems/cpukit/libmisc.
* shell/cmds.c: Moved to rtems/cpukit/libmisc.
* shell/shell.c: Moved to rtems/cpukit/libmisc.
* shell/shell.h: Moved to rtems/cpukit/libmisc.
* stackchk/.cvsignore: Moved to rtems/cpukit/libmisc.
* stackchk/Makefile.am: Moved to rtems/cpukit/libmisc.
* stackchk/README: Moved to rtems/cpukit/libmisc.
* stackchk/check.c: Moved to rtems/cpukit/libmisc.
* stackchk/internal.h: Moved to rtems/cpukit/libmisc.
* stackchk/stackchk.h: Moved to rtems/cpukit/libmisc.
* untar/.cvsignore: Moved to rtems/cpukit/libmisc.
* untar/Makefile.am: Moved to rtems/cpukit/libmisc.
* untar/README: Moved to rtems/cpukit/libmisc.
* untar/untar.c: Moved to rtems/cpukit/libmisc.
* untar/untar.h: Moved to rtems/cpukit/libmisc.
* wrapup/.cvsignore: Moved to rtems/cpukit/libmisc.
* wrapup/Makefile.am: Moved to rtems/cpukit/libmisc.
* wrapup/Makefile.am: Remove libmisc.
* wrapup/Makefile.am: Add libmisc.
* configure.ac: Remove libmisc.
* configure.ac: Add AC_CONFIG_SUBDIR(libmisc).
Moving libmisc from rtems/c/src to rtems/cpukit.
* Makefile.am: Reflect new path.
* configure.ac: Reflect new path.
Use RTEMS_ENV_RTEMSCPU instead of RTEMS_ENV_RTEMSBSP.
Remove RTEMS_PROJECT_ROOT.
* capture/Makefile.am: Reflect new path.
Remove OBJS from all-local.
* mw-fb/Makefile.am: Ditto.
* wrapup/Makefile.am: Reflect new path.
* src/cancelrun.c, src/cleanuppop.c: Get the last real node not the
permanent null last node.
* Makefile.am: Eliminate *_O_FILES.
Don't create $ARCH in %.o: %.c rules.
* network/Makefile.am: Eliminate C_O_FILES.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto,
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* kern/Makefile.am: Remove C_O_FILES;
Don't let all-local depend on $OBJS)
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* aclocal/prog-cxx.m4: Swap RTEMS_CHECK_TOOL/AC_PROG_CXX.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serial/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Don't use LIBC_DEFINES.
* rtc/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in src/Makefile.am, include/Makefile.am.
Unconditionally check for CXX.
* Makefile.am: Introduce sapi_C_FILES, rtems_C_FILES.
Makefile.am: Fix macro-file installation.
* configure.ac: Remove RTEMS_ENV_RTEMS_BSP, add
AC_ARG_VAR(RTEMS_BSP)-hack instead.
Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/check-bsps.m4: Remove.
* bootstrap: Require autoconf 2.54 or 2.57.
Require automake-1.7.2.
